SCguy
I'm finally getting around to repairing some new ebay trailing arms using Rick Patton's jig and KeenSerts. The directions look straight forward. My question is on installing the studs into the new KeenSert threads.
1. Should I use Locktight on the threads of the studs?
2. How or what is the best technique for installing the studs into the trailing arms? In other words. How tight do I install the studs? Do I put two nuts onto the end of them and then tork to 15lbs?
