MGB Installing steel dash into early 70's MGB
GTsRFine
Other than the steering column cowl, what other fit-up problems can I expect when using a '67 steel dash in a 73-74 MGB?
tony barnhill
Great Pumpkin - R.I.P
G
GTsRFine
Thanks Tony. Hmmm... daunting.
Wiring - no problem. I intend to rewire everything anyway with custom wiring.
The console is history. I never liked it anyway.
The rest sounds like the tough part....
Underdash support bar... hmmm I might can extend the windshield cowl to move the dash out a bit. I've never liked the limited space behind the dash. Since I'll be moving the dash out, the support bar can move out with it.
Ugh - it's going to be a full fabrication rework. I guess I better save this idea for the "dream" car.
Edit - just noticed your URL for your article. I knew I had seen that somewhere.
Looks like you modified your 70's car to fit the early dash. I was sort of thinking of going the other way -> modifying the steel dash to fit the 70's car. Got any thoughts on that?
tony barnhill
David - never thought of it because of the curve of the '70's windshield cowl...you'd have to 'bend' the dash.
tony barnhill
When you coming this way again?
vping
Bronze
I've got a friend here that wants to convert a RB to a CB car and a steel dash. I've got a 67 donor I am cutting up for him. I hope he is up for the challenge.
LCVDriver
I know over in England when they import a padded dash car from the States and convert it to RHD, they weld in a panel on the dash top (or a complete new shroud panel part # HZA480) to get the dash back aft and away from the windshield where it's supposed to be. Not sure if someone over there manufactures a small panel to do that?? They may just fabricate a piece or use the full shroud.
FYI.
bob
DJThom
I'd like to do this modification also, but it is very daunting. Perhaps a winter project some year down the road. Someone sold a complete dash all switches, hardware, steering column, gauges etc.
https://cgi.ebay.com/ebaymotors/ws/...item=150231200932&_trksid=p3984.cWAT.m240.lVI
No telling if the gauges etc were in good working order or condition of chrome bits etc so I took a pass.
Maybe I should just focus on my existing project and at least try to get the car back on the road before this summer is over
bighealeysource Installing stainless steel brake hose on BN2 Austin Healey 5
bighealeysource Installing new stainless steel beading on BN2 Austin Healey 4
bighealeysource Installing front fender stainless steel beading Austin Healey 4
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
S Installing a Radiator Fan Austin Healey 9
G Installing New Rocker Shaft Assembly Austin Healey 3
W Need advice on installing new side curtain glass Spridgets 1
Bayless Help please installing bonnet release cable Spridgets 8
M TR6 Installing Retrosound? Triumph 4
S TR2/3/3A Installing the distributor pedestal. Triumph 3
K TR2/3/3A Question about installing the steering wheel control head? Triumph 1
A TR6 Installing differential and transmission Triumph 10
Z Installing Toe Board Panels Austin Healey 1
K TR2/3/3A Installing Brake Caliper pistons into the bore? Triumph 21
CJ Burton MGB-GT Installing Seat Covers for 1962 - 1967 MGB GT MG 0
A Early 1967 AH Sprite - installing steering column and new directional switch? Spridgets 0
B Installing cam bearings 1275, can I do it? Spridgets 1
steveg TR6 Installing stock trailing arm bushings on the car - is it possible? Triumph 2
steveg TR6 Installing adjustable trailing arm brackets Triumph 7
T Installing Garmin GPS in a BJ7 Austin Healey 19
F Installing AC in my 1960 Healey Austin Healey 14
S TR2/3/3A technique for installing a door Triumph 5
R TR2/3/3A Installing wiring harness in steering column Triumph 59
R TR2/3/3A Installing gas tank Triumph 6
C Installing rubber grommets in firewall? Austin Healey 6
S TR2/3/3A installing a fuse in the red tail lights Triumph 4
S TR2/3/3A installing the wiring harness Triumph 8
R Installing Sprite Luggage Rack Spridgets 9
Lukens TR2/3/3A Installing a throttle. Triumph 2
J Powertune booster for a bj8 , trouble installing Austin Healey 2
B TR2/3/3A Installing dzus fastners in bonnet Triumph 8
D Prepping Floors Before Installing Interior Restoration & Tools 6
drooartz Installing front hubs, tips? Spridgets 15
E TR4/4A Wiring the horn when installing a Moto -Lita steering wheel Triumph 4
K TR2/3/3A Installing Moss wheel spacers? Triumph 5
D BT7 tri-carb installing my crank Austin Healey 4
aero3113 Installing Front rotors to hubs Austin Healey 2
C Advice for installing a 3000 Grille??? Austin Healey 7
B MGB Installing new upper fulcrum bushings MG 5
B MGB Installing upper fulcrum bushings MG 0
S TR4/4A procedure for installing gauges etc Triumph 0
I Tips for installing intake manifold plugs in a stock Bugeye? Spridgets 6
55modified Help installing toggle dip switch on dash for lights. Austin Healey 23
TRMark TR4/4A Installing a new windscreen Triumph 9
55modified Rear anti-roll bar. Is it worth installing on a BN1? Austin Healey 22
T Installing a Lucas 16 ACR alternator on Bugeye Spridgets 10
KVH General Tech Installing the Pistons and Rings Triumph 7
T Need advice for installing a Winner's Circle Panhard rod on a BE Spridgets 4
6 General Tech Installing New Oil Pressure Gauge MG 5
6 Installing Oil Pressure Gauge Spridgets 2
