My wife's 3000 died over the weekend. On initial investigation it cranked fine and had a spark but empty fuel bowls.
When I turned on the ignition I did not hear any ticking from the SU (her car came with one of the double-headed models) so I checked the circuit to it--test meter showed 12 volts. I disconnected the fuel supply line--The pump would give one gasp and emit a short burst of fuel when the ignition switch was turned on and no more. Same thing when I turned the switch off-one click and that was it. I removed the pump and checked it on the bench--same deal.
I went to the NAPA store and bought a FACET pump. Checked it on the bench and it was fine. I wired and plumbed it in and with the ignition switch turned on it clicked away and apparently pushed fuel to the engine. However, whenever I start the engine the fuel pump dies--I can feel it stop clicking at the same time that the green "ignition warning" light goes off--and within a minute or so the engine dies for lack of fuel. I can also see that the fuel is not being pumped into the transparent inline fuel filter.
When I turn the ignition switch off and then back on the fuel pump energizes and keeps on ticking (less intensely once the system is pressurized) but as soon as I push the start button and the engine fires over the fuel pump switches off and does not come on until I turn the ignition off, then on, etc. etc.
Here are some other observations:
1. If I wire the pump directly to the battery there is no problem. The pump runs with the engine off or on. I can see fuel being pumped into the transparent fuel filter. Everything is fine.
2. When I run a test light to the fuel pump power lead it lights when I turn on the ignition switch, blinks or dims a bit during starting (never really goes out), and stays lighted when the engine is running (this with the fuel pump wired directly to the battery as in #1 above.)
3. When I attach a test meter to the fuel pump power lead the voltage is around 12 with the ignition switch on and the engine off. On startup the voltage goes up to 13+ (it's an analog meter and I'm testing on a 50 volt scale so I cannot get precise readings.)
Best I can tell something is kicking the fuel pump off when the engine starts up but I am lost. I have an alternator if that is important. The pump is wired for negative ground.
Any suggestions will be appreciated.
