Brakes are working fine apart from a pull to the right under heavy braking but even that's not noticeable under normal driving conditions.
The one thing i am finding though, is that i can hear a sort of double "Click" noise when applying the brakes - and the clicks are at the start of application and about 0.25 of a second apart.
They seem to be only coming from the front right but maybe that's because I'm closes to that wheel. i did have some squealing coming fromt he front right a while ago but that sorted itself out.
Worn pads? Caliper bolts loose? not sure what's going on and I haven't had a look under there yet but as ever I thought I should consult the Oracle.
Bob
Bob
