Solid state turn and brake box
coj
Member
Randy Forbes was very helpful to me about a turn signal problem, thank you Randy. A few days ago I came across a web site with a video that showed a solid state turn and brake signal "Box" that looked like a good replacement for the existing device which in my car is located near the front left side. It clicks when the turn signal is activated. Has anyone seen this video, and if so do you know what the site is. The part seems reasonable to purchaseand if it does the job as seen in the video, may be another way around a Lucas system. Thanks for any info.
AUSMHLY
I've had the Moss DB10 Style Flasher Relay in my car for the last 5 years, then it went bad. Eventhough it's a computer board, seems Lucas found it's way in there. I'm now using an orginal Lucas. I opened it up, cleaned the points and all the wires. Seems problem free, just as the aftermarket one, (photo below) seemed to be.
So, I would not replace the Lucas unit if it's working. Just because you think a modern unit without points will be better, don't count on it. Seems here's another item one may consider adding to the spare parts in the boot.
Bob McElwee
I second AUSMHLY. I'm back to an orginal box after the modern one went bad.
Keoke
Well,Within a population of units there is a small sub-group of units with latent defects that will fail. However, the larger group in the sample will be OK--Keoke
John Turney
AUSMHLY said:
.... I'm now using an orginal Lucas. I opened it up, cleaned the points and all the wires. Seems problem free, just as the aftermarket one, ....
The coils went bad in my Lucas original. I had an event to get to and the new solid state one didn't arrive in time, so I made one from Radio Shack relays. If I get the time, I'll see if I can get the relays to fit in the original housing and keep as a spare. Then if it goes bad, I can just replace relays without unwiring it.
Keoke
The Late Jim Albrecht pioneered this type upgrade years ago. The design is published in a write up in one of the Healey club Magazines.--Fwiw--Keoke
TodE
I am restoring a 1955 BN-1. My original was bad, so I purchased a new one from Moss. I cleaned my old flasher cover plate and replaced the new cover plate with the old cleaned one! It looks more original.With the correct Manufacture date. The new flasher cover looked too new and "tinny". Have not put power to it yet.
Good luck!
C AUF214 solid state conversion question British Motor Corp 0
R Solid state SU Fuel Pump Austin Healey 2
BobbyD New OD Controller & Solid State Rheostat Triumph 0
V Solid state fuel pump question Spridgets 2
M Solid state conversion of Lucas regulator Triumph 9
bighealeysource Noisy solid state fuel pump Austin Healey 15
MGTF1250Dave Solid State Voltage Regulator Up-date Triumph 7
MGTF1250Dave Solid State Voltage Regulator Conversion Triumph 9
vping Installing a Solid State Fuel Pump MG 7
B MOSS solid state fuel pump Spridgets 3
ronzet Flame Thrower solid state distributor for my A MG 12
vping Anyone use a solid state fuel pump? MG 35
6 Solid State SU Fuel Pump Ticking: Constant? Austin Healey 4
AUSMHLY Su Solid state fuel pump Austin Healey 26
V For Sale Hard Top and Solid Walnut Dash for Sale Triumph Classifieds 2
KVH General Tech Rear Brakes and Solid Axle Triumph 2
T Wanted Looking for a solid [but doesn't have to be perfect] 100-6 Austin Healey Classifieds 17
D TR4/4A Seals on TR4 Solid Rear Axle Triumph 5
KVH TR4/4A Removing Rear Differential Seal--Solid Axle Triumph 1
T TR4/4A Differential clatter-solid axle Triumph 4
Popeye TR4/4A TR4A solid axle rear leaf spring question Triumph 14
N Spitfire Question on solid steering rack mounts! Triumph 3
richie TR4/4A Wheel fitment on TR4a solid axle vs IRS Triumph 6
T TR4/4A Refreshing solid axle TR4a rear bushings Triumph 4
T Tvr 2500m For Sale, Nice Original Solid Example. TVR 1
Stinger TR4/4A TR4A Wood Dash Plywood or Solid Wood Triumph 13
T TR4/4A Which TR4a is better - IRS or solid axle? Triumph 30
hymodyne rubber, poly vs solid steering rack bushings Triumph 12
PAUL161 Solid Throttle Disk for HIFs MG 7
Banjo TR4/4A TR4A solid rear axle, axle. free Triumph 8
T GT6 GT6+ - could be a solid car Triumph 22
J TR4/4A TR4A Solid Axle Rear Brake Backing Plates Triumph 17
BugEyeBear Nice Solid BugEye on eBay [not mine...] Spridgets 8
Morris Solid core wire Spridgets 6
J TR4/4A TR4A solid axle assembly Triumph 15
B solid looking project for someone Spridgets 7
B solid bronze TW Spridgets 1
T TR4/4A 4A IRS tub on 4A solid axle frame? Triumph 2
Westfield_XI Solid mounted Spridget transmission Spridgets 0
T TR4/4A TR4a [solid axle] rear twitch-iness question Triumph 15
D E-type solid rack mounts? Jaguar 6
Banjo TR4/4A TR4A solid axle rear end for sale Triumph 0
racing girl How Many Of You Use A Solid Neck/Shoulder Brace? Racing 3
M Solid color or 2 tone paint Austin Healey 8
Banjo TR4/4A Soon to be parting a TR4A solid axle Triumph 1
beaulieu solid wheel knock-offs , do they exhist ? Restoration & Tools 11
T Solid Sway Bar bushing mounts Spridgets 2
3 Solid vs. poly vs. stock rack mounts. Triumph 10
R rusty but solid seat bottom Spridgets 4
Basil Seriously considering solid stainless cylinders Jaguar 9
