TR2/3/3A New Control head wiring - Moss purchase
RobbieP
Hello!
Long time reader, first time poster. I've bought a new control head for my 62 Tr3a from Moss. This item here..
https://mossmotors.com/control-head-standard-wheel
Unfortunately the item comes with mismatched coloured wiring to the factory harness. Has anyone already been through the install and can shed some light on the correct colour-to-colour matches? As the wiring on the control head tucks behind the mounting plate, I can't tell where they lead inside the unit.
I must admit wiring and electrics aren't my strong point.
Much appreciated.
Robert
TR3driver
Great Pumpkin - R.I.P
What colors do you have? Usually it's only the wire marked green on the diagrams that is different. I don't recall what mine was offhand, but something like light green with brown.
Easy enough to figure out, if you have an ohmmeter (or multimeter) or a powered test lamp (aka continuity checker).
1) Move the turn signal lever to the right, and use your tester to find which two wires are connected together electrically. Mark those (or note their colors).
2) Now move the lever to the left and check again.
One wire should be common to both positions, it connects to the GN (green with brown) in the harness. This is the feed from the flasher unit near the control box. (On a LHD car, it also goes through a connector near the horns on the RH side.)
The wire that was only connected in step 1) goes to GW, for right turn; the wire that was only connected in step 2) goes to GR for left turn.
The remaining wire is normally noticeably thicker than the other three, and goes to NB for the horns.
Got_All_4 TR2/3/3A Control head wiring help Triumph 11
C TR2/3/3A Control Head wiring Triumph 18
B Another wiring question 57 smallmouth control head Triumph 2
mountainman TR2/3/3A TR3 Control Head Wiring Triumph 11
K TR2/3/3A Who sells steering wheel control head "Allen head'' grub screws? Triumph 5
K TR2/3/3A Inside the horn and turn signal control head. Triumph 3
K TR2/3/3A Question about installing the steering wheel control head? Triumph 1
F Wanted TR3A control head parts (trafficator) Triumph Classifieds 4
71TR6 TR2/3/3A Control Head horn contact Triumph 7
Lin Another Trafficator/Control Head Question Austin Healey 10
B TR2/3/3A Control Head/Stator tube orientation Triumph 8
K TR2/3/3A Turn signal and control head memory refresh..... Triumph 9
K TR2/3/3A Turn Signal Control Head Alignment Again Triumph 1
S TR2/3/3A Horn not working unless I rotate the control head Triumph 6
K TR2/3/3A The 3 Steering Wheel "Grub Screws" and the Control Head. Triumph 2
T TR2/3/3A Is it possible to buy stronger springs for turn signal lever in control head? Triumph 14
T TR2/3/3A Questions on TR3A steering control head refresh Triumph 34
G TR2/3/3A Fitting the Control Head - Telescoping [Adjustable] Wheel Triumph 20
P TR2/3/3A TR3A Steering Control Head Harness Triumph 7
C TR2/3/3A Control Head Rebuild Help Triumph 1
trotti Control head / trafficator questions Austin Healey 14
B Stator/Traficator [Control Head] Question Austin Healey 2
J TR2/3/3A Correct trafficator control head? Triumph 4
K TR2/3/3A The Control Head on the Steering Wheel Triumph 3
Kleykamp TR2/3/3A 1961 TR3 control head. Triumph 5
G TR2/3/3A Control Head How to Repair Triumph 5
G TR2/3/3A Control head Lubricant? Triumph 3
Y Fault in Steering Wheel Control Head in BT7mk1 Austin Healey 3
G TR2/3/3A Control Head Video Triumph 3
R trafficator/control head rebuild Austin Healey 10
luke44 TR2/3/3A Control Head Ground? Triumph 1
Scotsman TR2/3/3A Signal switch on TR3 Horn Control Head not canceling Triumph 20
O TR2/3/3A TR3 Steering Wheel Hub / Control Head Triumph 1
O TR2/3/3A TR3 Control Head Install Triumph 10
O TR2/3/3A TR3 Control Head Stator Tube Install Triumph 5
Superwrench Steering Control Head Assembly Austin Healey 4
Tinkerman 60 TR 3 A Control Head & Steering Wheel Triumph 9
S control head canceller 180 out Triumph 3
J TR2/3/3A TR3A control head question Triumph 4
tmc TR2/3/3A TR3A control head disassembly Triumph 4
DavidChandler TR2/3/3A Tr3A Control Head Triumph 16
K TR2/3/3A Internal view of a tr3 control head Triumph 7
Gordon_Dedrick Control Head Screws Triumph 5
ekamm TR2/3/3A TR3a horn/turn indicator control head Triumph 13
AweMan Control head question Triumph 4
donbmw link to control head rebuild Triumph 5
F TR2/3/3A TR3 Turn Signal/Horn control head Triumph 4
P Steering Control Head Triumph 2
G Adapting adj. wheel control head to non adj. wheel Austin Healey 5
J TR2/3/3A TR3 control head internal pictures? Triumph 11
