Solid State SU Fuel Pump Ticking: Constant?
62BT7
Hello all: I installed a solid state electronic SU fuel pump in my '62 BT-7 a few months ago. The pump is working fine, ie the car runs well both at idle and driving, including the freeway at higher speeds. Here's the issue: Once the ignition is on there's the usual SU ticking from the pump. Ordinarily with stock pumps the ticking stops after a few seconds, then I'd fire up the engine. With this new solid state pump it rapidly ticks, then slows significantly but never completely stops ticking. Maybe a tick every second or two. I've sealed & tightened every connection from the tank to the pump, including all threaded connections (with teflon tape), tightened all fuel clamps, new fuel lines, etc. No visible cracks in the pump body. Question: It seems the pump is slightly cavitating, but I thought I'd read somewhere in the distant past that the solid state pumps were different in that they never fully stopped ticking...??? Maybe I'm imagining that...Again, it runs fine but this is a pricey piece of gear that I don't want to burn out. Thoughts?
Keoke
Hi 62BT7, Sounds like it is ok to me. However, there are some aftermarket electronic pumps, Not SU's, that click all the time and those are the ones you probably heard being discussed. Or in some cases a bad input fuel line on a new SU install which lets the pump suck air and cycle continuously.---Keoke
bob hughes
I have never waited long enough after the pump has initially stopped to listen for residual ticks from my solid state pump, but I would have thought that it was not unusual to happen, to maintain pressure in the line.
Get her going and enjoy that deep throated sound.
Bob
dklawson
Send a PM to Dave DuBois on this board. He will know better than anyone what is normal for the electronic SU pumps.
Keoke
Bob
Yep Bob /bcforum/images/%%GRAEMLIN_URL%%/iagree.gif---------------------------------Keoke- /bcforum/images/%%GRAEMLIN_URL%%/thumbsup.gif
R Solid state SU Fuel Pump Austin Healey 2
V Solid state fuel pump question Spridgets 2
bighealeysource Noisy solid state fuel pump Austin Healey 15
vping Installing a Solid State Fuel Pump MG 7
B MOSS solid state fuel pump Spridgets 3
vping Anyone use a solid state fuel pump? MG 35
AUSMHLY Su Solid state fuel pump Austin Healey 26
C AUF214 solid state conversion question British Motor Corp 0
BobbyD New OD Controller & Solid State Rheostat Triumph 0
coj Solid state turn and brake box Austin Healey 7
M Solid state conversion of Lucas regulator Triumph 9
MGTF1250Dave Solid State Voltage Regulator Up-date Triumph 7
MGTF1250Dave Solid State Voltage Regulator Conversion Triumph 9
ronzet Flame Thrower solid state distributor for my A MG 12
V For Sale Hard Top and Solid Walnut Dash for Sale Triumph Classifieds 2
KVH General Tech Rear Brakes and Solid Axle Triumph 2
T Wanted Looking for a solid [but doesn't have to be perfect] 100-6 Austin Healey Classifieds 17
D TR4/4A Seals on TR4 Solid Rear Axle Triumph 5
KVH TR4/4A Removing Rear Differential Seal--Solid Axle Triumph 1
T TR4/4A Differential clatter-solid axle Triumph 4
Popeye TR4/4A TR4A solid axle rear leaf spring question Triumph 14
N Spitfire Question on solid steering rack mounts! Triumph 3
richie TR4/4A Wheel fitment on TR4a solid axle vs IRS Triumph 6
T TR4/4A Refreshing solid axle TR4a rear bushings Triumph 4
T Tvr 2500m For Sale, Nice Original Solid Example. TVR 1
Stinger TR4/4A TR4A Wood Dash Plywood or Solid Wood Triumph 13
T TR4/4A Which TR4a is better - IRS or solid axle? Triumph 30
hymodyne rubber, poly vs solid steering rack bushings Triumph 12
PAUL161 Solid Throttle Disk for HIFs MG 7
Banjo TR4/4A TR4A solid rear axle, axle. free Triumph 8
T GT6 GT6+ - could be a solid car Triumph 22
J TR4/4A TR4A Solid Axle Rear Brake Backing Plates Triumph 17
BugEyeBear Nice Solid BugEye on eBay [not mine...] Spridgets 8
Morris Solid core wire Spridgets 6
J TR4/4A TR4A solid axle assembly Triumph 15
B solid looking project for someone Spridgets 7
B solid bronze TW Spridgets 1
T TR4/4A 4A IRS tub on 4A solid axle frame? Triumph 2
Westfield_XI Solid mounted Spridget transmission Spridgets 0
T TR4/4A TR4a [solid axle] rear twitch-iness question Triumph 15
D E-type solid rack mounts? Jaguar 6
Banjo TR4/4A TR4A solid axle rear end for sale Triumph 0
racing girl How Many Of You Use A Solid Neck/Shoulder Brace? Racing 3
M Solid color or 2 tone paint Austin Healey 8
Banjo TR4/4A Soon to be parting a TR4A solid axle Triumph 1
beaulieu solid wheel knock-offs , do they exhist ? Restoration & Tools 11
T Solid Sway Bar bushing mounts Spridgets 2
3 Solid vs. poly vs. stock rack mounts. Triumph 10
R rusty but solid seat bottom Spridgets 4
Basil Seriously considering solid stainless cylinders Jaguar 9
