Anyone use a solid state fuel pump?
vping
Bronze
I've heard about them and seen them in the Moss catalog. Anyone have any experience with them and can you get them at a Pepboys or something rather than Moss? I'm thinking about putting one in my 74 which will be a daily driver.
What is the flow rate of a stock SU pump?
Steve_S
They're noisy so you need to insulate them. They are also quite reliable but if they do go out, they do it like all modern components - without warning. I use SUs in all my cars except the GTS which has different requirements than stock.
The stock pump for your '74 should pump roughly 2.4 pints per minute.
David_DuBois
Vince - The standard AZX 1300 series fuel pump (either points or all electronic ) for the MGBs is 2.2 pints per minute. The all electronic pump works essentially the same as as the points type pump, but uses a Hall effect circuit to trigger the pump instead of points on a throw over toggle. The advantage of the all electronic pump is that there are not points to film over during periods of disuse. If the car is used regularly, there is not real advantage of the all electronic pump over the points style pump. I have a pump on our MGB with the Burlen Fuel Systems all electronic circuit installed. I put their circuit in a pump that I had to see how well it operated and have found that it works real well. that said, my own circuit works well also. If you have an old pump, I can restore it and modify it to solid state for less than the cost of the all electronic pump through the normal source. You will not find any kind of SU fuel pump at Pepboys or any of the other discount auto parts houses. You can order on from Little British Car Co. https://www.lbcarco.com/ an get about a 15% discount, or you can order one directly from Burlen Fuel Systems in England https://www.burlen.co.uk/ but I'm not sure that the cost is any better after figuring in shipping.
Cheers - Dave
aeronca65t
Most of the noisy, square, electronic fuel pumps are made by Facet. I have one in my racer. Very reliable and noise doesn't matter when you have open exhaust and wear ear plugs and a helmet.
Facet is making new-style, quieter, round-shape pumps that are suppposed to be more suitable for street cars.
Your car should not need more than 3 psi of fuel pressure, so most aftermarket pumps require a regulator (I like the Holley regulator sold by Summit.
~Click Here~ to see some of the newer Facet pumps.
Platinum
I just installed a solid-state SU double sided one into a V12 E-Type a week ago. It seemed quieter than the POS plastic fake it had before. Not sure whether it's noisier than a points type one. Frankly I ~like~ hearing the tick-tick... reassuring AFAIC. /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
1965_MGB
I'm not a big fan of the square pumps, but if you are going to use one, get it locally. Ordering one of those pumps from the catalogs is rather expensive compared to what can be paid locally. If you can find one cheap, buy two, and keep the spare in the car for when the first pump quits. Like is said above, make sure you get the low pressure pump, that way you won't have to mess with a pressure regulator.
I went through several of them before I rebuilt my SU pump.
David_DuBois
The all electronic SU fuel pumps, single or double ended are slightly quieter than the points style pumps in that they do not have the sharp tick, tick, tick sound (I don't know how to approximate the sound in writing). The familiar tick, tick, tick sound of a points style pump comes from the toggle (on which the lower contacts are attached) hitting on the top of the coil housing and the bottom of the pedestal as it transitions up and down. The all electronic pumps don't have a toggle, so that component of the characteristic sound is no longer there, just the sound of the diaphragm armature hitting against the coil core and that is soften by a thin rubber washer. The result is a slightly softer ticking. You now know more about the sounds produced by SU fuel pumps than you ever really wanted to /bcforum/images/%%GRAEMLIN_URL%%/smile.gif
Cheers,
WA1KWA
I've had the SU solid state fuel pump in my 1974 MGB for over 10 years now, never a problem at all. perfect replacement for the standard SU pump. I highly recommend it.
Colin
vping
vping
Bronze
Dave you have a PM.
vping
vping
Bronze
and to you /bcforum/images/%%GRAEMLIN_URL%%/smile.gif
Great write up and I may go this route.
Nunyas
I had a Facet pump in my car for a while... it was one of the resin body design pumps. It was noisy as all heck! If I ran the fuel out (only happened once!), the pump sounded like a jack hammer in the boot. I did my best to isolate it with neoprene padding between it and the mounting surface, but it was always too loud IMO. Also, it did not solve the issue I thought it would (I thought I had a vapor locking issue).
This past year, after switching my ZS carb for a HS6 that Doc graciously donated to my cause, I also decided to switch back to the stock SU that came with the car. So, I purchased all the necessary components to mount the pump in the original stock location (body sticking through a hole in the trunk), rebuilt the pump, and switched over. In the stock location for my '76, the SU's ticks are almost inaudible before starting the engine.
David_DuBois
Rob - You might want to consider mounting that noisy facet on the back of the passenger side battery box as a permanently mounted back up pump, with a switch for switching power between the two pumps. See my article in the Library under Carburetors and Fuel. You can get regular sound mounts for the Facet pump that will isolate the noise completely.
Cheers,
vping
vping
Bronze
I would think you could mount the facet on grommets to cut down on some noise. Dave do you pumps make any noise so I can tell if it is working? As doc stated earlier, I too like the sound of the pump - it tells me when I'm outta gas /bcforum/images/%%GRAEMLIN_URL%%/smile.gif
Michael Oritt
On the Elva I have two of them installed in tandem with separate switches so I can run either or both. They are diaphragm-type pumps so the first one pumps through the second and the second pulls through the first, etc.
