TR6 How do I grease TR6 trailing arm u-joints?
ichthos
I put my driver side suspension system back together this weekend. I thought I had done a good job, but then I noticed that I have access to the inner u-joint grease fitting (near the differential) but not the outer one (the one inside the trailing arm. I used the heavy duty Goodparts u-joints with the zert fitting on the cap. Is there a trick to getting a grease gun in this area? I did not add any extra grease before I installed it - is this something I need to worry about? I am not crazy about it, but should I remove the outer axle from the trailing arm, add more grease, and then reinstall it? I still have the passenger side to complete, so this information would be especially helpful. Thanks,
Kevin
T
Tinster
When you figure out a method- take photos and write up
a "How to"
dalw
DougF
It's that way so you will remember to grease the splines...sounds good.
I
ichthos
OK - not the information I was hoping to hear. Is not being able to lube the u- joint a design flaw? Why couldn't a small hole be drilled through the trailing arm? Is there a 90 degree grease fitting that could fit into the u-joint cap so that it could be reached from the inside part of the trailing arm? Also, I used all new fastners as Dale suggested. Do I need to buy new locking nuts again now that I will be removing them to lube the inner u-joint?
Kevin
T
Tinster
Kevin- do not ever, ever use locking nuts again after you remove them. Go to a speciality fastener shop and purchase
a bagful of 5/16", 1/2" and 9/16 locknut of appropriate threads. That way you'll always have some.
d
TR6BILL
Original Equipment U-joints did not have grease fittings. That is how you grease them. Did you grease them when you first installed the TRF units? Then forget about it and move on to more important things in life, like universal health care or something......
BobbyD
Goodparts now sells "Heavy Duty U-Joint, w/ Performance Dynamics Joints" with his upgraded axles. I think they are permanently greased. Drop him an email and see if he sells them for standard axles.
But actually greasing them is as simple as unscrewing the 6 nuts holding the hub in place and pulling it forward enough to get to the zerk.
I always replace nyloc nuts but I've been told re-using once is no big deal. Having said that...... I buy them by the box from McMaster.... a box of 10 Grade 8 for $4.75.
Good time to redo all those axle studs ......... though Dale will disagree
And if you pull those axles apart, make sure you pack them with grease to avoid any clunks.
T
Tinster
Won't argue with ya BobbyD since I know almost nothin
about auto mechanics. It ain't my skill set.
But it sure half scared me to death and almost gave me
a case of "brown shorts" when my rear wheel came off
at 40 mph going around a gentle bend in the road.
Why? The six wheel studs were held in place with
aftermarket inserts and the inserts pulled out.
Just my personal experience with wheel stud inserts.
I bow to your and Paul Rego's kings of the mechanical
hill skills.
Please take no offense. If your design works and no wheels
fall off after a 12 month trial period, I will probably
install them in my car. The theory looks sound.
d
Got_All_4 TR6 drill and tap for a grease fitting tr6 rear hub assembly Triumph 4
B TR6 Oil in a grease gun for TR6 lower steering swivel? Triumph 16
G TR6 TR6 Grease seal Triumph 7
C TR6 TR6 speedo and bushing grease ? Triumph 3
L Red Rubber Brake Grease Austin Healey 2
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
drooartz What am I seeing - oil/grease on wheel Spridgets 20
Hangtown Healey King Pin Bushings Grease Groove Austin Healey 8
K TR2/3/3A Girling red grease that used to come with brake cylinder rebuild kits? Triumph 7
K TR2/3/3A The grease gun brake caliper piston removal trick..... Triumph 6
S TR2/3/3A Putting dish soap in the radiator to remove grease Triumph 10
M TR2/3/3A Rear Axle Bearing Grease Triumph 5
T TR2/3/3A Steering box oils - grease ? Triumph 20
Jayplum TR2/3/3A Grease cap Triumph 25
K For Sale Original Grease gun and jack....complete your TR3 collection. Triumph Classifieds 0
AUSMHLY Grease type for zerk fittings Austin Healey 7
warwick-steve Missing grease cap in front hub Austin Healey 8
warwick-steve Front hub bearing grease repacking Austin Healey 28
S Grease Gun Recommendation? Spridgets 7
steveg Recycling grease question Austin Healey 11
R grease for windshield wiper motor- BJ7 Austin Healey 4
D TR2/3/3A grease nipple/zerk Triumph 6
C TR2/3/3A Grease Zerks Triumph 7
S TR4/4A how ro grease steering box? Triumph 4
C General Tech Grease and Grease Gun recommendations Triumph 12
Martinld123 Grease Retaining Cup Not Tight Fit Austin Healey 2
CJD TR2/3/3A Grease Gun Color Triumph 9
N Lockheed brake assembly grease??? Spridgets 2
T TR5/TR250 Is it good or bad idea to grease an overdrive angle drive? Triumph 2
Popeye TR4/4A TR4A front brake caliper rebuild - grease on rubber seals? Triumph 5
P TR6 Grease job Triumph 6
Popeye TR4/4A Stub axle - grease or no grease? Triumph 4
T TR4/4A Front hub grease cap sizing - anyone had a cross reference part # for a FLAPS? Triumph 2
M Oil Gun vs Grease Gun Spridgets 21
tahoe healey dielectric grease Austin Healey 13
S How much grease for the drive [prop] shaft plunger Austin Healey 3
T TR2/3/3A Windshield Wiper Motor Grease Triumph 4
S Plugged Grease Zerks Spridgets 7
S Will copper grease work for squeeling brakes? Austin Healey 3
charleyf TR2/3/3A Rear axle grease Triumph 0
K TR2/3/3A Greasing the idler arm grease zirk??? Triumph 3
R TR2/3/3A Grease fitting list Triumph 5
simon1966 Current day grease choices? Austin Healey 3
RJS TR4/4A Grease for IRS Axle Shaft Splines Triumph 5
RJS General TR U-Joint Grease fitting interferes Triumph 4
S Correct way to remove grease retaining cup from front hub? Austin Healey 7
AUSMHLY Distributor grease Austin Healey 2
K TR2/3/3A Front wheel bearing grease seal with felt packing? Triumph 4
K TR2/3/3A Trunnion oil/grease again? Triumph 1
brohawk TR6 Grease on rear hubs Triumph 8
