TR2/3/3A TR3 steering coulmn install
griff
I just installed piece number two of the split column and slid my steering wheel on and I need clarification.
As it sits now I can see a small amount (perhaps an inch) of the column between the base of the steering wheel hub and the column tubing,
Is that correct or should the hub and outer tube meet.( I don;t see how they can since I have the uper and lower section connected properly with the coupler.)
Advice please.
Griff
TR3driver
Great Pumpkin - R.I.P
That's certainly not the way mine was. There is a bit of a cavity on the back of the hub, and the outer tube extends slightly into that cavity so the shaft is not exposed at all. The tube doesn't actually touch the hub, but the clearance is pretty tight.
However, there is some shaft exposed between the outer tube and the coupler. If you are certain the coupler is fully in place on both shafts (so both locking bolts pass through the notch on the shafts), then I think you need to loosen the clamps and slide the upper tube higher until it almost meets the hub.
BTW, the clamps should go out Monday.
Geo Hahn
griff said:
...As it sits now I can see a small amount (perhaps an inch) of the column between the base of the steering wheel hub and the column tubing...
Not exactly clear what you are seing, but here is what mine looks like:
Mkutz
I'm with TR3driver; on the coupler, make sure you completely withdraw the bolt before inserting the column. There is a divet on the column which will line up with the bolt when correctly seated. If it is already correctly seated, loosen the brackets under the dash and on the firewall and gradually slide the column tube toward the steering wheel.
G
griff
I have the coupler installed with bolts dropped through the divits and with everything on the column loose, I am unable to move it toward the hub. It appears the bushing on the coupler end stops the tube from sliding at a ridge/lip in the shaft.
I am going over everything again this morning to double check. If I am unsuccessful, I will take a couple of pics and perhaps a measurement or two(who knows maybe the P/O shortened the upper tube and redrilled the holes for the bushing numbs due to corrosion or something
Thanks guys and thanks Randall for the brkts.
Griff
G
griff
OK, now I feel a bit stupid. Upon re-examining the column where I mentioned there was a ridge preventing me from sliding the tube further toward the steering wheel hub. Well as it turns out it was the remains of the metal portion of an old bush. apparently when I cleaned the column up it was smooth and neat as to look like part of the column so I thought nothing of it.
Anyways, I cut through it gently with die grinder, put a new bush on and everything is good to go. Slid right up to the wheel.
Thanks
Griff
martx-5
For sure. I've done my share of bone headed things. Just chalk it up to experience and the learning process.
K TR2/3/3A Non Adjustable TR3 Steering Wheel Triumph 7
T TR2/3/3A Is there a Delrin bush available for the top of TR3 steering column instead of felt? Triumph 8
T TR2/3/3A Seeking advice on how to repair TR3 steering wheel broken spoke. Triumph 8
B Wanted Need '58 TR3 adjustable steering set up Triumph Classifieds 4
C TR2/3/3A Installation of stator tube in steering column 1957 TR3 Triumph 2
Tinkerman TR2/3/3A 1960 TR3 A Additional steering question Triumph 4
Tinkerman TR2/3/3A 1960 TR3 A Steering wheel play or Lash Triumph 2
M TR2/3/3A TR3 Steering lockstop set Triumph 4
M TR2/3/3A One more steering question TR3 Triumph 4
Tr3aguy TR2/3/3A Need TR3 bits for steering support!!! Triumph 18
M TR2/3/3A TR3 Steering box rocker shaft and drop arm Triumph 5
O TR2/3/3A TR3 Steering Wheel Hub / Control Head Triumph 1
B TR2/3/3A TR3 Steering wheel restoration Triumph 4
O TR2/3/3A TR3 Steering Wheel Swap Triumph 1
T TR2/3/3A TR3 steering wheel and indicator Triumph 5
J TR2/3/3A How to fill TR3 steering idler? Triumph 10
luke44 TR2/3/3A TR3 Steering Column Blanking Plate Triumph 18
M TR2/3/3A TR3 Steering Wheel Repair Triumph 5
CJD TR2/3/3A TR3 Steering Wander Triumph 20
TRclassic3 TR2/3/3A TR3 Steering groan Triumph 6
M TR2/3/3A TR3 steering column mounting question???? Triumph 2
R TR2/3/3A TR3 Front Suspension and Steering Triumph 12
ekamm TR2/3/3A Tr3 steering box end plate Triumph 8
ekamm TR2/3/3A Tr3 steering rocker shaft bushing Triumph 1
ekamm TR2/3/3A Tr3 steering gear box removal Triumph 6
ekamm TR2/3/3A tr3 steering colmn felt bush Triumph 5
B TR2/3/3A 57 tr3 steering box Triumph 3
ekamm TR2/3/3A Tr3 steering rebuild Triumph 2
T TR2/3/3A TR3 steering column bracket Triumph 5
S TR2/3/3A Tr3 steering box olive Triumph 9
T TR2/3/3A tr3 steering wheel resto Triumph 5
J TR2/3/3A tr3 notchy steering in parking lots Triumph 12
mountainman TR2/3/3A TR3 Hard Steering Question Triumph 16
T TR2/3/3A TR3 steering column/bad post Triumph 14
T TR2/3/3A tr3 steering box drop arm nut torque setting? Triumph 2
T TR2/3/3A yet another TR3 steering box question/hone? Triumph 9
H TR2/3/3A TR3 Steering Box Removal Triumph 11
Tinkerman TR2/3/3A Another Steering Box Question TR3 Triumph 4
J TR2/3/3A Rack and Pinon steering for TR3 at MOSS Triumph 1
E TR2/3/3A TR3 Steering rack conversion Triumph 41
A TR2/3/3A TR3 steering wheel support Triumph 10
newmexTR3 TR2/3/3A Separating Tie Rod Ends from Steering Arms TR3 Triumph 18
A TR2/3/3A TR3 steering box rebuild Triumph 4
J TR2/3/3A tr3 steering box leak Triumph 3
K TR2/3/3A TR3 Steering:Nut that attaches drop arm........... Triumph 2
K TR2/3/3A TR3 front end..mounting wishbone near steering box Triumph 9
TR4nut TR2/3/3A Blanking off the spare steering hole on TR3/3A? Triumph 7
M TR2/3/3A TR3 Steering: Penrite v. Snythetic Triumph 4
newmexTR3 TR2/3/3A TR3 Steering Box Rebuild Service? Triumph 10
S TR2/3/3A tr3 steering Triumph 38
