I had a Facet pump in my car for a while... it was one of the resin body design pumps. It was noisy as all heck! If I ran the fuel out (only happened once!), the pump sounded like a jack hammer in the boot. I did my best to isolate it with neoprene padding between it and the mounting surface, but it was always too loud IMO. Also, it did not solve the issue I thought it would (I thought I had a vapor locking issue).
This past year, after switching my ZS carb for a HS6 that Doc graciously donated to my cause, I also decided to switch back to the stock SU that came with the car. So, I purchased all the necessary components to mount the pump in the original stock location (body sticking through a hole in the trunk), rebuilt the pump, and switched over. In the stock location for my '76, the SU's ticks are almost inaudible before starting the engine.
