Trailing arm stud repair and new CV axles done
Platinum
That CV axle setup is elegant, Paul!! Nicely done. :laugh:
mrv8q
<span style="font-style: italic">Everything</span>, as usual, nicely done. Good on ya', Paul!
Did you have any thoughts of going to the Nissan differential, and if so, can you use the RG half shafts?
hondo402000
when you test drive it or if you have give us a description on the new axles vs the old
thanks for the detailed repair
Hondo
Andrew Mace
Forgive me for expressing a bit of amusement at the spelling of "Hazzard Relay" in the fuse box; does that control the function that helps the car jump creeks?
:driving:
tdskip
Yeh! So how does it <span style="text-decoration: underline">drive</span> Paul? Notice any difference in power application or ride etc?
Nice work (as usual), and thanks for the write up (as usual).
PeterK
Well Daisy Duke that's funny, I missed that one. I often see gauges incorrectly spelled as guages too. Can't blame this one on Chinese to English translation. Quality control.
PeterK
Paul, those brake shoes look they need a little glaze removal. Maybe box in the shock mounts too if you need another project (like a hole in the head, I know!)
Brosky
Brosky
OK, I'll have to check out the Hazzard Relay. I missed that one. Good eyes Andrew!
Brake shoes were de-glazed with a bit of 80 grit paper.
It rides and handles very well. I did a bit of "spirited" driving coming back from Eric's and it is just fine up to where the extra digits come on. I like the feel and I'm sure that as I get it out to drive more, I'll like it a lot more.
Larry, it really is a drop in operation but several things to consider.
You want two guys for the extra hands needed, especially with the trailing arms going in and out.
Richard recommends installing his nylatron bushings with the new axles. I bought them, but did not install them as I have new bushings in mine with only 2,400 miles on them and they seem to be fine.
The rear is easier to drop than the front suspension, so if you have a good set of jack stands and a jack, with the helper it is easier than you think.
The harder side is the right side as the exhaust can be tricky to get around when torquing the adapters to the differential hubs and then the axle flanges to the adapters. Two pairs of hands helps here as well. You can get a wrench up through the exhaust to hold the nut, but need to torque it from the wheel side in. One outside and one under.
The big nut that goes on the axles is torqued to 250 Ft. Lbs (I believe, but may be 225, so you want good accurate torque wrenches for that part of it.
The instructions sent are very clear, but I added the pictures that I thought would make it easier for anyone to do it. I will add some arrows pointing to the spot whee the silicone goes, etc., to try to make it bit clearer. Between my site and BobbyD's you should get a really good idea of what it takes to get it done.
Brakes will need to be bled, so another good reason for a helper.
And if anyone does this........do yourself a favor and do the studs at the same time and get them out of the way.
Brosky
Brosky
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]Did you have any thoughts of going to the Nissan differential, and if so, can you use the RG half shafts?[/QUOTE]
With all of the other expenses, I decided that I could live without that part.
Good news is that the seat bottoms are done and they look great. Back covers are sewn up and they will be assembled and should be be done for Friday (fingers crossed)and hopefully I can get those in this weekend. Pics to follow tomorrow.
BobbyD
Kevin......interesting question as the CVJ price for use with a Nissan diff is $50 cheaper if it's being attached to a 5 bolt Nissan diff like I have. It looks like the stock diff and the Nissan 6 bolt diff all require an adapter plate which you can see in Paul's first picture of all the kit components. If you went to a 5 bolt Nissan diff, you'd probably just remove the adapters and if you went to a 6 bolt Nissan diff, you'd have to buy new adapters from Richard.
I went the opposite way. I had the Nissan diff first with my stock axles and you can see the adapters in the picture below. When I replaced the stock axles with his CVJs, I didn't need any adapters.
Brosky
Brosky
Can you guys even imagine trying to do this stuff without these forums? The money, time and effort that is saved by everyone collaborating on their projects and posting it must be enormous.
