TR4/4A Trailing Arm IRS
HarryL
Does anyone know the firm that produces the kit to tap in new
inserts for the hub carrier. They have the helicoils and all allowing you to
reuse the trailing arm after the original studs have been stripped.
Happy New Year Everyone
Harry
H
HarryL
This include the whole kit, helicoils, a plate to fasten down flat so the tap is done correctly,
plus the oversize studs. I just can't remember where I saw it.
Harry
alanjohnturner TR6 Trailing arm brackets - any IRS car Triumph 2
T TR4/4A TR4A IRS trailing arm bushing question Triumph 15
steveg TR6 Installing stock trailing arm bushings on the car - is it possible? Triumph 2
steveg TR6 Installing adjustable trailing arm brackets Triumph 7
Tim Tucker TR6 Trailing Arm NYLATRON bushing-washer gap questions Triumph 4
A TR5/TR250 Trailing Arm Question Triumph 9
bugedd Rear trailing arm question Spridgets 2
tomshobby TR6 Nylatron trailing arm bushings. Triumph 11
R TR6 Cruciform [T shirt] and possible trailing arm mount replacement Triumph 8
glemon General TR Adjustable Trailing Arm Brackets, Cheap and Lazy, or clever like a fox? Triumph 0
T Trailing Arm Cracks Triumph 23
K TR4/4A 4A Trailing Arm Bushings Replacement Again? Triumph 2
K Remove & Replace Trailing Arm Bushings? Triumph 9
M Rear Trailing arm Shims Question [pic] Triumph 2
M TR6 GoodParts Adjustable Trailing Arm Brackets TR6 Triumph 14
TR6BobNF TR6 TR6 Trailing Arm Bracket - Crack Triumph 10
glemon TR5/TR250 TR250/6 Rear Trailing Arm Bush Options Triumph 39
B TR5/TR250 TR250 trailing arm box section Triumph 5
T Trailing arm reassembly question Triumph 3
Brosky Trailing arm stud repair and new CV axles done Triumph 14
SCguy TR6 TR6 Trailing arm question Triumph 10
Gliderman8 Trailing arm studs Triumph 5
I TR6 TR6 rear hub and trailing arm spares advice Triumph 2
I TR6 How do I grease TR6 trailing arm u-joints? Triumph 8
I TR6 TR6 trailing arm stud upgrade? Triumph 50
I trailing arm torque, torque wrench questions Triumph 28
T Alemites in Trailing Arm to grease Nylatron Bushs. Triumph 8
T Goodparts trailing arm bracket install question... Triumph 4
T Trailing Arm bushing question..... Triumph 9
I TR6 TR6 trailing arm bushing installation help Triumph 24
T Trailing arm failures Triumph 27
D Adjustable Trailing Arm Mounts Triumph 11
John_Mc Trailing arm refurbish Triumph 3
John_Mc Rear trailing arm brackets Triumph 5
T Trailing Arm Bushings Install Triumph 4
RobT Trailing Arm Bushes - Help - Too Many Choices Triumph 12
71tr New Trailing Arm Brackets Triumph 5
M TR6 TR6 trailing arm bracket bolts - Help! Triumph 9
A Installing Trailing Arm Bushes Triumph 9
2 Trailing Arm Studs Triumph 10
SCguy Trailing arm bushing removal Triumph 6
G TR6 Rear suspension [trailing arm] adjustment on a TR6 Triumph 18
71tr Trailing Arm Brackets Triumph 0
tr6web TR6 Bumper stop on trailing arm - TR6 Triumph 5
71tr Trailing Arm Busing Removal Triumph 13
Mark_Gibson TR6 TR-6 Rear Trailing Arm Brackets..Success!! Triumph 10
Mark_Gibson TR6 TR-6 Adjustable Trailing Arm Bracket Feedback Triumph 3
beez trailing arm section Triumph 3
T Trailing arm & rear shock paint ? Triumph 2
TR4nut TR6 Ballpark cost - TR6 trailing arms? Triumph 4
