TR6 tr6 rear shock part number ???
skagroovy
Member
having a hard time finding the kyb gr2 part number for my rear shock i want to replace... cant find a part number all the distributors just want to sell a conversion kit but don't mention what the kyb replacement is... i have the easy shock replacement version no cutting into the trunk... koni, kyb are preferred
big6
The rear shock kit that I installed some 18+ years ago on my TR6 will cross reference with 1972-4 Ford Pinto wagon rear shock. If you shock is a bit shorter try the rear shock for the Ford Pinto coupe. Almost any brand of your choice is available for the Pinto.
HerronScott
What's the manufacturer and part number of the shock that's currently installed? If you have that you should be able to cross reference to another brand.
Scott
DougF
The ones I have on the shelf are from CarQuest. Part #1923138. If you have trouble finding a set, let me know. This set is a spare and I'd be willing to let them go.
S
skagroovy
Member
the shock mount that is on my car must be custom since the top of the mount is much higher than any mount i have see on a tr6 it is a Gabriel shock but i don't have a part number, i checked the pinto route but they are too short the shock on the car fully extended is about 17.5"
YYCDave TR6 TR6 Rear Shock Conversion & Tire Size Triumph 2
T TR6 TR6 Rear lever shock rebuild: Triumph 3
A TR6 TR6 Rear Tube Shock Conversions Triumph 13
V TR6 TR6 Tube Shock Size [front and rear] Triumph 9
M TR6 Help- TR6 rear shock mount cracked Triumph 3
S TR6 1974 TR6 Rear Brakes w/o hydr. press. Triumph 6
R For Sale TR6 REAR AXLE HUBS Triumph Classifieds 0
R For Sale TR6 REAR DIFFERENTIAL Triumph Classifieds 3
edkap2002 TR6 TR6 rear pinion seal Triumph 3
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 15
mctriumph For sale rear wings Tr6 Triumph Classifieds 3
mctriumph Have a pair of tr6 rear wings Triumph Classifieds 0
EWD TR6 74 TR6 - Rear and windshield frame color Triumph 2
EWD TR6 Rear Transmission Seal 74 TR6 Triumph 4
Got_All_4 TR6 drill and tap for a grease fitting tr6 rear hub assembly Triumph 4
J TR6 1973 TR6 Rear Brake Operation Questions Triumph 4
T TR6 TR6 Rear Bumper Bar Triumph 1
Got_All_4 TR6 Rear Bumper removal 1970 TR6 Triumph 3
T Wanted TR6 rear trailing arms Triumph Classifieds 1
M TR6 TR6 rear bumper Triumph 0
cmacmillan TR6 Rear bumper removal - TR6 Triumph 10
GBRandy TR6 1973 TR6 Rear Frame / Body Bushings Triumph 3
T TR4/4A Under the been there - done that school of learning: TR6 rear springs on a TR4a Triumph 12
T TR6 TR6 aftermarket rear shocks Triumph 35
W TR6 tr6 rear hubs Triumph 3
F TR6 TR6 HARDTOP GLASS [rear] Triumph 7
D TR6 76 TR6 Rear Brake Installation Triumph 17
hondo402000 TR6 New rear wheel cylinder leaking, TR6 Triumph 0
D TR6 76 TR6 Rear Right Brake Line Triumph 8
J TR6 rebuilding tr6 rear hubs Triumph 13
T TR6 Passenger side TR6 rear clunk? Triumph 9
W TR6 broken bleeder on rear brakes tr6 Triumph 12
Coyote1 TR6 TR6 Rear Springs ? Triumph 11
Pete_Chadwell TR6 TR6 Rear Hub question, plus gearbox vibe Triumph 8
O TR6 TR6 Rear Valance ID Triumph 1
TR6oldtimer TR6 TR6 windscreen and rear flat black Triumph 4
SherpaPilot TR6 TR6 Rear Axle Bearing Question Triumph 10
B TR6 TR6 rear axle oil change Triumph 21
T TR6 Anyone use TR6 rear springs in their TR4a IRS? Triumph 8
glemon TR6 TR250 TR6 Rear Springs Triumph 13
S TR6 Rear suspension TR6 Triumph 8
hondo402000 TR6 NEEDED rear light socket TR6 for reverse lamp Triumph 10
hondo402000 TR6 TR6 Rear Paint, Satin Black Triumph 8
hondo402000 TR6 TR6 rear body Black paint help Triumph 9
B TR6 Rear-ended today and my beautiful TR6 is smashed.. Triumph 18
T TR6 TR6 rear sway bar question Triumph 6
I TR6 TR6 rear hub and trailing arm spares advice Triumph 2
T TR6 Is this a TR6 rear sway bar? Triumph 10
B TR6 Removal and Replacement of TR6 rear deck Triumph 3
