TR6 Rear brake drum temperature TR6
ichthos
Hello,
I tried doing a search to find out what temp the rear brake drums get, but I found a wide range on the internet. Does anyone know what the upper temperature limit would be for the rear brake drums on a TR6? I would think they would not get that hot since most of the braking action is in the front. The reason I want to know this? I am trying to figure out which powdercoat paint to use. The standard powdercoat paint I use is good up to 250 degrees. Eastwood offers a high temp powder paint that is good up to 1000 degrees, but it costs three times as much, and only comes in satin black (the rest of the black on my car is painted semigloss black). Any help would greatly be appreciated.
Kevin
prb51
Why not rattle can them with a high temp semi gloss black from your flaps? I've done mine that way and since they don't touch anything and are readilly touched up why bother with the expense.
TR3driver
Great Pumpkin - R.I.P
How hot they get depends a good deal on your driving habits, etc. But I would say it's very easy to exceed 250F.
I've seen them actually glow red after driving with the brakes stuck on (or handbrake not released), which would likely kill even your 1000F PC.
Brosky
Keep in mind that heavy amounts of paint can act as an insulator keeping heat inside the drum, rather than letting it escape.
poolboy
You're right about that.
Emmett1010 and I were riding in my 6 to go see his TR3 that he's restoring. I was so busy catching up on old times that I didn't notice that my hand brake was stiil engaged, until I stopped to let him take the wheel.
I tapped the drums with my finger and I tell you they were as hot as a frying pan. Only the callous prevented a blister.
BTW, Emmett1010 is going to have a real gem.
Geo Hahn
prb51 said:
Why not rattle can them with a high temp semi gloss black...
That's what I have done and they have held up fine. Considering my driving habits and the slighty over-engineered weight of those 10" TR3 drums a bit of paint isn't going to cause me any heat problems.
Unless you feel compelled to PC whenever and wherever possible, rattle-can should be fine.
Glad to see you're staying with black -- I never cared much for the bling look or aluminum paint on drums behind a set of wires.
MadMarx
To have them nice I painted them with caliper paint coat and used a normal brush. After some races the paint color is getting a little darker but still nice.
The temperature is max 250°C.
Cheers
Chris
DNK
Chris -Where the heck you been?
Hanging out in the racing forums. Us street guys to tame for ya?
T
Tinster
Go for a drive on an expressway and take
your speed up to 75MPH; with your handy dandy
infrared thermometer gun beside you..
Then panic brake your car to zero, jump out and quickly
shoot a rear drum with your heat pistola - you will get
a "rough" approximation of the brake drum temp.
Wear a pair of old pants.
d
MadMarx
Tame?
Maybe your speed limits force you to be tame.
I had 5 engine blows this year, the most embarrassing season I ever had.
And my job prevented me from writing much.
For this year I want to leave the standard racing head behind and will search for more power with larger valves and changed combustion chambers. The car will be converted to plastic panels to become lighter.
Hope this will help to get more in front part of the grid.
DNK
Maybe you need a more reliable race car. Like a TR8
D Rear Brake Drum Nuts Austin Healey 15
regularman Gear leaking from axle housing into rear brake drum Spridgets 3
nevets stuck rear brake drum Austin Healey 18
A rear brake drum too tight after rebuild Austin Healey 3
K TR2/3/3A Rear brake drum won't go on? Triumph 12
glemon General TR Rear Drum Brake Adjustment Triumph 2
J TR2/3/3A Rear drum brake noise, Why?? Triumph 4
nevets Questions about rear brake drum removal Austin Healey 24
J Wedge Rear Brake Drum 1980 TR 7 Triumph 5
K TR2/3/3A Needs Picture of Rear TR3A Brake Assembly Drum Off Triumph 6
B Hot rear brake drum Austin Healey 9
tri_carb_healey rear drum brake problem Austin Healey 6
JBann Spitfire Rear passenger brake drum smoking - Mk1 Spitfire Triumph 4
SCguy Wedge TR8 rear brake drum removal Triumph 28
I screws on rear brake drum area Spridgets 10
Thomas591 Rear Drum Brake Rubber Dust Cover Austin Healey 2
M Rear brake drum paint Austin Healey 7
Lin rear brake drum adjusters Spridgets 0
KVH General TR Rear Brake Shoe Orientation Triumph 12
BN6_L1232 Rear Disc Brake Installation Instructions Austin Healey 3
J TR2/3/3A TR3A Girling 9" Rear Brake Initial Adjustment Triumph 9
R TR6 Rear brake wheel cylinder fitment Triumph 5
fpstude TR4/4A Replacing Rear Flexible Brake Hoses on TR4A w/ IRS Triumph 11
G Rear Brake Adjustment Austin Healey 30
Kurtis TR4/4A Rear wheel brake cylinder replacement Triumph 1
J TR6 1973 TR6 Rear Brake Operation Questions Triumph 4
R TR2/3/3A Lockeed rear brake banjo fittings. Triumph 7
K MG Midget Early and Later model rear brake shoes.... Spridgets 2
A AH 3000 rear disc brake conversion Austin Healey 28
K TR2/3/3A Rear brake wheel cylinder attachment again Triumph 1
J For Sale Triumph TR3 rear differential and rear brake assembly - Northern Illinois Triumph Classifieds 1
Gliderman8 TR6 Removing Left Rear brake line... help! Triumph 9
Got_All_4 General TR Is there a special tool needed for rear brake cylinders Triumph 14
histerical Wanted WTB Set of Later Spridget Rear Brake Backing Plates Spridgets Classified 0
BN6_2197 Question on rear brake drums BN6 wire wheel Austin Healey 15
warwick-steve Rear Brake cylinder connection Austin Healey 12
Michael Oritt Moss Motors rear brake "set" Austin Healey 11
J Spitfire Spitfire Rear Brake Bleeding Triumph 9
vette Tire Size and Improving Rear Brake Drums Austin Healey 17
nevets BN6 rear brake pipes Austin Healey 15
Jim_Gruber Reinstalling Brake Hubs and Wheel Hubs in Rear. Spridgets 5
Jim_Gruber Brake Lines for Bugsy - What do I need for a Flaring Tool / Rear Discs for Bugsy Spridgets 39
C Help diagnosing rear brake issues... Austin Healey 20
W BN1 vs. BN2 rear brake lines / pipes Austin Healey 4
SASSAMON TR2/3/3A Rear Brake Cylinder Recommendations Triumph 2
Jim_Gruber BE Rear Brake Spring Orientation Spridgets 13
A TR2/3/3A Newbie Question regarding Girling rear brake cylinder Triumph 5
M suggestions on vendor Rear brake rebuild Spridgets 15