On my 100 I have one mounted inside the rear wheel well, again in tandem with an SU with an "On-Off-On" toggle switch so that I can select between them or shut them both off for a bit of theft prevention.
BTW according to the instructions (who reads them??) they like to be mounted on an upward angle.
David_DuBois
Vince - My modified pumps sound exactly like the original SU fuel pumps because it still uses the original toggle.
When mounting the Facet pumps the mounting screws have to be isolated from the pump or the mounting surface or they will transmit the sound of the pump right into the car. The sound mounts that are available from Pegesus Racing have studs at either end of a rubber isolator, so there is no sound short for the noise to transmit through.
Cheers,
Bugeye58
Vince, the mounts look like this. These are from Aircraft Spruce, and the studs are 8x32. Actually Cessna instrument mounts, in this case.
Jeff
marinmg
Very timely discussion.
I have positive ground electronic SU Solid State Fuel Pump I put in my MGA about 4 years ago and it works great (purchased from moss).
I am looking at converting my MGA to negative ground, (putting in an alternater) but was wondering if there is anyway to rewire the polarity of the SU solid state fuel pump I have? Or would it be easier to purchase the neg ground one and try to sell the positive ground one.
Any info you guys have on this one sure would help.
Thanks,
Liam
57 MGA
David_DuBois
Liam - The pump can be converted to negative ground. If I remember correctly, there is one connection on the circuit board that has to be moved, but without having one in front of me, I couldn't tell you which it is. If somebody has that information, I'm sure they will get back to you. If that doesn't happen, contact me at ddubois@sinclair.net and I'll see what I can do to help you.
Cheers,
Basil Anyone remember Dave Russell? Austin Healey 10
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
AngliaGT Anyone Plan on Attending the SCCA Runoffs at VIR Next Week? Racing 6
R TR2/3/3A Does anyone know the paint Code for british Racing Green for a 1954 TR-2? Triumph 12
Celtic 77 Anyone recall Hobo Hill in New York State? Racing 0
T Rut's 4 speed shifter modification - anyone have knowledge? Spridgets 3
JPSmit Gear reduction starters anyone? Restoration & Tools 5
L Can anyone tell me what car this is from please? Other Cars 0
DrEntropy Show this to anyone under 40... Restoration & Tools 9
K TR2/3/3A Can anyone confirm that if you replace the ammeter with a voltmeter ( generator removed and alternator added) that you...... Triumph 5
D Can anyone identify this vintage car? Other British Cars 17
T Can anyone identify this bumper Spridgets 5
AngliaGT Morgans - Anyone Heard From John Sheally lately? Other British Cars 13
johntennyson Anyone Know These Guys? Or Remember Sprite-Midget Owners' Group? Spridgets 29
K TR2/3/3A Anyone remember the "rattling gear shift" fix? Triumph 8
roscoe Comments, anyone? Austin Healey 3
BillyB62 TR2/3/3A Anyone seen a valve cover like this Triumph 0
T TR2/3/3A Has anyone designed a hand brake warning light for the TR3? Triumph 3
Pythias Sprite Winged Bonnet Badge.... ANYONE? Spridgets 16
B Anyone have a Europa Twin Cam for sale? Lotus 6
B Anyone have spark advance data for Piper camshafts? Spridgets 1
Got_All_4 TR5/TR250 New Hazard Relays Does Anyone know How to Hook Up Triumph 7
steveg TR6 Metal Dash - does anyone make one? Triumph 13
T Powertrain locked up three times whilst driving today - anyone have thoughts? Spridgets 15
S TR2/3/3A Anyone care to share their bondo applying techniques Triumph 35
DrEntropy MGB Clevis pins, anyone? MG 3
69MGC Wanted Anyone know this guy? MG Classifieds 2
B Does anyone still make or sell a quality condenser? Austin Healey 14
W TR6 Anyone add Exhaust tips to standard exhaust Triumph 4
K TR2/3/3A Anyone have a picture of the crankshaft pulley.... Triumph 1
K Anyone racing a TR3? Racing 5
S General TR Can Anyone identify this TR Triumph 3
C Anyone know where to get one of these? Austin Healey 6
Grantura_MKI T-Series MG TD anyone? MG 5
HealeyRick Why Would Anyone Butcher a Healey with a V8? Austin Healey 26
K TR2/3/3A Anyone running NGK spark plugs? Triumph 26
K TR2/3/3A Anyone heard of an oil additive called 'Molyslip E" ? Triumph 5
Basil SS100 anyone? Jaguar 5
Jim_Gruber Recovering Dashboard - Anyone tried this approach? Spridgets 4
T TR2/3/3A Anyone running tubeless radials on TR3 steel radials? Triumph 2
R General TR Anyone going to TRA in North Georgia? Triumph 0
R Wanted Anyone have one of these? Triumph Classifieds 6
mt10flyer TR2/3/3A Anyone race prepped a TR3? Triumph 3
Rut TR4/4A Sorry Top anyone? Triumph 0
Got_All_4 General TR Anyone know where to get one of these? Triumph 5
AngliaGT Anyone in Charlotte,NC That Could Check Out a Truck for Me? Other Cars 0
Gliderman8 TR2/3/3A A nice ORIGINAL TR3A resto project if anyone is looking Triumph 3
Got_All_4 TR2/3/3A Has anyone installed one of these slack limiting plates Triumph 4
