Solid Sway Bar bushing mounts
They cause the sway bar to transmit more force from one side to the other with no loss of energy. However, you will end up with much more road noise, and you are more likely to rip the mounts loose from your A arms. I do not think they would be adviseable for a road car.
T
TommyMG
Member
Thanks for the reply.
I thought they were a bit overkill myself but wanted to ask the knowledgeable ones here.
V For Sale Hard Top and Solid Walnut Dash for Sale Triumph Classifieds 2
KVH General Tech Rear Brakes and Solid Axle Triumph 2
T Wanted Looking for a solid [but doesn't have to be perfect] 100-6 Austin Healey Classifieds 17
C AUF214 solid state conversion question British Motor Corp 0
R Solid state SU Fuel Pump Austin Healey 2
D TR4/4A Seals on TR4 Solid Rear Axle Triumph 5
KVH TR4/4A Removing Rear Differential Seal--Solid Axle Triumph 1
T TR4/4A Differential clatter-solid axle Triumph 4
Popeye TR4/4A TR4A solid axle rear leaf spring question Triumph 14
N Spitfire Question on solid steering rack mounts! Triumph 3
BobbyD New OD Controller & Solid State Rheostat Triumph 0
richie TR4/4A Wheel fitment on TR4a solid axle vs IRS Triumph 6
T TR4/4A Refreshing solid axle TR4a rear bushings Triumph 4
T Tvr 2500m For Sale, Nice Original Solid Example. TVR 1
Stinger TR4/4A TR4A Wood Dash Plywood or Solid Wood Triumph 13
coj Solid state turn and brake box Austin Healey 7
V Solid state fuel pump question Spridgets 2
T TR4/4A Which TR4a is better - IRS or solid axle? Triumph 30
hymodyne rubber, poly vs solid steering rack bushings Triumph 12
PAUL161 Solid Throttle Disk for HIFs MG 7
Banjo TR4/4A TR4A solid rear axle, axle. free Triumph 8
M Solid state conversion of Lucas regulator Triumph 9
bighealeysource Noisy solid state fuel pump Austin Healey 15
T GT6 GT6+ - could be a solid car Triumph 22
J TR4/4A TR4A Solid Axle Rear Brake Backing Plates Triumph 17
MGTF1250Dave Solid State Voltage Regulator Up-date Triumph 7
MGTF1250Dave Solid State Voltage Regulator Conversion Triumph 9
BugEyeBear Nice Solid BugEye on eBay [not mine...] Spridgets 8
Morris Solid core wire Spridgets 6
vping Installing a Solid State Fuel Pump MG 7
J TR4/4A TR4A solid axle assembly Triumph 15
B solid looking project for someone Spridgets 7
B MOSS solid state fuel pump Spridgets 3
ronzet Flame Thrower solid state distributor for my A MG 12
B solid bronze TW Spridgets 1
vping Anyone use a solid state fuel pump? MG 35
6 Solid State SU Fuel Pump Ticking: Constant? Austin Healey 4
T TR4/4A 4A IRS tub on 4A solid axle frame? Triumph 2
Westfield_XI Solid mounted Spridget transmission Spridgets 0
T TR4/4A TR4a [solid axle] rear twitch-iness question Triumph 15
D E-type solid rack mounts? Jaguar 6
Banjo TR4/4A TR4A solid axle rear end for sale Triumph 0
racing girl How Many Of You Use A Solid Neck/Shoulder Brace? Racing 3
M Solid color or 2 tone paint Austin Healey 8
Banjo TR4/4A Soon to be parting a TR4A solid axle Triumph 1
beaulieu solid wheel knock-offs , do they exhist ? Restoration & Tools 11
AUSMHLY Su Solid state fuel pump Austin Healey 26
3 Solid vs. poly vs. stock rack mounts. Triumph 10
R rusty but solid seat bottom Spridgets 4
Basil Seriously considering solid stainless cylinders Jaguar 9
