TR4/4A 4A IRS tub on 4A solid axle frame?
TR3driver
Great Pumpkin - R.I.P
Yup, should fit fine. Even the frames are the same, except for a bolt-on piece. But totally different than a TR4 frame.
B TR4/4A Measurement of "IRS" badge Holes Triumph 1
B TR4/4A Rear Fuel Line Routing IRS Triumph 5
fpstude TR4/4A Replacing Rear Flexible Brake Hoses on TR4A w/ IRS Triumph 11
S TR4/4A Build Date Triumph TR4A IRS Triumph 3
M TR4/4A Reducing Chassis Flex on TR4A IRS Triumph 2
jfarris For Sale 1967 TR4A IRS $19,000 Birmingham AL Triumph Classifieds 3
Rut TR4/4A 67 TR4a irs to live axle Triumph 18
Brinkerhoff TR4/4A Straightening a TR4A IRS chassis Triumph 15
J Wanted Tr4a irs frame Triumph Classifieds 1
L For Sale late tr4a IRS project Triumph Classifieds 0
Scotsman TR4/4A TR4a Live axle vs IRS Triumph 13
J TR4/4A 67 IRS Damper arm/link removal help Triumph 10
KVH TR4/4A Loose Rear Shocks on my IRS Triumph 7
H Joan Baex 1961 flat floor--silver exterior--anybody know what IRS sold it for? Jaguar 0
J TR4/4A TR4A IRS Grille Question Triumph 4
S TR6 Would a IRS TR-4A body bolt on to a TR-6 frame??? Triumph 4
RJS TR4/4A Grease for IRS Axle Shaft Splines Triumph 5
KVH TR4/4A Noise from the Rear--IRS Triumph 4
O TR4/4A Will these tires/wheels work on my 1966 TR4a, IRS? Triumph 19
G TR4/4A irs differential Triumph 7
G TR4/4A tr4a irs left rear wheel Triumph 14
H TR4/4A Trailing Arm IRS Triumph 6
alanjohnturner TR6 Trailing arm brackets - any IRS car Triumph 2
6TTR3A TR6 Replacing the IRS u-joints on a TR6 Triumph 15
glemon Cheap Insurance [Triumph TR IRS Reinforcement] Triumph 2
C TR4/4A TRIUMPH TR4A iRS For Sale - NUT & BOLT RESTORATION--[CONCOURS CONDITION] Triumph 2
C TR4/4A 1967 TR4A IRS motor mounts Triumph 7
T TR4/4A TR4 IRS boot instalation Triumph 15
Zimmycobra TR4/4A TR4A IRS Differential Mounts Triumph 8
Zimmycobra TR4/4A any tricks to change rear brake hose - especially on passenger side [TR4A IRS] Triumph 9
richie TR4/4A Wheel fitment on TR4a solid axle vs IRS Triumph 6
rovernut TR4/4A TR4A IRS VIN differences Triumph 9
Geo Hahn Lowering Passenger Side Ride Height on non-IRS TR Triumph 4
J 67 IRS Exhaust Tips Triumph 2
Gerard TR4/4A TR4A IRS rear suspension rebuild Triumph 10
T TR4/4A 65 triumph tr4a-irs tires Triumph 7
J TR4/4A TR4A IRS Trunk Triumph 3
J TR4/4A TR4A IRS Exhaust Triumph 5
T TR6 TR4a IRS vs TR6 handling Triumph 20
P IRS swingarm alignment shims Triumph 2
KVH TR4/4A TR4A IRS Front and Rear Differential Bridge Pins Triumph 6
J TR4/4A TR4A IRS Clamps, Belt and Suspenders? Triumph 4
R IRS Rear Axles Triumph 16
J TR4/4A TR4A IRS Exhaust Triumph 11
britlover TR6 TR4A IRS body on a TR6 Frame?? Differences? Triumph 10
J TR4/4A TR4A IRS Jack Stands Triumph 6
J Putting the IRS on stands ??? Triumph 5
J TR4/4A Shock Absorbers TR4A IRS Triumph 3
R TR4/4A 66' TR4a irs, steering nut size Triumph 13
R TR4/4A Tr4a irs, name plate question Triumph 13
