I'm in the process of rebuilding the steering assembly on my 62 TR3B. I've replaced the idler arm, and will also replace all the tie-rod ends and I ran into a problem when I tried to install new silentbloc bushings in the center tie-rod assembly. I had an automotive machine shop press out the old bushings and when they tried to press in the new silentbloc bushings in the center tie-rod, they would simply slip in by hand. The new bushings are several thousand's of an inch smaller. I purchased them from Victoria British which is only a couple miles away from where I live. Is it possible there is a quality control issue with the bushings from them,(being manufactured to the wrong size)? I don't believe they make these in any other size. The car is original, and these bushings, as well as the rest of the front suspension, has never been overhauled.
Thanks,
Don, 1962 Signal Red TR3B
Olathe, Kansas
Thanks,
Olathe, Kansas
