Solid state fuel pump question
V
vagt6
I'm thinking about replacing my MKIII Midget's original AZX1307 SU fuel pump with the solid state one in the Moss catalog.
However, the Moss pump in the catalog photo does not seem to have the flange going around the pump where the fuel pump bracket holds the pump to the underside of the chassis on my MKIII '74 Midget.
Question: is this pump a direct, bolt-on substitute or will I have to fabricate a new bracket?
Thanks, all!
Sarastro
I'm not familiar with that pump, but making a small bracket or otherwise remounting shouldn't be terribly difficult. If you're not going for the appearance of originality or something else special, there are loads of options for fuel pumps, virtually all of which are much less expensive than anything you'll get from Moss. There are a couple of threads right now discussing this.
V
vagt6
Thanks, Steve.
The electronic SU pump, Moss part #377-295/285, <span style="text-decoration: underline">WILL</span> require a different bracket on my '74 MKIII car. AND, it may not have the same fuel line attachment/hardware as the original SU pump. Haven't determined that yet . . .
I believe the original replacement SU pump for my car, a '74 MK III Midget, is Moss part 377-175. Does anyone know if this is correct?
The original, points-type pump in this case is at least 50% less expensive, I'm going with the original.
Unless someone has a better idea . . .
R Solid state SU Fuel Pump Austin Healey 2
bighealeysource Noisy solid state fuel pump Austin Healey 15
vping Installing a Solid State Fuel Pump MG 7
B MOSS solid state fuel pump Spridgets 3
vping Anyone use a solid state fuel pump? MG 35
6 Solid State SU Fuel Pump Ticking: Constant? Austin Healey 4
AUSMHLY Su Solid state fuel pump Austin Healey 26
C AUF214 solid state conversion question British Motor Corp 0
BobbyD New OD Controller & Solid State Rheostat Triumph 0
coj Solid state turn and brake box Austin Healey 7
M Solid state conversion of Lucas regulator Triumph 9
MGTF1250Dave Solid State Voltage Regulator Up-date Triumph 7
MGTF1250Dave Solid State Voltage Regulator Conversion Triumph 9
ronzet Flame Thrower solid state distributor for my A MG 12
V For Sale Hard Top and Solid Walnut Dash for Sale Triumph Classifieds 2
KVH General Tech Rear Brakes and Solid Axle Triumph 2
T Wanted Looking for a solid [but doesn't have to be perfect] 100-6 Austin Healey Classifieds 17
D TR4/4A Seals on TR4 Solid Rear Axle Triumph 5
KVH TR4/4A Removing Rear Differential Seal--Solid Axle Triumph 1
T TR4/4A Differential clatter-solid axle Triumph 4
Popeye TR4/4A TR4A solid axle rear leaf spring question Triumph 14
N Spitfire Question on solid steering rack mounts! Triumph 3
richie TR4/4A Wheel fitment on TR4a solid axle vs IRS Triumph 6
T TR4/4A Refreshing solid axle TR4a rear bushings Triumph 4
T Tvr 2500m For Sale, Nice Original Solid Example. TVR 1
Stinger TR4/4A TR4A Wood Dash Plywood or Solid Wood Triumph 13
T TR4/4A Which TR4a is better - IRS or solid axle? Triumph 30
hymodyne rubber, poly vs solid steering rack bushings Triumph 12
PAUL161 Solid Throttle Disk for HIFs MG 7
Banjo TR4/4A TR4A solid rear axle, axle. free Triumph 8
T GT6 GT6+ - could be a solid car Triumph 22
J TR4/4A TR4A Solid Axle Rear Brake Backing Plates Triumph 17
BugEyeBear Nice Solid BugEye on eBay [not mine...] Spridgets 8
Morris Solid core wire Spridgets 6
J TR4/4A TR4A solid axle assembly Triumph 15
B solid looking project for someone Spridgets 7
B solid bronze TW Spridgets 1
T TR4/4A 4A IRS tub on 4A solid axle frame? Triumph 2
Westfield_XI Solid mounted Spridget transmission Spridgets 0
T TR4/4A TR4a [solid axle] rear twitch-iness question Triumph 15
D E-type solid rack mounts? Jaguar 6
Banjo TR4/4A TR4A solid axle rear end for sale Triumph 0
racing girl How Many Of You Use A Solid Neck/Shoulder Brace? Racing 3
M Solid color or 2 tone paint Austin Healey 8
Banjo TR4/4A Soon to be parting a TR4A solid axle Triumph 1
beaulieu solid wheel knock-offs , do they exhist ? Restoration & Tools 11
T Solid Sway Bar bushing mounts Spridgets 2
3 Solid vs. poly vs. stock rack mounts. Triumph 10
R rusty but solid seat bottom Spridgets 4
Basil Seriously considering solid stainless cylinders Jaguar 9