KVH
This is an incredible forum, and the discussion, links and pics on the subject of trailing arms and CV axle replacements is really fantastic.
Now, here's a related topic.
If you're upgrading to the CV axles, or using a Nissan differential, what about upgrading the frame members and upper coil spring beam which I hear can be so problematic--or is that only an issue on the IRS TR4A?
Are there kits to be used and steps that can be taken to strengthen the frame in those areas, without removing the body from the chassis, or would such a project entail essentially a frame-off retoration?
I TR6 TR6 trailing arm stud upgrade? Triumph 50
steveg TR6 Installing stock trailing arm bushings on the car - is it possible? Triumph 2
steveg TR6 Installing adjustable trailing arm brackets Triumph 7
Tim Tucker TR6 Trailing Arm NYLATRON bushing-washer gap questions Triumph 4
A TR5/TR250 Trailing Arm Question Triumph 9
bugedd Rear trailing arm question Spridgets 2
tomshobby TR6 Nylatron trailing arm bushings. Triumph 11
R TR6 Cruciform [T shirt] and possible trailing arm mount replacement Triumph 8
H TR4/4A Trailing Arm IRS Triumph 6
alanjohnturner TR6 Trailing arm brackets - any IRS car Triumph 2
glemon General TR Adjustable Trailing Arm Brackets, Cheap and Lazy, or clever like a fox? Triumph 0
T Trailing Arm Cracks Triumph 23
K TR4/4A 4A Trailing Arm Bushings Replacement Again? Triumph 2
K Remove & Replace Trailing Arm Bushings? Triumph 9
M Rear Trailing arm Shims Question [pic] Triumph 2
M TR6 GoodParts Adjustable Trailing Arm Brackets TR6 Triumph 14
TR6BobNF TR6 TR6 Trailing Arm Bracket - Crack Triumph 10
glemon TR5/TR250 TR250/6 Rear Trailing Arm Bush Options Triumph 39
B TR5/TR250 TR250 trailing arm box section Triumph 5
T Trailing arm reassembly question Triumph 3
T TR4/4A TR4A IRS trailing arm bushing question Triumph 15
SCguy TR6 TR6 Trailing arm question Triumph 10
Gliderman8 Trailing arm studs Triumph 5
I TR6 TR6 rear hub and trailing arm spares advice Triumph 2
I TR6 How do I grease TR6 trailing arm u-joints? Triumph 8
I trailing arm torque, torque wrench questions Triumph 28
T Alemites in Trailing Arm to grease Nylatron Bushs. Triumph 8
T Goodparts trailing arm bracket install question... Triumph 4
T Trailing Arm bushing question..... Triumph 9
I TR6 TR6 trailing arm bushing installation help Triumph 24
T Trailing arm failures Triumph 27
D Adjustable Trailing Arm Mounts Triumph 11
John_Mc Trailing arm refurbish Triumph 3
John_Mc Rear trailing arm brackets Triumph 5
T Trailing Arm Bushings Install Triumph 4
RobT Trailing Arm Bushes - Help - Too Many Choices Triumph 12
71tr New Trailing Arm Brackets Triumph 5
M TR6 TR6 trailing arm bracket bolts - Help! Triumph 9
A Installing Trailing Arm Bushes Triumph 9
2 Trailing Arm Studs Triumph 10
SCguy Trailing arm bushing removal Triumph 6
G TR6 Rear suspension [trailing arm] adjustment on a TR6 Triumph 18
71tr Trailing Arm Brackets Triumph 0
tr6web TR6 Bumper stop on trailing arm - TR6 Triumph 5
71tr Trailing Arm Busing Removal Triumph 13
Mark_Gibson TR6 TR-6 Rear Trailing Arm Brackets..Success!! Triumph 10
Mark_Gibson TR6 TR-6 Adjustable Trailing Arm Bracket Feedback Triumph 3
beez trailing arm section Triumph 3
T Trailing arm & rear shock paint ? Triumph 2
TR4nut TR6 Ballpark cost - TR6 trailing arms? Triumph 4
