Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: Noise from clutch area?
  1. #1
    Join Date
    Sep 2015
    Location
    Michigan USA
    Posts
    98
    Thanks Thanks Given
    Thanks Thanks Received
    1
    Thanked in
    1 Post
    Suddenly hearing a noise from the clutch area on my 3A. Sounds like water running under pressure. Only happens when the clutch pedal is depressed. Any ideas? Time for a new throwout bearing? I tried to capture it:
    https://drive.google.com/open?id=1-F...DCBHiYQU13FHEJ
    60 TR3A TS66043
  2. #2
    Yoda CJD's Avatar
    Join Date
    Feb 2011
    Location
    Arlington, TX, USA
    Posts
    5,354
    Thanks Thanks Given
    6
    38
    Thanked in
    Re: Noise from clutch area?
    Did you change the fluid in your tranny recently?
    John
    1955 TR2
  3. #3
    Yoda TOC's Avatar
    Join Date
    Jun 2008
    Location
    Floe Ice, Antarctica
    Posts
    6,246
    Thanks Thanks Given
    20
    Thanked in
    why would the type of lubricant inside the transmission show up as a noise when the clutch pedal is depressed?
    Carbon T/O bearing still?
    Starts as soon as you press the pedal and take the free-play out, or does it start when pedal is almost fully depressed?
    T/O for first, pilot for second.
    Generally.
    Speakers on this Toshiba not qualified to discern the subject of the link.
  4. #4
    Join Date
    Sep 2015
    Location
    Michigan USA
    Posts
    98
    Thanks Thanks Given
    1
    Thanked in
    1 Post
    Quote Originally Posted by CJD View Post
    Nope. TBH I'm not sure I've ever changed it. I check it once in a while.
    But the noise happens when I step on the clutch, so the trans is not moving. No noise when I let the clutch out.
    Also, it doesn't matter if the car is moving or not. The video was with the car not moving.
    60 TR3A TS66043
  5. #5
    Join Date
    Sep 2015
    Location
    Michigan USA
    Posts
    98
    Thanks Thanks Given
    1
    Thanked in
    1 Post
    Quote Originally Posted by TOC View Post
    What do you mean?
    Not sure about that. I'll have to try it again.
    60 TR3A TS66043
  6. #6
    Join Date
    Sep 2015
    Location
    Michigan USA
    Posts
    98
    Thanks Thanks Given
    1
    Thanked in
    1 Post
    I just changed the permissions on the video file if anybody had trouble accessing it. Hopefully you can see it now. Sorry about that.
    60 TR3A TS66043
  7. #7
    Yoda CJD's Avatar
    Join Date
    Feb 2011
    Location
    Arlington, TX, USA
    Posts
    5,354
    Thanks Thanks Given
    6
    38
    Thanked in
    Definitely the throwout bearing. In the early stages the noise may come and go. Towards the end it will get constant and louder. If it were mine, I’d put it on my long term “to do” list. It could go for a year or more before getting serious.
    John
    1955 TR2
  8. #8
    Join Date
    Sep 2015
    Location
    Michigan USA
    Posts
    98
    Thanks Thanks Given
    1
    Thanked in
    1 Post
    Thanks. I'll probably make it my winter project for this year.
    60 TR3A TS66043
  9. #9
    Jedi Trainee Graham H's Avatar
    Join Date
    Feb 2018
    Location
    Perth Western Australia
    Posts
    234
    Thanks Thanks Given
    2
    6
    Thanked in
    Definitely need to change the T.O bearing, I wouldn't go too far from home until you do.
    [SIGPIC][/SIGPIC]
  10. #10
    Join Date
    Nov 2004
    Location
    washington state
    Posts
    3,316
    Thanks Thanks Given
    29
    Thanked in
    The question now is do you want pull the trany out from the top or pull the engine and trany together. Kinda depends on how nice the car is if you want to remove the apron or the seats. The car looks nice from what I can see, and then I would probably pull the seats. That bearing sound wore out. If it only made a little noise in neutral sitting, I would wait, but that is heavy metal.
    steve
  11. #11
    Join Date
    Oct 2018
    Location
    Livermore, Ca
    Posts
    179
    Thanks Thanks Given
    8
    Thanked in
    If you can get some lub. to it it might last a year longer.
    Dumb comment...."your tach is on the right, mine is on the left." Was that intentional ?
  12. #12
    Join Date
    Sep 2015
    Location
    Michigan USA
    Posts
    98
    Thanks Thanks Given
    1
    Thanked in
    1 Post
    Quote Originally Posted by STeve 1958 View Post
    Would pretty much have to pull it to get lube to it, wouldn't I?
