Solid State Voltage Regulator Conversion
MGTF1250Dave
Aloha,
I am considering converting a mechanical two spool Lucas voltage regulator to a solid state electronic regulator. I would have the job done by someone who does this professionally. The one I would have converted is not operable. Does anyone have experience operating with this conversion?
Adrio
I have made one and it worked just fine. Though my only use was for the electric temp guage in my TR3. That car was suppose to have a mechanical (either bulb) guage but I only had a early TR4 electric one. What i did was put the sender in a pot of water on the stove and got the resistance vs. temperature figures for it. Then I set up a bench test for the guage itself and got a current vs. temperature reading curve for it. Combining those two curves I was able to determine what the voltage of the regulator had to be. I am at work now (no comments) so I can't get you the value it worked out to (was many years ago) but I do remember it was an even value or at least a normal value as I was able to build it with a single unit three pin voltage regulator chip 9and positive ground to boot). If you want the values I can look them up for you this weekend. Just PM me (or do a search on here I may have posted the results way back when).
angelfj1
MGTF1250Dave said:
Aloha,
Hello Dave. Just to confirm, are you thinking of retaining the Lucas dynamo or converting to an alternator. Here's and example of a solid state replacement for the Lucas "box". Not expensive at $80.
solid state voltage regulator
Of course, modern alternators have internal solid state control for excitation, so the "box" would not be required.
MGTF1250Dave
MGTF1250Dave
Aloha Adrio,
Thanks for the reply. I have rebuilt a 10VDC voltage stabilizer for the Temp and Fuel guage as you describe. I guess I didn't make it clear I was asking about the Dynamo/Battery voltage regulator or control box. This is a conversion of the Lucas RB106 control box to a solid state electronics.
P.S. I found a source for the three pin stabilizer but I have to look at home for the website address. I think they were about $1 to $2 each.
MGTF1250Dave
MGTF1250Dave
Aloha Frank,
I was planning on keeping the Dynamo. Your link is to where I was planning to have the conversion made. Seems to me I would eliminate points in the control box arching and sticking. I can retain the original look and have a replacement with no moving parts.
TR3driver
Great Pumpkin - R.I.P
Even more important IMO, eliminate overcharging when the load is light, and undercharging when the load is heavy (headlights on). Of course, you could also do that by converting to a 3-bobbin unit, like the one used on Vitesse, Spitfire and I believe GT6.
Shame you're not doing it yourself, as I think it would be an interesting DIY project. But please do keep us informed of how it turns out!
MGTF1250Dave
MGTF1250Dave
Aloha Randall,
I know enough about electronics to know I need help. As Harry Callahan said, "A man's got to know his limitations". I know I can not solder components to a circuit card. I'll let everyone know if it works out.
Another reason I am thinking about this is that I can use the carcass of the car's original Lucas Control Box.
Sarastro
I think this makes a lot of sense. I was going to do it with my Bugeye Sprite, to preserve the original appearance and not have to modify the tach. I had actually designed the thing and started testing it (I'm an electrogeek), but eventually I just switched to an alternator.
That mechanical regulator, you have to realize, is really crude. The simplest electronic regulator should be way better; it would be hard to do worse.
One consideration that was a dilemma for me: the transistors in the regulator handle a fair amount of power and therefore probably generate a lot of heat. There has to be some way to get rid of it. Clamping it into that bakelite box is prevents the heat from escaping. You might ask the maker how he handles the heat sinking.
TR3driver
If you zoom in on the photo on the website referenced above, I think you'll see an aluminum plate mounted vertically that serves as heat sink. The field control is undoubtedly done with a power MOSFET for minimum forward resistance; and of course operates in switching mode to keep power dissipation to a minimum.
MGTF1250Dave Solid State Voltage Regulator Up-date Triumph 7
C AUF214 solid state conversion question British Motor Corp 0
R Solid state SU Fuel Pump Austin Healey 2
BobbyD New OD Controller & Solid State Rheostat Triumph 0
coj Solid state turn and brake box Austin Healey 7
V Solid state fuel pump question Spridgets 2
M Solid state conversion of Lucas regulator Triumph 9
bighealeysource Noisy solid state fuel pump Austin Healey 15
vping Installing a Solid State Fuel Pump MG 7
B MOSS solid state fuel pump Spridgets 3
ronzet Flame Thrower solid state distributor for my A MG 12
vping Anyone use a solid state fuel pump? MG 35
6 Solid State SU Fuel Pump Ticking: Constant? Austin Healey 4
AUSMHLY Su Solid state fuel pump Austin Healey 26
V For Sale Hard Top and Solid Walnut Dash for Sale Triumph Classifieds 2
KVH General Tech Rear Brakes and Solid Axle Triumph 2
T Wanted Looking for a solid [but doesn't have to be perfect] 100-6 Austin Healey Classifieds 17
D TR4/4A Seals on TR4 Solid Rear Axle Triumph 5
KVH TR4/4A Removing Rear Differential Seal--Solid Axle Triumph 1
T TR4/4A Differential clatter-solid axle Triumph 4
Popeye TR4/4A TR4A solid axle rear leaf spring question Triumph 14
N Spitfire Question on solid steering rack mounts! Triumph 3
richie TR4/4A Wheel fitment on TR4a solid axle vs IRS Triumph 6
T TR4/4A Refreshing solid axle TR4a rear bushings Triumph 4
T Tvr 2500m For Sale, Nice Original Solid Example. TVR 1
Stinger TR4/4A TR4A Wood Dash Plywood or Solid Wood Triumph 13
T TR4/4A Which TR4a is better - IRS or solid axle? Triumph 30
hymodyne rubber, poly vs solid steering rack bushings Triumph 12
PAUL161 Solid Throttle Disk for HIFs MG 7
Banjo TR4/4A TR4A solid rear axle, axle. free Triumph 8
T GT6 GT6+ - could be a solid car Triumph 22
J TR4/4A TR4A Solid Axle Rear Brake Backing Plates Triumph 17
BugEyeBear Nice Solid BugEye on eBay [not mine...] Spridgets 8
Morris Solid core wire Spridgets 6
J TR4/4A TR4A solid axle assembly Triumph 15
B solid looking project for someone Spridgets 7
B solid bronze TW Spridgets 1
T TR4/4A 4A IRS tub on 4A solid axle frame? Triumph 2
Westfield_XI Solid mounted Spridget transmission Spridgets 0
T TR4/4A TR4a [solid axle] rear twitch-iness question Triumph 15
D E-type solid rack mounts? Jaguar 6
Banjo TR4/4A TR4A solid axle rear end for sale Triumph 0
racing girl How Many Of You Use A Solid Neck/Shoulder Brace? Racing 3
M Solid color or 2 tone paint Austin Healey 8
Banjo TR4/4A Soon to be parting a TR4A solid axle Triumph 1
beaulieu solid wheel knock-offs , do they exhist ? Restoration & Tools 11
T Solid Sway Bar bushing mounts Spridgets 2
3 Solid vs. poly vs. stock rack mounts. Triumph 10
R rusty but solid seat bottom Spridgets 4
Basil Seriously considering solid stainless cylinders Jaguar 9
