TR2/3/3A Suggestions for shoulder harness retractable/inertia seat belts
Got_All_4
Looking for suggestions or what you did for 3 point shoulder harness seat belts in a TR3. I used just the lap belt for 30 years now and would like to up grade. I never installed the chrome handle on the passenger side dash because of that. One quick stop and I call it the concussion bar. Anyway I may not have a choice but I don't want to drill a hole in the wheel arch ether to mount the shoulder harness part. I've seen them out there even if I have to give up the retractable part. Pics would be great!
Gliderman8
Andrew Mace
Personally, I prefer the "static" type of three-point harness in older cars over inertia type, as I feel cars with the inertia type belts were designed and engineered specifically for such a setup. And purist that I am, I would have no qualms about mounting the shoulder part on the wheel arch, which is probably as strong a mounting point (if not stronger) than the floor mounts for the lap belt part. It is important to get the shoulder mount high enough so that it is not significantly lower than your shoulder.
I've purchased and have been extremely happy with several sets of three-point static harnesses and other seatbelts from these folks: https://andoauto.com/3point.htm
Got_All_4
Got_All_4
Thanks PowderBlue! Gorgeous interior! Although I didn't think about it when I wrote the introduction but my car is suppose to have the occasional seat. Not built yet. So that inertia real would be in the way. So maybe now looking at something mounting under or around the seats if possible.
I Bugeye valve rebuild suggestions Spridgets 8
D Shop lighting suggestions. Restoration & Tools 8
AngliaGT MGB-GT TT Stainless Steel Exhaust Re-Installtion Suggestions MG 2
nichola TR6 Oil pan is going to leak: suggestions? Triumph 11
K BN4 Locking Door Handle Removal Suggestions Austin Healey 10
catfood Looking for suggestions - ignition issue Austin Healey 6
55modified Need suggestions for fastening aftermarket hardtop for BN1. Austin Healey 15
Bob_Spidell Rebuild Performance Suggestions Sought Austin Healey 8
vette Any Suggestions As to Where to Buy a New BJ7 Gasoline Tank? Austin Healey 24
RAC68 Gear Reduction Starter Infor and Suggestions Requested Austin Healey 11
PatGalvin TR2/3/3A Vacuum Hose Fitting Install, Any Suggestions? Triumph 6
I General TR Mold clean up suggestions Triumph 4
M suggestions on vendor Rear brake rebuild Spridgets 15
DerekJ Healey Blue Paint - suggestions Austin Healey 23
J General TR D Type overdrive not working need suggestions Triumph 5
2billydavies TR2/3/3A looking for suggestions on putting engine back in Triumph 17
G TR4/4A Yet another engine build thread. Parts list: Suggestions/Recommendations/Etc Triumph 11
dcoplan Suggestions for painting letters on dash knobs? Spridgets 6
I TR6 suggestions for brake LED bulbs Triumph 13
dcoplan Tires rubbing on frame - suggestions? Spridgets 2
I TR6 Muffler suggestions? Triumph 6
HealeyDave Car transport company suggestions needed - winter/midwest/USA Austin Healey 2
M Overdrive parts source suggestions Austin Healey 4
M Making a manifold/carb heat shield - any suggestions? Spridgets 14
S TR6 Removing TR6 dash [and suggestions on refinish] Triumph 12
N Spitfire Spitfire sheetmetal prep and sealing suggestions wanted Triumph 2
S TR6 Suggestions: cylinder head won't release from block Triumph 10
Zimmycobra Trans problem. Looking for suggestions. Triumph 10
S Any suggestions on where to start? MG 7
D TR2/3/3A Suggestions needed for TR3 pricing Triumph 10
M TR4/4A 67 TR4A hasn't run for 10 yrs+... suggestions? Triumph 11
TRMark Brake pad suggestions Triumph 16
I Suggestions for bugeye headlights Spridgets 21
M suggestions for brake system Spridgets 9
RAC68 Paint & Design Suggestions Triumph 4
Andrew Mace lacquer primer removal suggestions Triumph 4
I LED tail light suggestions? Spridgets 22
G TR6 Radio suggestions for fitting to TR6 Triumph 3
hondo402000 suggestions on Ignition coils Triumph 22
I Suggestions for tach gear rebuild? Spridgets 8
J rear brake rubbing, need suggestions Triumph 12
BugeyeNJ58 Need new ignition switch..Suggestions? Spridgets 3
I Adhesive suggestions? Spridgets 4
I Wax, rubbing compound suggestions Spridgets 10
AngliaGT Subaru Wagon Suggestions? Other Cars 8
I Suggestions for new Bugeye soft top? Spridgets 3
TomMull carburetors not pretty, cleaning suggestions neede Triumph 13
RAC68 Suggestions – LED Project Austin Healey 24
O Suggestions.. Austin Healey 8
tmc Battery suggestions Triumph 5
