TR2/3/3A Will cable ties hold rear axle rubber buffer securely?
TuffTR250
I am planning to replace the rear axle rubber buffers (p/n 115456) on my TR3 with the ones that are split to allow them to fit around the axle. I am thinking of using long cable ties around each side the of the rubber buffer, rather than the stock wire method. Has anyone tried using cable ties, and will they securely hold the buffer in place? Thanks!
Bob
DavidApp
Hello Bob
I used a combination of wire ties and a cable ties. I did have a bit of trouble getting the wire ties wound up to my satisfaction and wished I had bought several spares.
My concern with cable ties is will they become brittle and disintegrate.
David
TR3driver
Great Pumpkin - R.I.P
Yup, I've used tie wraps. Got the black UV-resistant ones, they seem to have held up well. They do get hard, but I've never seen one break.
Make sure you get them as tight as possible though; I have had trouble with them slipping off. Apparently, hard cornering can put some side force on the rubber stops.
Geo Hahn
I used wire tightened with my twirly safety wire pliers, but Harbor Freight sells stainless steel zip ties that might work well.
sp53
Twisting wire is all in the first set up and is easier on round surfaces. Practice on a pole about the size of the axle. Start by getting the wirer tails about 2 inches longer than needed, or 4 inches bigger than the pipe. Make the first twist by hand and have both tails at about 45 degrees to each other with a nice clean symmetrical fold/ twist in the center. Then grab the tails down low right at the top of the first twist with some piles, and pull back some as you twist. Maybe twist around 4 times and trim.
IMHO the wire is best because it sinks down in the rubber creating a small grove and will stay in the grove. Masonry supply stores sell special pliers and wirer with small loops on the end and you pull back on the special pliers and that does a perfect twist. They should have wire to fit an axle because the diameter is small.
steve
TR4nut
I’ve used stainless ties from Band-it on a few cars now and really like them. Was lucky to find a used kit so cost was still cheap.
B Replacing the Handbrake Cable Austin Healey 8
KVH General Tech Heater control valve/cable Triumph 1
J 1985 TVR 280i Speedometer Cable TVR 4
F TR4/4A Speedometer cable replacement access Triumph 0
D BT7 Air Vent Control Cable Routing Austin Healey 0
Celtic 77 MGB Looking for best info regarding throttle cable replacement. MG 16
Bayless Help please installing bonnet release cable Spridgets 8
B tachometer cable has a hole in it Restoration & Tools 7
D Choke Cable Length Austin Healey 0
algot1901 1950 Prefect Speedo Cable Other British Cars 8
jfarris TR2/3/3A Removing choke cable from dash insert Triumph 3
LAW75 Rubber Tubes for Choke Cable Austin Healey 11
D Carb Choke Cable Austin Healey 9
M TR6 1973 TR6 - broken choke cable Triumph 6
R Bugeye heater cable Spridgets 12
George Zeck Speedo Cable? Spridgets 3
steveg Battery Cable Specs Austin Healey 33
Walter74 Throttle Cable Conversion Austin Healey 6
Got_All_4 TR6 Routing Speedo cable for a J type tranny in my TR250 Triumph 4
P TR6 Jumpy Speedometer cable Triumph 4
E Oil leaking from the Tachometer cable Austin Healey 5
TomMull TR2/3/3A Which choke cable Triumph 12
P TR6 72 TR6 Speedo cable Triumph 2
S Routing of Hand Brake Cable Austin Healey 6
Gliderman8 TR6 It finally HAPPENED... Hood cable broke but HAPPY ending. Triumph 44
T TR6 TR6 Choke Cable Lubrication Triumph 5
S BJ8 Choke Cable- How to tighten the nut behind the dash? Austin Healey 6
K Choke cable replacement Austin Healey 1
Marvin Gruber BJ7 tach cable location. Austin Healey 3
Jim_Stevens TR2/3/3A OD angle drive engaging the speedo cable Triumph 8
FlyingCat Spitfire Accelerator cable Triumph 4
B TR6 TR6 Hood Release Cable Triumph 7
sparkydave 1500 battery cable colors Spridgets 1
JFS TR2/3/3A Wiper Cable Lube Triumph 5
T TR5/TR250 What lubricant for TR250 wiper box and cable? Triumph 2
M TR4/4A Speedometer Cable Routing Triumph 7
S TR2/3/3A Routing the OD speedo cable Triumph 9
F TR2/3/3A Choke Cable Problem Triumph 29
B Speedometer Cable Routing Austin Healey 9
S TR2/3/3A tach cable lubricant Triumph 4
2 TR2/3/3A Non OD speedometer cable routing diagram/pictures. Triumph 7
T TR2/3/3A Drive end of speedo inner cable to large for pinion Triumph 2
edkap2002 TR6 72 tr6 choke cable Triumph 4
D TR2/3/3A overdrive cable routing: and mounting the drive train Triumph 31
TRMark TR4/4A Choke Cable Routing Triumph 3
S BJ8 Speedometer Cable Austin Healey 6
S Speedometer Cable Spridgets 5
S TR4/4A What is the routing for the speedo cable Triumph 2
BN6_2197 Correct run of the Choke Cable of BN6 Austin Healey 7
