BJ8 Windshield
Martec
Member
Hi
Does anyone have "instructions" on how to take apart and put back together an BJ8 windshield? I wish to send the frame out for re-chroming.
Thanks
Re: BJ8 Wind shield
Search this forum, myself and others have asked the same question and gotten good info. Short answer:
1) Remove the dash and unscrew the screw in the center of the dash.
2) Unbolt the windshield frame at the front pillars.
3) Lift the windshield out in one piece (2-man job).
Getting the glass back in a (presumably) new seal is a bit of a trick, there's info here.
Keoke
Re: BJ8 Wind shield
Getting the glass back in a (presumably) new seal is a bit of a trick, there's info here., or let a pro glass shop do it.
M
Martec
Member
Re: BJ8 Wind shield
I need to know how to diassemble the frame and put it back together after. There are rivets that need to be removed ...... can these be replaced later? I already have the screen out of the car and the screws in the frame loose. Or do I send the frame out to the platers with the riveted parts in place.
Thanks
PeterB
Re: BJ8 Wind shield
I just did the same to my BJ7. I sent everything to the plater and they took the rivets apart so they could see how it went together to know what to chrome. Sourcing the rivets and reinstalling them wasn't fun in the least but it can be done. I learned a little about riveting in the meantime.
RestoreThemAll
Re: BJ8 Wind shield
I haven't receive my windshield back from the platers yet but I sent good pictures ahead of time and they said I didn't need to remove the rivets. I thought that meant they weren't going to either. You may want to talk it through with your plater.
Re: BJ8 Wind shield
I think if there's any indication of rust around the rivet heads you'd want to remove them; I'm not sure the plating process can guarantee all traces of rust will be removed and/or neutralized under the rivet heads (IMO only).
RestoreThemAll
Re: BJ8 Wind shield
Excellent point Bob. I 100% agree. I had no rust around my rivets. Other folks may have.
Htimsc
Re: BJ8 Wind shield
Hello all, I need to remove the top bar from the windshield assembly of my BJ8. There are two screws at either end of the top bar. It appears that there is a “U” shaped channel facing down that holds the gasket that holds the glass. This is evidenced by a small hole about 3/8” in the middle of the channel in which the top of the rubber gasket can be seen. (Purpose of this hole is not clear).
Is the removal of this top bar as simple as removing the two screws either side and carefully levering up the bar?! If not what is the procedure? Are there any issues reinstalling the bar? I’ve found that the apparently most simple task with these cars are often not!
Thanks for any advice or suggestions...
Chris
Re: BJ8 Wind shield
The two screws on each side bracket fix an L-shaped bracket that also screws to the top bracket. Just unscrew them and the top bracket should be released from the side brackets.
The hole in the middle of the top bracket is for a rubber 'plug' that acts as a cushion for the hood (convertible top) when the hood is closed (convertible top is up).
Bob_Spidell BJ8 Windshield Replacement Austin Healey 11
wangdango BJ8 windshield to body hardware? Austin Healey 2
J BJ8 windshield-shroud seal installation-found way to help keep ends from popping out Austin Healey 1
C Re-Chroming BJ8 Windshield Surround Austin Healey 10
O BJ8 Windshield seal Austin Healey 3
H Any tips to install BJ8 bottom windshield seal? Austin Healey 0
C BJ8 Windshield re-chrome Austin Healey 9
J Rechroming BJ8 windshield support posts Austin Healey 5
A BJ8 Upper Windshield Bow - Center Hole Finisher Austin Healey 16
John Loftus BJ7-BJ8 windshield seal cut Austin Healey 6
Ed_K BJ8 windshield frame to scuttle gasket fun ! Austin Healey 10
R Removing 66 BJ8 Windshield frame Austin Healey 23
R BJ8 Windshield Frame Austin Healey 3
JamesD BJ8 Top Frame Bumpers Austin Healey 6
AUSMHLY BJ8 Driveshaft Installation Austin Healey 10
M BJ8 Inner Body Panel Repair Austin Healey 2
crispy BJ8 Front Suspension Austin Healey 9
Cutrog1 BJ8 Fuel Tube Installation Austin Healey 10
HealeyRick BJ8 Repaint Advice Sought Austin Healey 15
BJ8Healeys Original Metallic Golden Beige BJ8 for sale Austin Healey Classifieds 0
M BJ8 Seat Thickness Austin Healey 6
D BJ8 Headlight Rims Austin Healey 0
B RHD BJ8 Throttle Control Rods Austin Healey 9
J BJ8 Radiator Fan Austin Healey 12
H BJ8 Heater Valve/Control Tap Austin Healey 3
R BJ8 Upholstery Austin Healey 5
M Mounting BJ8 Chassis on Rotisserie Austin Healey 8
T BJ8 Drain Channel Removal Austin Healey 2
B BJ8 Phase 1 Electrical Diagram Austin Healey 15
M For Sale BJ8 Tonneau Cover Austin Healey Classifieds 8
R Distributor: Reassembling BJ8 Engine Austin Healey 5
lbcspinners BJ8 chassis number ending with suffix "G" [??] on BaT Austin Healey 11
R New Engine mountings BJ8 Austin Healey 1
T BJ8 carpet Austin Healey 2
R Cylinder head gasket BJ8 Austin Healey 32
pkmh BJ8: Upper Trunnion Rebuild [Of Continuum] Austin Healey 9
BJ8Healeys For Sale 1965 BJ8 for sale Austin Healey Classifieds 0
M Getting behind the dash on BJ8 Austin Healey 4
J BJ8 flywheel take some pounds off Austin Healey 17
Keoke 1966 AH BJ8 on eBay Austin Healey 18
L BJ8 Batteries Austin Healey 8
pkmh Front Spring Removal For BJ8 Austin Healey 8
M Wanted Bj8 left front wing Austin Healey Classifieds 3
B BJ8 door hinges Austin Healey 7
BJ8Healeys For Sale BJ8 engine for sale Austin Healey Classifieds 0
B Wanted BJ8 door hinges Austin Healey Classifieds 0
H Wanted BJ8 Jack and complete Tool Kit Austin Healey Classifieds 0
HealeyPassion FYI - AH BJ8 super car for sale Austin Healey 3
S For Sale 3000 BJ8 Laycock 4 speed with 22% OD trans & 2 6 cyln engines / long blocks / BUNDLE Austin Healey Classifieds 1
G BJ8 Spare Wheel 'Blocks' Austin Healey 3
