TR6 TR6 REAR TRAILING ARMS AND BETTER HANDLING
ALLAN
J.K.JACKSON (TR6 GURU FROM FLORIDA) SAID IN AN ARTICLE IN GRASSROOTS MOTORSPORTS THAT LATE MODEL (74 AND NEWER TRAILLING ARMS) ALLOW THE CAR TO HANDLE BETTER THAN EARLY MODEL ARMS--DOES ANYBODY KNOW ANYTHING ABOUT THIS OR WHY IT IS TRUE, HE WAS REFERING TO THE ARMS THEM SELVES AND NOT THE MOUNTING BRACKETS. THEY ALL LOOK THE SAME TO ME!!
vrod
I am not aware of any differences in the trailing arms but do know there are different brackets used between the early and late models. The difference is in the location of the trailing arm mounting holes between the inner and outer brackets which control your wheels camber setting.
RobT
Perhaps its not the trailing arms themselves but the half-axle splines that were redesigned in the later TR6. I could well be wrong but I seem to remember something like this. It would prevent lock-up of these under power.
Simon TR4a
Interesting question, I do not remember reading that.
I will ask about this on the Triumph racing board, where Tim Suddard and JK (and Kas Kastner) are members, should get an answer by tomorrow.
Simon.
A
ALLAN
THIS WAS IN A GRASSROOTS ARTICLE FROM ABOUT 6 YEARS AGO, AND HE SPECIFICALY MENTIONED THE TRAILING ARMS AND NOT THE BRACKETS OR SHAFTS. ALLAN
trboost
Hi All,
Just for the heck of it I looked in the TRF green book & they show only one part # for the trailing arms. I guess that doesn't mean that all the years were cast the same but only that they were probably interchangable. I've had a 69, 71 & 74 & can't recall any obvious differances. The chassis pick up points are the same. If there was a maunfacturing design change I'll bet it was for strength. The earlier trailing arms were prone to stress cracks.
Simon TR4a
Allan I got two responses both indicating no differences except in the bumpstop; however I have heard of people using Corvair rear hubs on TR6s if they are used for track driving, this is probably to improve durability not handling.
Polyurethane bushings on the trailing arms will prevent unwanted toe-in changes. Also, do the alignment of the car with about 200lbs on the seats, representing the driver, so you get the camber settings correct. A careful alignment with a little negative camber at the front will improve turn in on corners.
Simon, (by the way, your capslock is stuck on.)
T Wanted TR6 rear trailing arms Triumph Classifieds 1
I TR6 TR6 rear hub and trailing arm spares advice Triumph 2
G TR6 Rear suspension [trailing arm] adjustment on a TR6 Triumph 18
S TR6 1974 TR6 Rear Brakes w/o hydr. press. Triumph 6
R For Sale TR6 REAR AXLE HUBS Triumph Classifieds 0
R For Sale TR6 REAR DIFFERENTIAL Triumph Classifieds 3
edkap2002 TR6 TR6 rear pinion seal Triumph 3
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 15
mctriumph For sale rear wings Tr6 Triumph Classifieds 3
mctriumph Have a pair of tr6 rear wings Triumph Classifieds 0
EWD TR6 74 TR6 - Rear and windshield frame color Triumph 2
EWD TR6 Rear Transmission Seal 74 TR6 Triumph 4
Got_All_4 TR6 drill and tap for a grease fitting tr6 rear hub assembly Triumph 4
J TR6 1973 TR6 Rear Brake Operation Questions Triumph 4
T TR6 TR6 Rear Bumper Bar Triumph 1
Got_All_4 TR6 Rear Bumper removal 1970 TR6 Triumph 3
M TR6 TR6 rear bumper Triumph 0
cmacmillan TR6 Rear bumper removal - TR6 Triumph 10
GBRandy TR6 1973 TR6 Rear Frame / Body Bushings Triumph 3
T TR4/4A Under the been there - done that school of learning: TR6 rear springs on a TR4a Triumph 12
T TR6 TR6 aftermarket rear shocks Triumph 35
W TR6 tr6 rear hubs Triumph 3
F TR6 TR6 HARDTOP GLASS [rear] Triumph 7
D TR6 76 TR6 Rear Brake Installation Triumph 17
hondo402000 TR6 New rear wheel cylinder leaking, TR6 Triumph 0
D TR6 76 TR6 Rear Right Brake Line Triumph 8
J TR6 rebuilding tr6 rear hubs Triumph 13
T TR6 Passenger side TR6 rear clunk? Triumph 9
W TR6 broken bleeder on rear brakes tr6 Triumph 12
S TR6 tr6 rear shock part number ??? Triumph 5
Coyote1 TR6 TR6 Rear Springs ? Triumph 11
Pete_Chadwell TR6 TR6 Rear Hub question, plus gearbox vibe Triumph 8
O TR6 TR6 Rear Valance ID Triumph 1
TR6oldtimer TR6 TR6 windscreen and rear flat black Triumph 4
SherpaPilot TR6 TR6 Rear Axle Bearing Question Triumph 10
B TR6 TR6 rear axle oil change Triumph 21
T TR6 Anyone use TR6 rear springs in their TR4a IRS? Triumph 8
glemon TR6 TR250 TR6 Rear Springs Triumph 13
S TR6 Rear suspension TR6 Triumph 8
hondo402000 TR6 NEEDED rear light socket TR6 for reverse lamp Triumph 10
hondo402000 TR6 TR6 Rear Paint, Satin Black Triumph 8
hondo402000 TR6 TR6 rear body Black paint help Triumph 9
B TR6 Rear-ended today and my beautiful TR6 is smashed.. Triumph 18
T TR6 TR6 rear sway bar question Triumph 6
T TR6 Is this a TR6 rear sway bar? Triumph 10
B TR6 Removal and Replacement of TR6 rear deck Triumph 3
T TR6 tr6 rear noise Triumph 8
I TR6 Rear brake drum temperature TR6 Triumph 13
I TR6 Rear wheel bearing help TR6 Triumph 6
