mightymidget
I have been fortunate enough to find a import shop near my home that actually knew, and has worked on Spridgets.
They will work on my vehicle if I provide parts needed and the car at same time to his shop. I have removed the rear end from my Bugeye, thought that I would take the rear end to shop for rebuild to install new brakes/check bearings instead of car and see how this works out.
Seems that must people upgrade to later rear brakes when converting to front disc on front as I have, I have the later model backing plates. Should i just call Moss and let them order what I need and hope I get everthing, or is there a vendor that sells a kit?
Anything I should be aware of ? Seems I remember something about aftermarket axle bearings not being right orsomething odd??
