TR4/4A Seals on TR4 Solid Rear Axle
Dash
Having trouble trying to get the correct outer most axle seals (what moss is calling a hub seal) for the solid axle on my TR4. My original, including the metal casing that presses into the hub, measures 19/32 thick according to my caliper or reading a regular ruler is about 9/16. Moss is out of stock on those so I'm not sure how thick their seals are but NPNW told me theirs are about 5/16. I've not seen any shims associated with those so I'm assuming all the vendors have replacements that are pretty much the same. For anyone who has used those replacement seals, does that 1/4" make any difference since it presses in??
TR3driver
Great Pumpkin - R.I.P
Seems like there must be some mistake. I just checked a TR3A bearing housing (which is the same P/N as TR4 and certainly looks identical), the cavity for the seal is only .300" deep. The seal I knocked out measures .310", so it stood a bit proud. And I'm fairly certain it's the original seal (P/N 58801, also same as TR4).
Are you sure you aren't looking at the axle seal (58800) instead? The hub seal can only be accessed by removing the hub from the axle, and doesn't actually touch the axle at all. It seals the bearing housing to the hub (hence "hub seal").
PS, the seal thickness isn't critical anyway, the thinner seal would probably work fine. I just think you're looking at the wrong part, which won't work fine :smile:
CJD
I've often run into aftermarket seals that are different "thicknesses" than the originals. Unfortunately, with Standard out of business, everything we buy is aftermarket.
Assuming, like Randall says, that you have seals for the correct ID and OD, then the thickness should not be an issue. The important thing is that, if the seal is thinner than original, it must be installed perfectly straight, i.e not "cocked" in the seal bore. I usually study the hub sealing surface for any wear or grooves, and choose the best location for the seal. If you want it deep, then just tap it in against the bore notch. If you want it out sightly, use a flat plate to tap the seal so it is only in as far as the outer edge of the bore, but still straight.
KVH
Let's say the seals are now nicely tapped into place. When you slide the axles back in are you supposed to lubricate anything? Grease up the shafts? I think not since they are splined at the end, and any lubrication would be at the differential end, correct?
Why did a read a warning about not tearing the seal upon axle installation? Is it that tricky?
Finally, to avoid tapping the seal in backward, what is the rule on seals? Lip protrusion (convex) toward the oil?
TR3driver
I definitely lube both the lips of the seal, and the shaft where it rubs the seal. Just a little, no need to grease up the whole shaft.
Modern seals I think are less prone to damage than originals, but it's still a good idea to support the shaft as it goes through the seal (rather than letting the weight rest on the seal), and to not bang the splined end against the seal.
Lips go towards the oil.
Dash
Randall was spot on. I was after the wrong seal..I'm fortunate to be within 3 miles of the restoration shop that sanblasted the chassis and since they picked it up with the rear end still mounted I asked them to go ahead and inspect the differential and , at the very least, replace the seals. Since I was already putting an order together from Moss I said I would get them and let me know what they needed. Well the mechanic told the office that he had everything except a pinion seal but the office somehow translated that to axle seal(s) and called me so that's what I ordered. I had picked up the old seal (just in case) so when the new seals arrived I could compare. Well obviously they didn't match and not having ever torn down a differential before to know better, spent the next 3 days going crazy on a snipe hunt trying to match axle seals to the size of a pinion seal. I was convinced I was the proud owner of a mutant differential.. Finally went back to the shop and spoke directly with the mechanic to see what the options were and that's when I learned where the snipe was hiding..
Guess I learned a lesson out of all that. Maybe one of these days I'll find out what it was..
J Carburetor Banjo Seals Austin Healey 11
6 Valve Oil Seals Spridgets 10
RonC TR2/3/3A TR3A Hardtop Seals Triumph 7
V Door Seals Austin Healey 8
K TR2/3/3A Front wheel bearing felt seals too large? Triumph 9
volunteer Wanted Need Door Seals, Vent Window Seals and Trunk Seal for Daimler ds420 Limo Jaguar Classifieds 23
CharlesBN1 Uprated or 'umbrella' valve stem oil seals for BN1 Austin Healey 2
O MGB Gaskets and seals MG 15
Jim_Stevens TR2/3/3A Rear door seals on a 3A? Triumph 12
D TR2/3/3A Draftt seals Triumph 2
M 3000 BJ8 Door Seals Austin Healey 9
BJ8Healeys Disc brake piston seals Spridgets 2
C TR4/4A Selector shaft seals Triumph 12
H TR4/4A Leaking ft hub seals Triumph 5
KVH TR4/4A Door Seals: Moss Part 249-607 Triumph 0
Lin BT7 furflex/rubber door seals Austin Healey 17
HealeyRick BJ7/8 Door Seals Austin Healey 7
KVH TR4/4A Door Seals and Top Padded "Rail" Triumph 5
T TR2/3/3A H6 jet bearing seals Triumph 3
H Side curtain seals Spridgets 0
B Transmission seals Spridgets 12
CJD TR2/3/3A Lockheed Dif seals Triumph 5
D BT7 main bearing seals Austin Healey 11
H General Tech Door Glass outer seals installation Triumph 6
D Door seals bt7 Austin Healey 4
C TR4/4A Transmission seals that do? Triumph 6
4tecdog Side screen rubber seals Spridgets 0
H Door seals BJ8 Austin Healey 15
Sarastro TR4/4A Puzzled about TR6 door seals on a TR4A Triumph 7
GBRandy MGB HIF float chamber seals MG 6
B TR4/4A Door seals Triumph 2
CJD TR2/3/3A Foam vs Rubber Seals Triumph 5
Popeye TR4/4A TR4A front brake caliper rebuild - grease on rubber seals? Triumph 5
G Where can I get bottle jack seals? Restoration & Tools 2
T TR4/4A Replacing Drive Train Seals Triumph 5
Superwrench BJ8 Window seals Austin Healey 6
B Front Seat Bases and Door Seals -- BJ7 -- Advice Austin Healey 6
S TR4/4A door and trunk seals Triumph 3
M TR4/4A Replacing inner furrey window glass seals. Triumph 4
A TR4/4A Changing rear diff seals Triumph 15
WillR MGB transmission seals worth replacing? MG 8
AngliaGT Easiest Way to Remove/Replace Rear Axle Seals/Etc.? Spridgets 9
gbtr6 TR6 Transmission seals Triumph 21
6 Window Seals Spridgets 7
mgedit TR2/3/3A Replacing Lockheed Axle Seals 56 TR3 Triumph 25
Gerald_Gordon TR4/4A Hard door closing after replacing rubber seals Triumph 8
P TR6 Engine seals Triumph 7
Scotsman TR2/3/3A TR3 door weather seals Triumph 22
R TR4/4A Door Seals Triumph 4
J Door/scuttle rubber seals Austin Healey 2
