TR2/3/3A Cutting the finish end on the windshield top rubber
sp53
Cutting the finish end on the windshield top rubber, has anyone figured out a repeatable way to cut the rubber where it tucks in behind the upright and the flat piece. Every time I do the cut on the rubber, I use bad language and snip and pray and usually it goes well. But, ever time the job feels like I should be doing this different because there is only so much material. There has to be a cool way. ideas?
steve
James A Martin
Bronze
Steve:
See if this will work...
britishcarforum.com/bcf/showthread.php?85673-TR3-Windshield-Rebuild-and-Assembly-Step-by-Step
Copy & paste in your browser...
Jim
CJD
I slide the rubber inward as much as possible, compressing it together. that way even if my cut is off a bit it compresses back outward. In other words my finished seal is still a bit too long in the end so it holds tight on the ends.
S
sp53
I installed the top rubber and wanted to mention leave about Âľ of an inch of the little piece ÂĽ inch wide strip that fits in the channel. The piece will be out of sight and be pinched between the frame and upright to help hold the seal on the end in place after the angle cut.
Jim_Gruber Bugsy IV - Painting, Cutting, Buffing is done Spridgets 20
RAC68 Cost of Cutting Down an American Rear Austin Healey 12
55modified Wanted Wanted rough BN1/2 hood for cutting up Austin Healey Classifieds 0
Rut Cutting disc caution Spridgets 8
Got_All_4 Wedge 1980 TR7 PI cutting out Triumph 4
T TR4/4A New switch plinth - cutting holes Triumph 8
T TR4/4A Cutting an access panel into transmission tunnel cover for solenoid adjustment Triumph 13
B MGB MGB tachometer erratic, engine cutting out.... MG 11
B TR6 'Cutting-down' a TR6 distributor ? Triumph 26
Willie_P Triumph cutting coil springs?? Triumph 36
RickB Midget w Datsun running gear cutting out suddenly Spridgets 19
TR_JOE250 TR6 Cutting up TR6 for body panels Help! Triumph 5
Tabcon Cutting out eyebrows on the cylinder liners? Racing 1
S Metal Cutting Restoration & Tools 9
ronzet So, OK, Cutting corners.... MG 17
C 1500 electrical cutting out Triumph 18
Bruce_B Cutting the car for a dual MC setup hints/tricks? Spridgets 23
T need a cutting oil Triumph 16
spiny Tips needed on cutting out and replacing sills Spridgets 32
G Cutting out floorboards with a RotoZip tool..... Triumph 34
David_DuBois Cutting back on coffee MG 7
D Engine cutting out Spridgets 17
Michael Oritt Fuel pump circuit cutting out on start up Austin Healey 40
mondialo64 TR4/4A TR4 Body cutting oversize mags Ideas? Triumph 9
A Cutting S.S. Braided Hoses Triumph 4
B For Sale 57TR3 Small Mouth with OD Project. 12 yeqrs running. I'm not going to finish Triumph Classifieds 0
Rob Glasgow Boot Liner Edge Finish Austin Healey 11
R Ceramic Finish Austin Healey 3
AH67 Heat Shield finish 66 Type Jaguar 5
R TR2/3/3A Crinkle/Wrinkle Finish Triumph 4
Sopwith_Camel dead at the finish line Spridgets 10
D coil spring finish Austin Healey 5
L GT6 correct finish Triumph 5
Rut TR4/4A Defrost vent finish Triumph 3
S TR4/4A How to finish dashboard? Triumph 19
RJS TR4/4A Exhaust Manifold - Most Durable Finish? Triumph 4
Sarastro TR4/4A What kind of wood and finish for the dashboard? Triumph 20
Csarneson Exhaust Manifold finish? Austin Healey 18
D TR2/3/3A Wheel Finish Triumph 26
M What is the finish Jaguar Uses on Veneered Trim Pieces? Jaguar 4
W TR6 Dashboard Recommended finish Triumph 5
Rut TR4/4A TR4a dash finish Triumph 8
Rut TR4/4A Color/finish Triumph 11
TulsaFred Bugeye garage paint job - start to finish [almost] with lessons along the way Spridgets 28
Got_All_4 General TR How can I remove the finish on this center console for my 7 Triumph 9
B BN4 Dash Face Finish Question Austin Healey 15
chicken So i have the bits of the Jigsaw - How do i finish the car ? Austin Healey 15
Jim_Gruber Not LBC but British Car Related - Bathhurst 1000 finish- worth a look Spridgets 3
S BJ8 Air Cleaners - correct finish? Austin Healey 21
K TR4/4A Wood Finish on 4A Dashboard Triumph 9
