TR6 Is this a TR6 rear sway bar?
tdskip
OK guys - hit me with some knowledge....
M_Pied_Lourd
Hey Skip,
Ok, I will bite.
I say no. The angle looks too severe to mount as it should on the rear frame....from the photos anyway.
Cheers,
M. Pied Lourd
M_Pied_Lourd
Here is a pick of the rear bar I have installed on mine for comparison purposes...
To me,it looks more like a front sway bar for a TR3.....
Cheers,
M. Pied Lourd
bgbassplyr
I don't recall ever having seen one with 2 mounting points on each end.
Jim
TR3driver
Great Pumpkin - R.I.P
I've never seen one like that on a Triumph, but some GM cars do it that way. Both points fasten solidly to the A-arm; so the bar has to deflect even if the A-arms move together. Thus the bar is adding overall spring rate as well as roll stiffness.
Just a WAG, but I'd guess they do it that way for simplicity (low cost) and possibly also so the same main springs can be used for both standard and 'sport' suspensions. The stiffer bar for the sport option also increases the spring rate.
T
tdskip
Hi guys - thanks for the ideas. When I was (finally) cleaning up the 1971 TR6 shell I found that next to a new front sway bar and some other bits from TRF. It may well be a stray part, but everything else was correct for the TR6 so I'm wondering if it was from some other vendor but intended for a TR?
T
tdskip
Hi Don - I was wondering that myself. I need to grab some measurements and report back.
Nice icon by the way.
BTW - how the TR7/8 coming along?
T TR6 TR6 rear sway bar question Triumph 6
C TR6 TR6 Rear Sway Bar Install ?? Triumph 17
S TR6 1974 TR6 Rear Brakes w/o hydr. press. Triumph 6
R For Sale TR6 REAR AXLE HUBS Triumph Classifieds 0
R For Sale TR6 REAR DIFFERENTIAL Triumph Classifieds 3
edkap2002 TR6 TR6 rear pinion seal Triumph 3
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 15
mctriumph For sale rear wings Tr6 Triumph Classifieds 3
mctriumph Have a pair of tr6 rear wings Triumph Classifieds 0
EWD TR6 74 TR6 - Rear and windshield frame color Triumph 2
EWD TR6 Rear Transmission Seal 74 TR6 Triumph 4
Got_All_4 TR6 drill and tap for a grease fitting tr6 rear hub assembly Triumph 4
J TR6 1973 TR6 Rear Brake Operation Questions Triumph 4
T TR6 TR6 Rear Bumper Bar Triumph 1
Got_All_4 TR6 Rear Bumper removal 1970 TR6 Triumph 3
T Wanted TR6 rear trailing arms Triumph Classifieds 1
M TR6 TR6 rear bumper Triumph 0
cmacmillan TR6 Rear bumper removal - TR6 Triumph 10
GBRandy TR6 1973 TR6 Rear Frame / Body Bushings Triumph 3
T TR4/4A Under the been there - done that school of learning: TR6 rear springs on a TR4a Triumph 12
T TR6 TR6 aftermarket rear shocks Triumph 35
W TR6 tr6 rear hubs Triumph 3
F TR6 TR6 HARDTOP GLASS [rear] Triumph 7
D TR6 76 TR6 Rear Brake Installation Triumph 17
hondo402000 TR6 New rear wheel cylinder leaking, TR6 Triumph 0
D TR6 76 TR6 Rear Right Brake Line Triumph 8
J TR6 rebuilding tr6 rear hubs Triumph 13
T TR6 Passenger side TR6 rear clunk? Triumph 9
W TR6 broken bleeder on rear brakes tr6 Triumph 12
S TR6 tr6 rear shock part number ??? Triumph 5
Coyote1 TR6 TR6 Rear Springs ? Triumph 11
Pete_Chadwell TR6 TR6 Rear Hub question, plus gearbox vibe Triumph 8
O TR6 TR6 Rear Valance ID Triumph 1
TR6oldtimer TR6 TR6 windscreen and rear flat black Triumph 4
SherpaPilot TR6 TR6 Rear Axle Bearing Question Triumph 10
B TR6 TR6 rear axle oil change Triumph 21
T TR6 Anyone use TR6 rear springs in their TR4a IRS? Triumph 8
glemon TR6 TR250 TR6 Rear Springs Triumph 13
S TR6 Rear suspension TR6 Triumph 8
hondo402000 TR6 NEEDED rear light socket TR6 for reverse lamp Triumph 10
hondo402000 TR6 TR6 Rear Paint, Satin Black Triumph 8
hondo402000 TR6 TR6 rear body Black paint help Triumph 9
B TR6 Rear-ended today and my beautiful TR6 is smashed.. Triumph 18
I TR6 TR6 rear hub and trailing arm spares advice Triumph 2
B TR6 Removal and Replacement of TR6 rear deck Triumph 3
T TR6 tr6 rear noise Triumph 8
I TR6 Rear brake drum temperature TR6 Triumph 13
I TR6 Rear wheel bearing help TR6 Triumph 6
I TR6 TR6 rear axle u-joint removal help Triumph 14
