TR6 TR6 rear hub and trailing arm spares advice
ichthos
Hello,
I like to keep spares of parts I know will most likely wear out so that I do not have much down time. Many times good deals on spare parts have saved me from the price of expensive repairs. I admit it is easy to get carried away with this idea. I frequently see rebuilt rear hubs and trailing arms for sale on the internet. Is it worth it to get spares for these four parts? I know what to look for in the trailing arms (mainly that the studs are not stripped), but how do I know if a rear hub has been rebuilt correctly? What are reasonable prices for these parts?
Kevin
TR3driver
Great Pumpkin - R.I.P
Ok, I'm prejudiced. But unless it's from a well-known vendor who oversaw the rebuilding themselves; IMO the only safe assumption is that a "rebuilt" component is, at best, a core for rebuilding.
For example, there was the "rebuilt" Stag steering rack that had no power assist once I got it installed ... control valve was improperly assembled. Or the "rebuilt" TR3 starter (that I bought as a core anyway), that turned out to be full of blast media! Or the rebuilt TR3 wiper motor that looked beautiful with it's fresh powder coat, but was missing one of the brushes. Possibly the sellers were not being dishonest, they were simply unaware of the problems. But I no longer assume anything like that is actually in good shape unless I can verify it myself. With rear hubs, that may not be an option.
Here's a shot of the pinion head bearing from my "rebuilt" Stag differential (which turned out to actually be from a 2.5PI Estate).
BobbyD
Got_All_4 TR6 drill and tap for a grease fitting tr6 rear hub assembly Triumph 4
Pete_Chadwell TR6 TR6 Rear Hub question, plus gearbox vibe Triumph 8
SCguy TR6 Rear Hub on a TR6 5 out of 6 studs enough? Triumph 24
G TR6 TR6 Rear Axle and Hub - saga continues Triumph 7
tr6web TR6 Rear hub u-joints TR6 Triumph 9
S TR6 1974 TR6 Rear Brakes w/o hydr. press. Triumph 6
R For Sale TR6 REAR AXLE HUBS Triumph Classifieds 0
R For Sale TR6 REAR DIFFERENTIAL Triumph Classifieds 3
edkap2002 TR6 TR6 rear pinion seal Triumph 3
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 15
mctriumph For sale rear wings Tr6 Triumph Classifieds 3
mctriumph Have a pair of tr6 rear wings Triumph Classifieds 0
EWD TR6 74 TR6 - Rear and windshield frame color Triumph 2
EWD TR6 Rear Transmission Seal 74 TR6 Triumph 4
J TR6 1973 TR6 Rear Brake Operation Questions Triumph 4
T TR6 TR6 Rear Bumper Bar Triumph 1
Got_All_4 TR6 Rear Bumper removal 1970 TR6 Triumph 3
T Wanted TR6 rear trailing arms Triumph Classifieds 1
M TR6 TR6 rear bumper Triumph 0
cmacmillan TR6 Rear bumper removal - TR6 Triumph 10
GBRandy TR6 1973 TR6 Rear Frame / Body Bushings Triumph 3
T TR4/4A Under the been there - done that school of learning: TR6 rear springs on a TR4a Triumph 12
T TR6 TR6 aftermarket rear shocks Triumph 35
W TR6 tr6 rear hubs Triumph 3
F TR6 TR6 HARDTOP GLASS [rear] Triumph 7
D TR6 76 TR6 Rear Brake Installation Triumph 17
hondo402000 TR6 New rear wheel cylinder leaking, TR6 Triumph 0
D TR6 76 TR6 Rear Right Brake Line Triumph 8
J TR6 rebuilding tr6 rear hubs Triumph 13
T TR6 Passenger side TR6 rear clunk? Triumph 9
W TR6 broken bleeder on rear brakes tr6 Triumph 12
S TR6 tr6 rear shock part number ??? Triumph 5
Coyote1 TR6 TR6 Rear Springs ? Triumph 11
O TR6 TR6 Rear Valance ID Triumph 1
TR6oldtimer TR6 TR6 windscreen and rear flat black Triumph 4
SherpaPilot TR6 TR6 Rear Axle Bearing Question Triumph 10
B TR6 TR6 rear axle oil change Triumph 21
T TR6 Anyone use TR6 rear springs in their TR4a IRS? Triumph 8
glemon TR6 TR250 TR6 Rear Springs Triumph 13
S TR6 Rear suspension TR6 Triumph 8
hondo402000 TR6 NEEDED rear light socket TR6 for reverse lamp Triumph 10
hondo402000 TR6 TR6 Rear Paint, Satin Black Triumph 8
hondo402000 TR6 TR6 rear body Black paint help Triumph 9
B TR6 Rear-ended today and my beautiful TR6 is smashed.. Triumph 18
T TR6 TR6 rear sway bar question Triumph 6
T TR6 Is this a TR6 rear sway bar? Triumph 10
B TR6 Removal and Replacement of TR6 rear deck Triumph 3
T TR6 tr6 rear noise Triumph 8
I TR6 Rear brake drum temperature TR6 Triumph 13
