rubber, poly vs solid steering rack bushings
hymodyne
I'm especially interested folks thoughts on the solid steering rack mounts I've seen available versus polyurethane ones.
any advice would be appreciated
hym
SkinnedKnuckles
I replaced rubber with solid mounts, but found the feel on the wheel a bit harsh. Went to polyurethane and am very pleased,
M_Pied_Lourd
Replaced mine with the Goodparts solid mounts. Very happy with them.
Cheers,
M. Pied Lourd
trrdster2000
All, Poly won't cracker.
Or wear out very fast. Sorry, couldn't resist.
wayne
DougF
I had polyurethane on my car qnd was very disappointed when they wore out after about 40,000 miles. Replaced them with Richard Good's solid bushings...In the beginning you feel a lot through the wheel but eventually it's not noticable.
I definitely prefer the solid ones.
DNK
It would take most of these peoples cars about 15-20 years to get that kind of distance on the bushings.
Darrell_Walker
I have solid, along with a "quick rack". I like it. I also have two u-joints in the column rather than the rubber couplers.
3798j
Bronze
Add my vote for the solid mounts. I think it added some precision to the steering and the feel is not objectionable. They're much easier to install than the bushings too.
HerronScott
Two? I converted the lower one to the TR6 one. What did you do for yours (especially the upper)? Have any pictures?
Scott
Darrell_Walker
Scott
I also used the TR6 u-joints. It was pretty much a drop-in fit, as I recall, the u-joints are just a bit longer that the rubber joints, so I had to grind out the slot in the splines there the clamping bolt goes. I might have shortened the shaft a bit. I can get some pictures tomorrow.
-Darrell
HerronScott
Darrell,
I seem to recall that I had to use the lower shaft from a TR6 as well as the u-joint. Never thought about replacing the upper one too.
Scott
KVH
This is definitely "to each his own."
I have new poly mounts and like them quite well.
I have no concerns about longevity.
Some say that when the Brits designed the car, they decided against steel for mounting the rack because of the greater shock delivered to the steering rack, and maybe because English roads were relatively rough. I think that's likely true.
Popeye TR4/4A Steering bushing: replacing rubber with poly, do I snug to 1/8" gap or...? Triumph 3
J TR2/3/3A Suspension choices, rubber vs poly Triumph 8
Scotsman Rubber vs Poly bushings Triumph 9
S Poly vs. rubber inner wishbone bushings Spridgets 21
B TR6 Help! TR6 Diff Mounts - poly or rubber? Triumph 12
D For Sale GT6 Rotoflex Axles: clean, beadblasted, coated with POR15, excellent rubber couplings. Triumph Classifieds 0
K TR2/3/3A Exhaust bracket rubber "top hat" bushings? Triumph 3
L Red Rubber Brake Grease Austin Healey 2
C MGB Rubber Bumper cover removal MG 5
drooartz Replacing Bugeye windshield rubber Spridgets 6
ModifiedBJ7 BJ7 Windshield Surround Rubber Seal Austin Healey 2
D Top Door rubber and fuzzy seal Spridgets 5
algot1901 1950 Prefect E93A-946480 - door bottom rubber Other British Cars 14
algot1901 Weather stripping and rubber parts Other British Cars 1
LAW75 Rubber Tubes for Choke Cable Austin Healey 11
B TR4/4A Rubber wiper motor mounts Triumph 4
BoyRacer Rubber Fender Buffers Austin Healey 2
S TR2/3/3A Cutting the finish end on the windshield top rubber Triumph 4
T How do you secure your door rubber trim? Austin Healey 9
W Spitfire Hard Top rubber Triumph 5
T Windscreen wiper wheelbox rubber shaft seal Austin Healey 4
K TR2/3/3A Upper shock mounting rubber bushs ? Triumph 1
B TR2/3/3A Windshield Wiper mount rubber Triumph 3
M Quarter light rubber replacement Austin Healey 6
Rut Windshield rubber seal Spridgets 6
S TR2/3/3A little rubber plugs Triumph 3
S TR2/3/3A rubber seal go towards the inside of the trunk Triumph 3
I Best glue for rubber door panels? Spridgets 3
S TR2/3/3A vent lid rubber Triumph 11
BoyRacer windshield wiper motor rubber mounting grommets Austin Healey 9
AUSMHLY Rubber hoses; heater box and valve cover breather Austin Healey 2
warwick-steve Front suspension rubber trunnion bearing question Austin Healey 4
BoyRacer Fuel tank sealing rubber is too thick Austin Healey 3
C Spitfire Rubber bumpers Triumph 3
AngliaGT Rubber Gasket - What's it Fit? British Motor Corp 3
C Installing rubber grommets in firewall? Austin Healey 6
T TR2/3/3A Will cable ties hold rear axle rubber buffer securely? Triumph 7
S TR2/3/3A rubber O rings that go around the gauges Triumph 5
pa297pass TR4/4A TR4 wiper motor rubber mount installation. Triumph 7
Bob Claffie Rubber Bumpers Spridgets 3
Rob Glasgow Hard Top Rubber Seal Austin Healey 3
KVH TR4/4A Rubber Door Gaskets Triumph 8
D TR6 1976 TR6 - Can Rubber Guards be Removed from Bumpers? Triumph 9
Lin BT7 furflex/rubber door seals Austin Healey 17
R TR2/3/3A Replace Rubber bushings in front suspension Triumph 11
D MGB Painted rubber bumpers. How long will they hold up? MG 1
6 For Sale 1960 Bugeye Survivor for Sale with Original Rubber Mats Spridgets Classified 0
G Wanted Packing pieces on rebound rubber engine mount Austin Healey Classifieds 0
G Packing pieces on rebound rubber engine mount Austin Healey 5
Kleykamp Rubber bumper Midget value? Spridgets 5
