TR6 tr6 rear noise
TexasKnucklehead
Saturday was a perfect day in Houston for a TR6 and I did drive mine, but…
My 74 TR6 is making a louder than usual noise, seemingly from the rear end of the car. I know TR6s are notorious for differential mounting failures, and I’m hoping that is not the cause of my noise. If something is broken, I can’t find it from under the car probing with my fingers. I’m used to the usual “da-thum, da-thum, da-thum” heard when rolling over expansion joints on the freeway, but this noise is louder. I can hear it when I roll back over the 1” drop at the end of my driveway. –With either rear wheel. It sounds like the spare tire in the trunk is banging its rim against the trunk. Since I’ve completely emptied the trunk (no tools, spare, jack, handle, fire extinguisher…) I know it has to be something else. The exhaust system hangers were updated about a year ago when a u-joint failed on the main driveshaft. The exhaust has a little movement (from the rubber hangers) but not enough to allow it to hit anything. The springs are new and so are the blocks they sit in. I installed adjustable trailing arm brackets and nylatron rear bushings a few years back (<5,000 miles). With the rear of the car on jack stands, I can feel some slop or play in the differential when rotating the wheel, but it seems about normal, and no noise is involved. Everything seems tight. The noise is not apparent during hard accelerating or cornering –unless there is a 1” or larger bump. Even when I go over a spot in the road where a new section of pavement is higher than the old section, I hear the noise “da-thu-bang”.
I don’t know where to look or how to find the noise. At first I thought it was my imagination, and I know that a little evidence makes a noise louder, but I’m now sure it’s not normal. Any hints or clues would be most appreciated.
Jerry
hondo402000
If you have the original lever shocks you might check to see if the bolts are loose, I have read some post in the past that said if the bolts loosen up the make some kind of noise
TR4nut
Jerry-
Doesn't sound like the diff mounts. I had that problem on my last 6, and I would hear the problem when I started to let out the clutch and torque started going to the rear wheels - didn't even have to move. Yours sounds more gravity related, so (fingers crossed), I'd check muffler mounts first, then go to the shock mounts - thats where I had a similar problem on my 4. But I'd say it was more "clunk" than "da-thu-bang"...
Randy
AltaKnight
That's where I'd be checking first.
My 6 had loose bolts on the lever shocks and it would make quite a thump going over bumps till I figured it out.
Opa
I'm with the above. I would also check the muffler clearences between the frame rails,(side to side) also the rear tail pipes at the "T" shirt junction.
Can you replicate the sound by bouncing the car up and down? That may tell you if shock mounts are loose. Hopefully not a frame cross member break. :cry: Good luck
brent615
One of my shocks was dangerously loose when i bought the car. i could "bounce" on the rear end with the car parked and hear the thud. While I was in teh area, I pulled both rear shocks, cleaned them and refilled them with Harley Davidson fork oil (low bubbling). Just a thought.
There was a link posted here a year or so ago detailing shock cleaning and refilling.
T
TexasKnucklehead
This morning, I went into the garage to make sure I couldn't shake the car enough to make the noise. (I couldn't.) Then I picked up a 5/8" wrench and looked at the lever shock bolts. The road grime on the ends of the bolts was contiguous to the shock, so I felt this was a waste of time. -Plus what kind of idiot can't see that some bolts are loose? Apparently, this kind. When I put the wrench onto the bolt head and turned it, I thought I must have the wrong size wrench because all I'm doing is knocking off the grime. Actually, both bolts on both shocks were not very tight. After, perhaps more than a full turn on each, I put the wheels back on and went for a test drive. Then I filled the trunk with the usual crap and went for another test drive. It is soo much more quiet. Even the "da-thum, da-thum, da-thum" is toned down.
Thanks for the hints. I am very relieved that I don't have a diiff-mount issue to deal with and the noise is gone.
Jer
AltaKnight
Great news, that's the best type of fix!
