I just purchased this item to install in my Midget. The only paper in the package was a 1/2 sheet of supplemental instructions regarding positive / negative grounding. It does reference a set of instructions containing steps #1 - #12, but these were missing. I had MOSS send the missing instructions, but what they sent was a copy of the supplement.
Can anyone provide a copy (or summary) of the missing instructions? Are there any tricks that I should be aware of? What is the best way to cut the pump into the fuel line, with out setting anything on fire? What is the best way to seal the threads on the pump inlet / outlet? Is there a preferred location for mounting the fuel pump?
There are two lines attached to the tank, on the side facing forward. I assume that the line that I need to put the pump into (the line that feeds the carb) is the lower line.
Thanks for any help.
Bob
Bob
