Solid state conversion of Lucas regulator
M
Member 10617
I'm looking for information on solid state conversion of a Lucas regulator. What has been the experience with these units? Pros and cons? Who does the conversion?
Many thanks.
dklawson
Are you inquiring about the generator control box? There is a good write-up on that at the MGA Guru web site.
One or two members here have made that conversion and at last report they liked it. Hopefully they will see your post soon and reply.
M
Member 10617
I had this advertisement and have tried to telephone Mr. Jeffers, but no answer. The add dates to 2005, so I wonder if the fellow is still in the business. If he is, I'll inquire about the conversion.
But it would also be great to know what experience people have had these units. For the moment, I'm not having any great problem with my new Lucas regulator, but I constantly hear how poor and undependable they are. The folks at my shop went through three new regulators before they found one that worked properly!
M
Member 10617
Bob Jeffer returned my call and has let me know the information he would need from me if I decided to have the conversion done.
Still would like some input from people who have made the conversion and used these solid state units. Pros and cons.
Many thanks.
dklawson
I can't remember the name of the last guy who installed this conversion. What I do remember is that he is from Hawaii and starts all his posts with "Aloha". Randall might remember his name.
MGTF1250Dave
Aloha Ed,
I've had Bob convert one of mine to a solid state unit that I use in my TR3A daily driver. I've been using it probably for a year now. It works fine for me and I've had no problems it. Installed in the car, it will look original until you remove the cover. I will soon have Bob convert the original, but not working control box for my MG TF.
C AUF214 solid state conversion question British Motor Corp 0
MGTF1250Dave Solid State Voltage Regulator Conversion Triumph 9
R Solid state SU Fuel Pump Austin Healey 2
BobbyD New OD Controller & Solid State Rheostat Triumph 0
coj Solid state turn and brake box Austin Healey 7
V Solid state fuel pump question Spridgets 2
bighealeysource Noisy solid state fuel pump Austin Healey 15
MGTF1250Dave Solid State Voltage Regulator Up-date Triumph 7
vping Installing a Solid State Fuel Pump MG 7
B MOSS solid state fuel pump Spridgets 3
ronzet Flame Thrower solid state distributor for my A MG 12
vping Anyone use a solid state fuel pump? MG 35
6 Solid State SU Fuel Pump Ticking: Constant? Austin Healey 4
AUSMHLY Su Solid state fuel pump Austin Healey 26
V For Sale Hard Top and Solid Walnut Dash for Sale Triumph Classifieds 2
KVH General Tech Rear Brakes and Solid Axle Triumph 2
T Wanted Looking for a solid [but doesn't have to be perfect] 100-6 Austin Healey Classifieds 17
D TR4/4A Seals on TR4 Solid Rear Axle Triumph 5
KVH TR4/4A Removing Rear Differential Seal--Solid Axle Triumph 1
T TR4/4A Differential clatter-solid axle Triumph 4
Popeye TR4/4A TR4A solid axle rear leaf spring question Triumph 14
N Spitfire Question on solid steering rack mounts! Triumph 3
richie TR4/4A Wheel fitment on TR4a solid axle vs IRS Triumph 6
T TR4/4A Refreshing solid axle TR4a rear bushings Triumph 4
T Tvr 2500m For Sale, Nice Original Solid Example. TVR 1
Stinger TR4/4A TR4A Wood Dash Plywood or Solid Wood Triumph 13
T TR4/4A Which TR4a is better - IRS or solid axle? Triumph 30
hymodyne rubber, poly vs solid steering rack bushings Triumph 12
PAUL161 Solid Throttle Disk for HIFs MG 7
Banjo TR4/4A TR4A solid rear axle, axle. free Triumph 8
T GT6 GT6+ - could be a solid car Triumph 22
J TR4/4A TR4A Solid Axle Rear Brake Backing Plates Triumph 17
BugEyeBear Nice Solid BugEye on eBay [not mine...] Spridgets 8
Morris Solid core wire Spridgets 6
J TR4/4A TR4A solid axle assembly Triumph 15
B solid looking project for someone Spridgets 7
B solid bronze TW Spridgets 1
T TR4/4A 4A IRS tub on 4A solid axle frame? Triumph 2
Westfield_XI Solid mounted Spridget transmission Spridgets 0
T TR4/4A TR4a [solid axle] rear twitch-iness question Triumph 15
D E-type solid rack mounts? Jaguar 6
Banjo TR4/4A TR4A solid axle rear end for sale Triumph 0
racing girl How Many Of You Use A Solid Neck/Shoulder Brace? Racing 3
M Solid color or 2 tone paint Austin Healey 8
Banjo TR4/4A Soon to be parting a TR4A solid axle Triumph 1
beaulieu solid wheel knock-offs , do they exhist ? Restoration & Tools 11
T Solid Sway Bar bushing mounts Spridgets 2
3 Solid vs. poly vs. stock rack mounts. Triumph 10
R rusty but solid seat bottom Spridgets 4
Basil Seriously considering solid stainless cylinders Jaguar 9
