Re: {TR6 Clutch Pics}. Whats wrong with this pict
Hi again,
Frankly, I doubt it's a stuck driven plate, because that usually locks everything up and you won't be able to drive the car at all.
You drove the car home, right? A pretty long drive at that. And the shifting problem was sudden, the next day, when the engine was cold. And you simply can't shift into any gear at all, right?
Because it was working initially, I'm guessing it's not a problem with mis-matched parts or anything like that.
This also leads me to believe that there isn't oil on the driven plate, inspite of how it looks inside the bell housing. That would usually cause the clutch to start slipping, not prevent you from shifting into gear. The one exception might be if oil caused the friction material on the driven plate of the clutch to swell up a lot.
The symptoms lead me to believe something is broken, which would most commonly be the taper pin.
Since that's okay, I'd look for something else that broke suddenly, such as the release springs on the pressure plate. Or, it could also be elsewhere in the actuating linkage, such as the clevis pin. Or, the TO bearng mgiht be hanging up on something.
Perhaps its not the clutch at all. It might be a problem with the shift lever on the gearbox (this would likely be obvious).
Have you checked the oil level in the gearbox? Insufficient oil might cause a problem (and it looks like it's leaking out).
Worst case, something is broken inside the gearbox itself. However, there the most likely things would effect one or two gears, not likely all of them (and reverse). Still, it's possible. Is there a drain on the gearbox to allow you to check for any metal particles or bits in there? If not, the top cover isn't hard to remove, to allow a peek inside, but you will at least need a new gasket to reassemble it.
Have you asked the seller if any very recent work was done on the car? If so, what was done? Something might have "slipped" or come loose.