    Tach is where it was when I got the vehicle. No idea which is correct. Don't trust the PO further than I can throw him though.
    Edit: for fun I just looked at Bill Piggots book. He says the speedo is "usually" on the left, but sometimes they were reversed. So I guess both are correct.
  13. #13
    Join Date
    Aug 2010
    Location
    Strafford, NH
    Posts
    1,716
    Thanks Thanks Given
    8
    12
    Thanked in
    Quote Originally Posted by sp53 View Post
    steve
    The seats usually come out without protest. If the 3 screws on the bottom of the rails won't come out, take the bottom cushions out and unscrew the nuts that go on the studs that come up through the pans. IMO the transmission comes out easily this way and goes back in with some difficulty but usually not too much. And that's if it doesn't have an overdrive. If it does, I'd look for a strong helper or consider the engine/transmission option. (I've seen some engine cranes modified to lift the thing in the confined space under the dash)
    The front apron is not difficult to remove as long as the bolts and nuts are not rusty but it's a challenge to remove and replace the apron without scratching or bending something. And you also have the exhaust, electrical, fuel and cooling systems to deal with. Far better if you can get it out through the inside.
    Tom
    1960 TR3A TS73117 (under endless restoration, owned since 1964)
    1959 TR3A TS58023 (in case I never finish the one above)
    1969 Triumph Herald 13/60 (a whim)
    1970 Lotus Elan Plus 2 /0023/N
    1992 BMW325IC (fun to drive)
  14. #14
    Join Date
    Sep 2015
    Location
    Michigan USA
    Posts
    98
    Thanks Thanks Given
    1
    Thanked in
    1 Post
    Quote Originally Posted by TomMull View Post
    Tom
    I agree. I will go at it from the inside. I've had the apron off twice but it's a job.
    My big worry is the condition of the floorpans and rockers when I get the carpet out. The PO did a rather slapdash "restoration" which I have been turning a blind eye to in order to keep it on the road. I know there's some fiberglass in there. And some wood.
    60 TR3A TS66043
  15. #15
    Join Date
    Nov 2004
    Location
    washington state
    Posts
    3,316
    Thanks Thanks Given
    29
    Thanked in
    I can dig that--- honesty is great thing. I am going to put some por 15 down on this one because it is an all-weather driver.
  16. #16
    Join Date
    Feb 2016
    Location
    Macon Georgia
    Posts
    2,704
    Thanks Thanks Given
    12
    41
    Thanked in
    Having just acquired an OD transmission I am faced with the decision change from inside or out the front. Being on my own I will probable go out the front.
    David
    TR3A TS75524L
  17. #17
    Join Date
    Feb 2018
    Location
    Posts
    234
    Thanks Thanks Given
    2
    6
    Thanked in
    David,
    I changed my gearbox on my own using my lifting bar but you may need to take the steering wheel off I don't have that problem because all the controls are on the right-hand side of my car. If you go from inside don't forget to tie the clutch lever forward to the bell housing because it tends to get caught on the floor turn up when putting the box back in.
    Graham
    [SIGPIC][/SIGPIC]
  18. #18
    Join Date
    Aug 2010
    Location
    Strafford, NH
    Posts
    1,716
    Thanks Thanks Given
    8
    12
    Thanked in
    Clever arrangement Graham. I flipped the image below:
  19. #19
    Yoda CJD's Avatar
    Join Date
    Feb 2011
    Location
    Arlington, TX, USA
    Posts
    5,354
    Thanks Thanks Given
    6
    38
    Thanked in
    For just the throwout bearing I found going from the inside to be the lesser work. The tunnel is easier to remove than the apron.
    The early speedos were on the left in the US. Later they moved the speedo right so the navigater could see it in road rallying.
    John
    1955 TR2
  20. #20
    Join Date
    Nov 2004
    Location
    washington state
    Posts
    3,316
    Thanks Thanks Given
    29
    Thanked in
    I have pulled them and reinstalled them myself from the top. I used simple come- a –long from the rafter as close to balance point of the trans as I could it and that took up a lot of the weight, no od. Sometimes you will need to unhook the exhaust at the engine to let engine down some in the back and naturally support the engine somehow. I would not trust a hydraulic jack long, so I use a scissor jack to lower and raise the engine in the back.
    Today I would get some help probably, but back in day I would crawl under the car and lift and fettle with most the tail shaft looped and balanced at the come-a- long. Or make one of those cool deals like Graham has, but did not about that then.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
