When I let off the throttle on my TR4 solid axle I get this loud clatter which goes away immediately by giving the car a little throttle. I pulled the diff cover plate and confirmed the pinion gear is hitting the carrier.
While I did replace the pinion seal, I rechecked the castle nut torque and it's 100 lbs.
Is it possible to pull the pinion gear away from the carrier without completely disassembling the diff?
Thanks!
Thanks!
