TR6 Bumper stop on trailing arm - TR6
tr6web
I just got replacement bumper stops for the trailing arms (the ones right behind the backing plate. The manual says the screw on, but I tried to unscrew one and it ripped off revealing no screw hole. It's like it was glued on. Basically it's a round coin-like top, with a small round bump on top. The bumper was right on top of this . Is am I missing something?
71tr
Yes, I just did the same thing. Beneath the coin shaped item is a screw stud. The rubber bumper is glued to the coin which is attached to a screw. Use your vice grips and remove the coin/screw combo and refresh with the new stops.
tr6web
tr6web
Just finished rebuilding the rear and still can not get these darn things off. Anybody have other suggestions? They just don't budge.
71tr
Mine were pretty tight as well. I eventually ended-up tearing the rubber away from the metal base. I'd suggest a couple of whacks with a hammer against the side of the base plate then get some vice grips around the metal base itself.
Dugger
I had a very similar problem. I tried heat, penetrating oil, a hammer, and finally vise grips, all to no avail. Mine were frozen so bad, the the *coin* base twisted off leaving the stud in the swing arm. BTW: This happened to both sides. I was determined to mount these rubber bumpers in the arm and removed the swing arms from the car so that I could get my drill press into play. I failed miserably at the attempt; the tops of the broken bolts were recessed in the casting and were angled such that I could not get a drill bit to run straight. So, I mounted the bumpers to the contact shelf above by drilling a relief hole and welding a heavy washer and nut to the panel. I filled my nasty recess (and nasty drill holes) with JB weld and filed smooth for a decent contact area. Okay, its not original but it works and I actually think it is a better solution.
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
J Wanted Bumper Bracket Triumph Classifieds 2
C MGB Rubber Bumper cover removal MG 5
af3683 TR2/3/3A TR-2 / TR-3 Rear Bumper Wrap Around Fender Guards Identification Triumph 0
S 1958 100/6 Bumper Brackets Color Austin Healey 2
T Can anyone identify this bumper Spridgets 5
B TR4/4A Dumb Bumper questions Triumph 4
FlyingCat Wanted 1980 Spitfire Rear Bumper Triumph Classifieds 2
F TR2/3/3A Bumper frame brackets Triumph 10
F TR2/3/3A Bumper bracket to frame question Triumph 7
R Wanted WTB TR-3A front bumper brackets [pr] Triumph Classifieds 6
W XJ6 Series I bumper swap to Series II Jaguar 0
K For Sale Triumph TR3A front bumper and overiders Triumph Classifieds 0
B MGA Front bumper solution!! MG 1
HealeyPassion Rear bumper mod.... Austin Healey 5
Paulus TR6 Bumper Bars - what is the correct terminology Triumph 3
B TR2/3/3A Front Bumper Brackets Triumph 5
K For Sale TR3 support springs [bracket to bumper] Triumph Classifieds 2
H Wanted 1970 MGB rear bumper irons MG Classifieds 0
B Wanted TR3A Front Bumper Support Brackets Triumph Classifieds 1
RickPA Mounting number plate on front bumper Austin Healey 4
R TR2/3/3A TR-2 Front Bumper Brackets & Front and Rear Overriders Triumph 1
Jim_Stevens TR2/3/3A Rear bumper bolts size/thread? Triumph 3
N Bumper bracket and fan shroud color Austin Healey 5
T TR6 TR6 Rear Bumper Bar Triumph 1
L Tying cans to the bumper??? Austin Healey 14
K TR2/3/3A Rear bumper over rider set up. Triumph 2
HalLucy Wanted Renown Rear Bumper Overriders Triumph Classifieds 0
Got_All_4 TR6 Rear Bumper removal 1970 TR6 Triumph 3
Kleykamp Rubber bumper Midget value? Spridgets 5
JPSmit Rubber Bumper MGB Spotted 0
J For Sale Windshield, side curtains, bumper Spridgets Classified 13
A Wanted Front Bumper Brackets/Spring bar assembly for 100-6 Austin Healey Classifieds 0
J TR2/3/3A Blade-less bumper in TR3A Triumph 1
JPSmit Red Rubber Bumper Midget Spotted 0
kennypinkerton MGB Rubber bumper weight surprise.. MG 4
Basil Chrome Bumper MGB Spotted 1
M TR6 TR6 rear bumper Triumph 0
T To use front bumper on Bugeye or not? Spridgets 29
Bob Claffie MGB Bumper removal MG 1
M TR4/4A Front Bumper for TR4 Wanted. Triumph 3
cmacmillan TR6 Rear bumper removal - TR6 Triumph 10
2billydavies TR2/3/3A anybody need a spare rear bumper? Triumph 8
JPSmit Rubber bumper Midget Spotted 4
M TR4/4A Bumper over- rider fitment assistance please. Triumph 9
M TR4/4A TR4 Bumper Support Bracket...Help Please. Triumph 2
K TR2/3/3A Rear bumper overiders? Triumph 3
M TR4/4A TR4A & 250 front bumper guards Triumph 5
