Found one problem while fixing another
regularman
I took my steering column out last night to get to the ingnition switch. I took a punch and hammer and undid the bolts and removed the switch. After taking it apart I found that there is a plastic cklip inside that broke. I am trying to figure a way to fix this and keep it all original. Anyways. since I put the car back together I had always felt just a little play in the steering. I thought it might have been the rack internal or the rodd ends or something. I found out what it was. It is the entire rack moving back and forth about 1/8 inch in its clamps. The clamp bolts seem to be tight. Was there some sort of rubber or shim material that is supposed to be wrapped around the rack before it goes in the clamps?
2091351
Hi Kim, yes they were wrapped with 'packing'. Closest recreation would be to use old cloth electrical tape. Don't laugh!! It works!
Steve
regularman
regularman
Steve
OK, thanks. Well, looks like its time to pull the radiator out to get to all that. Might as well go ahead and pull the head and check for that crack while I am at it.
Uh oh......he said the dirty words......"Might as well...."!!!
Where do we send our condolences??!! :laugh: LOL
RickB
So the winter projects are starting a bit early this year??
Jim_Gruber
Kim, I used a piece of bicycle inner tube glued to the clamp, Be sure and use a bottoming tap to clean out holes in the rack. Pay careful attention if you replace lock washers and bolts. They need to be the exact size as they bottom in the hole. A skoosh over and they won't get tight. Those parts are aluminum, don't over torque. Be sure and replace pinch bolt nut with a new metal locking bolt not a nylock.
Not sure what year your Spridget is but consider changing out the pinion gear. On Bugsy the pinion gear 7-8 years ago for a '68 Spridget ran $8.95. Later racks saw the pinion gear priced at 10 x's that. Guess supply and demand. Replacing pinion gear really tightened up the steering feel.
losmorob
This is where we get the 2010-2012 calender out. Everyone buys days a dollar a day. Who buys the day the car is back on the road, wins the pot.
We kid, because we've all been there. Like when my overdrive installation in my B turned into a full blown engine rebuild. "Might as well."
regularman
regularman
I went through the rack when I restored the car Jim, so Its pretty much all new and tight and shimmed correct, I just never figured the rack could get loose in the clamp. I got to work on this sunday and see how far I get. Not really winter project time yet. I got lots of them besides the midget. An 86 motorcycle ready to go back together and a 1970 model that I am fixing for the wife to play on, plus some solar and wood heating stuff to finish, oh and the midget exhaust mods as well. I might not pull that head yet though. I have not even been through that one from living in the past. Better do that first in case I find a crack. Swapping heads on the 1275 is probably one of the easier jobs. Gotta love push rods, no chain or rubber band to take loose and retime :smile:
regularman
regularman
Well, I did a bit more work today on the midget. I took the switch apart and found out that a tiny piece of plastic had broken off which I can fix with a bit of wire and put it back together. I also fixed the steering lock mechanism that seem to work sporadically, then all was going well until I realize that one of the two ball bearings that go in the switch with springs was now missing. I know it was there earlier. I swept and cleaned and used a magnet on the floor everywhere I could think of that it might have went. Whew, this is a demotivator. I am tired now. I need to find that little ball or find one like it and that wont be easy. That switch in my 1971 is NLA from what I can tell, so I have to make it work. I could put it back together with one ball and spring but it wont have as much "click" in each position and I like it to be like original if I can. Anyways, hope all is well in the spridget world elsewhere. Starting to rain here.
J TR2/3/3A Found my overflow problem from the radiator , Triumph 9
AngliaGT TR6 Found the TR6 Brake Problem Triumph 5
Baz Found the transmission problem....... Spridgets 0
G I think I may have found the problem Triumph 8
tony barnhill I Found Another Problem Job! Spridgets 13
64rocksprite Carb problem found..I think. Spridgets 9
B Found the problem! Woo Hoo! Austin Healey 9
M Spitfire Spitfire[Lucas]wiring problem FOUND! Triumph 12
simpzimmer Found the Clutch Problem Triumph 1
drooartz Found the problem with blowing my oil filters Spridgets 27
Earl TR2/3/3A TR3 Overheating I think??????? Problem Found Triumph 15
Rob Glasgow Found Original Owner Austin Healey 2
J Walnut veneer for the dash, Look what I found! Austin Healey 12
2 TR2/3/3A Headache: Magnaflux found a crack Triumph 5
Editor_Reid Oddities Found During BN2 Revival, Part 2 Austin Healey 6
Editor_Reid Oddities Found During BN2 Revival, Part 1 Austin Healey 4
B Lost & Found FORUM Help 3
B Wanted FOUND. TR10 Fan mount Bushings Triumph Classifieds 3
AngliaGT MGB I think I found the Cause MG 5
1 MGB Found the leak, now what? MG 11
C MGB Found this spring in my gas tank MG 8
jackq MGB MGB Roadsters with a V-8 found. MG 1
M General TR Found on Google books Triumph 0
J Found something new on a Healey engine Austin Healey 3
Michael Oritt Strange debris found in sump Austin Healey 19
J Found a 1963 BJ8, by the serial number, built in October of 63 Austin Healey 26
jackq TR2/3/3A TR3s found Triumph 5
Popeye TR4/4A Found this odd long bolt in my fuel tank... Does anyone know what it is? Triumph 17
PeterK General Tech I've found the light Triumph 8
Number_6 TR2/3/3A TR1 Prototype found Triumph 2
K TR4/4A Look what I found in a 4A oil filter? Triumph 14
Patrick67BJ8 Healey Abbott Found Austin Healey 8
M TR4/4A More Commission Number Questions. Mine is nowhere to be found! Triumph 6
drooartz Finally found one Spridgets 8
anarchy99 Found the only other British car at the show Spridgets 2
T TR2/3/3A Finally found and fitted paper carb air filters on my TR3 Triumph 28
Steve P. Finally found a RWA Midget Spridgets 1
J BJ8 windshield-shroud seal installation-found way to help keep ends from popping out Austin Healey 1
N TR6 found a Soft top frame from a 1972 for sale Triumph 2
LarryK Found MK2 parts in cavern. Jaguar 3
TulsaFred Fixed One Oil Leak, Found Another! Spridgets 12
H Aston Martin DB4 converible found in UK awhile back--what was paid for it? Other British Cars 0
CLEAH Found another number on my frame [BJ8] Austin Healey 6
PAUL161 Found My old 60 midget engine Racing 6
J Found an oil leak Austin Healey 7
J Found an E Type in a Barn. Bought it. Let's Make it Run Jaguar 15
germanmichel Horror story what I found below the battery... Austin Healey 9
RickB Found on Craigslist - 2 Midgets, one is RWA for $600 Spridgets 1
C Mystery Parts found in intake. What are they? Austin Healey 21
J Funniest thing you found working on your car Austin Healey 32
