Most people equate replacing a windshield with DIY tooth extraction (with out 'caine). Just finished a steel-dash windshield and it went slick. Used a few of the tricks in the library-the c-clamp to "A" pillar was cool. I used a piece of light rope to pull the bottom seal front lip out. GOOP (without pumice) works like a dream as lubrication to pull the seal along the bottome channel.
Only one question remains-the seal between the A pillar and the door glass is so stiff it puts an outward pressure on the door glass frame. Is there any type of lubricant that will allow the frame to slide in to place as the door is closed. I'm really terrified of "the crack of doom".