The one that doesn't cost you a penny!
hondo402000
Your welcome Jer, now change the oil in the tranny, when I finally checked mine it only had 1/2 a quart in it, now it doesnt jump out of third gear. Just so you have something to do this weekend :smile:
Hondo
C TR6 TR6 Rear Axle Noise Triumph 5
R6MGS TR6 TR6! First Impressions and Rear End Noise! Triumph 16
S TR6 1974 TR6 Rear Brakes w/o hydr. press. Triumph 6
R For Sale TR6 REAR AXLE HUBS Triumph Classifieds 0
R For Sale TR6 REAR DIFFERENTIAL Triumph Classifieds 3
edkap2002 TR6 TR6 rear pinion seal Triumph 3
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 15
mctriumph For sale rear wings Tr6 Triumph Classifieds 3
mctriumph Have a pair of tr6 rear wings Triumph Classifieds 0
EWD TR6 74 TR6 - Rear and windshield frame color Triumph 2
EWD TR6 Rear Transmission Seal 74 TR6 Triumph 4
Got_All_4 TR6 drill and tap for a grease fitting tr6 rear hub assembly Triumph 4
J TR6 1973 TR6 Rear Brake Operation Questions Triumph 4
T TR6 TR6 Rear Bumper Bar Triumph 1
Got_All_4 TR6 Rear Bumper removal 1970 TR6 Triumph 3
T Wanted TR6 rear trailing arms Triumph Classifieds 1
M TR6 TR6 rear bumper Triumph 0
cmacmillan TR6 Rear bumper removal - TR6 Triumph 10
GBRandy TR6 1973 TR6 Rear Frame / Body Bushings Triumph 3
T TR4/4A Under the been there - done that school of learning: TR6 rear springs on a TR4a Triumph 12
T TR6 TR6 aftermarket rear shocks Triumph 35
W TR6 tr6 rear hubs Triumph 3
F TR6 TR6 HARDTOP GLASS [rear] Triumph 7
D TR6 76 TR6 Rear Brake Installation Triumph 17
hondo402000 TR6 New rear wheel cylinder leaking, TR6 Triumph 0
D TR6 76 TR6 Rear Right Brake Line Triumph 8
J TR6 rebuilding tr6 rear hubs Triumph 13
T TR6 Passenger side TR6 rear clunk? Triumph 9
W TR6 broken bleeder on rear brakes tr6 Triumph 12
S TR6 tr6 rear shock part number ??? Triumph 5
Coyote1 TR6 TR6 Rear Springs ? Triumph 11
Pete_Chadwell TR6 TR6 Rear Hub question, plus gearbox vibe Triumph 8
O TR6 TR6 Rear Valance ID Triumph 1
TR6oldtimer TR6 TR6 windscreen and rear flat black Triumph 4
SherpaPilot TR6 TR6 Rear Axle Bearing Question Triumph 10
B TR6 TR6 rear axle oil change Triumph 21
T TR6 Anyone use TR6 rear springs in their TR4a IRS? Triumph 8
glemon TR6 TR250 TR6 Rear Springs Triumph 13
S TR6 Rear suspension TR6 Triumph 8
hondo402000 TR6 NEEDED rear light socket TR6 for reverse lamp Triumph 10
hondo402000 TR6 TR6 Rear Paint, Satin Black Triumph 8
hondo402000 TR6 TR6 rear body Black paint help Triumph 9
B TR6 Rear-ended today and my beautiful TR6 is smashed.. Triumph 18
T TR6 TR6 rear sway bar question Triumph 6
I TR6 TR6 rear hub and trailing arm spares advice Triumph 2
T TR6 Is this a TR6 rear sway bar? Triumph 10
B TR6 Removal and Replacement of TR6 rear deck Triumph 3
I TR6 Rear brake drum temperature TR6 Triumph 13
I TR6 Rear wheel bearing help TR6 Triumph 6
