TR2/3/3A Grease fitting list
RC64
Within the last year or so I saw a list of the standard grease fittings on a TR-3. I'm getting close to having my restored TR-3 on the road and I want to make sure that I've properly serviced everything that takes grease. Can anyone point me to that list?
Rick...
Geo Hahn
The one fitting I missed for years is the one on the slider on the propshaft. Even after you are aware of it -- not the easiest zerk to find and get a gun on.
mrv8q
I love how zerks can be changed out to improve access to lube points. I bought a set of 45 and 90 zerks at NAPA, years back, for just this thing....
Got_All_4 TR6 drill and tap for a grease fitting tr6 rear hub assembly Triumph 4
RJS General TR U-Joint Grease fitting interferes Triumph 4
Tinkerman TR2/3/3A Water pump grease fitting. 60 TR3A post 60, 000 Triumph 4
S TR2/3/3A rear axle grease fitting tr3 Triumph 6
Jim_Gruber 2nd Grease Fitting on Fulcrum Pin Spridgets 5
T grease fitting in steering box Austin Healey 3
T Grease fitting ?? Triumph 24
B A- Arm - Fulcrum Grease fitting Spridgets 10
J TR2/3/3A Grease fitting access on front driveshaft TR3A Triumph 3
L Red Rubber Brake Grease Austin Healey 2
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
drooartz What am I seeing - oil/grease on wheel Spridgets 20
Hangtown Healey King Pin Bushings Grease Groove Austin Healey 8
K TR2/3/3A Girling red grease that used to come with brake cylinder rebuild kits? Triumph 7
K TR2/3/3A The grease gun brake caliper piston removal trick..... Triumph 6
S TR2/3/3A Putting dish soap in the radiator to remove grease Triumph 10
M TR2/3/3A Rear Axle Bearing Grease Triumph 5
T TR2/3/3A Steering box oils - grease ? Triumph 20
Jayplum TR2/3/3A Grease cap Triumph 25
K For Sale Original Grease gun and jack....complete your TR3 collection. Triumph Classifieds 0
AUSMHLY Grease type for zerk fittings Austin Healey 7
warwick-steve Missing grease cap in front hub Austin Healey 8
warwick-steve Front hub bearing grease repacking Austin Healey 28
S Grease Gun Recommendation? Spridgets 7
steveg Recycling grease question Austin Healey 11
R grease for windshield wiper motor- BJ7 Austin Healey 4
D TR2/3/3A grease nipple/zerk Triumph 6
C TR2/3/3A Grease Zerks Triumph 7
S TR4/4A how ro grease steering box? Triumph 4
C General Tech Grease and Grease Gun recommendations Triumph 12
Martinld123 Grease Retaining Cup Not Tight Fit Austin Healey 2
CJD TR2/3/3A Grease Gun Color Triumph 9
N Lockheed brake assembly grease??? Spridgets 2
T TR5/TR250 Is it good or bad idea to grease an overdrive angle drive? Triumph 2
Popeye TR4/4A TR4A front brake caliper rebuild - grease on rubber seals? Triumph 5
P TR6 Grease job Triumph 6
Popeye TR4/4A Stub axle - grease or no grease? Triumph 4
T TR4/4A Front hub grease cap sizing - anyone had a cross reference part # for a FLAPS? Triumph 2
M Oil Gun vs Grease Gun Spridgets 21
tahoe healey dielectric grease Austin Healey 13
S How much grease for the drive [prop] shaft plunger Austin Healey 3
T TR2/3/3A Windshield Wiper Motor Grease Triumph 4
S Plugged Grease Zerks Spridgets 7
S Will copper grease work for squeeling brakes? Austin Healey 3
charleyf TR2/3/3A Rear axle grease Triumph 0
K TR2/3/3A Greasing the idler arm grease zirk??? Triumph 3
simon1966 Current day grease choices? Austin Healey 3
RJS TR4/4A Grease for IRS Axle Shaft Splines Triumph 5
S Correct way to remove grease retaining cup from front hub? Austin Healey 7
AUSMHLY Distributor grease Austin Healey 2
