Here are different spring shots, front and rear. I wish they were more controlled but when I started out on this great idea I assumed someone already had it figured out. I’m sure each car is somewhat different. The rear felt dumpy and I needed new bushings.
STOCK SPRINGS
STOCK RIDE HEIGHT 20% Stiffer
SHORT SPRINGS, 1” Shorter, 20% Stiffer
It sits now with the Goodparts 1” Shorter, 20% stiffer.
I think the rear is good once I find the noise back there. It may be a tad lower but with less sag ok. The front has negative camber and looks low. Rats, the rear is much easier but I’ve got the drill down now. I think I’m going to try a ½” spacer rather than ¾”.
The important part, driving I appreciate the firmer ride on the road with moderate driving. Around town I suppose its bumpier but the roads are bad and that’s not where I spend most of my time driving.
