TR6 Differential ID year & output shaft removal
Got_All_4
This keeps getting worse. Anyway I made another post earlier about the hub diameter size well one needed turned and the other is cracked. To make matters worse the output shaft has a hug crack in it. Having a hard time figuring how it comes out. Miss placed my Haynes manual. Also I found yellow paint under all the crud and now need to know what year this could have come off of. Number on the diff is CD13817.
TRopic6
If the CD series started with the TR250/5, that would be from a 1969 TR6. Hopefully someone with an original drive train 69 TR6 can help.
titanic
I believe all of the inner axles are the same for TR250-6 and have a 3/8 keyway. The only difference might be the use of a castellated nut and cotter pin on the early ones vs nylock nut on the later ones. TR4A IRS axles have a 1/4" keyway. The left&right axles differ in length on all variations.
Berry
Got_All_4
Got_All_4
OK thanks Phil! After I wrote this I got into it some more and now it looks like a bearing rebuild. Axle bearing completely shot and the inners got to be going too as the entire inside looks like it is full of sand. Just from years of sitting around from the gear lube deteriorating. Almost looks like rust. Now I've never done a rear end before and if I dismantle it it has to be put back using dial indicators and shims. No clue how to do this.
Looking at the price of bearings and particularity Timken WOW. Moss is $129. Don't understand why so much.
philstr6
go to rock auto they have the best price
The hard one will be the 15100 sr timken
16150. 2each
16283. 2 each
3120. 1 each
3188. 1 each
15100sr 1 each
15245. 1 each
These are the bearings you need for the diff
I have spares on the 15100sr Timken
Phil
Got_All_4
Got_All_4
I don't know what I did wrong but didn't find them on Rock Auto. I will try Monday. However I did find them on Parts Geek. They had the 15100 but not the SR. I am still looking for a Timken bearing for the out put shaft. Moss # 525-100 and also found a pic of one that had this # on it LJ1-1/8. Haven't found that ether. Concerned about the quality of their bearing. It is accessible from outside the diff it's but it's the internals that I want the best parts. Getting too old for all this R&R stuff.
Phil I am interested in one of those 15100SR.
The 3188 is that the bearing for 3120?
TRopic6
I rebuilt a diff for a spare and was going to do another, but one was more than enough. I have some spare Timkens (but not the 15100SR) - will find the box tomorrow and let you know. Jeff
TRopic6
Phil, Looking at the bearings I have, there is a 3188S as well as 3188. Given the 15100 / 15100SR situation, is one better than the other?
Thanks - Jeff
S TR2/3/3A when rebuilding a differential Triumph 9
B TR2/3/3A Possible differential problem Triumph 3
S TR2/3/3A Placing the differential on the frame Triumph 4
S Spitfire Differential clicking Triumph 6
CARSINC For Sale Sprite Differential Spridgets Classified 0
S TR2/3/3A old 4 bolt axle differential. Triumph 11
T Rear/Differential "Clunk" Austin Healey 2
W TR2/3/3A Differential cover torque Triumph 4
G Spitfire Spitfire 1500 differential whining Triumph 6
B Midget Differential Capacity Spridgets 5
R Changing BJ7 Differential Ratio Austin Healey 10
R For Sale TR6 REAR DIFFERENTIAL Triumph Classifieds 3
A TR6 Installing differential and transmission Triumph 10
Sarastro TR4/4A Differential setup question Triumph 12
Ripper01 Sold- TR6 Differential drive Triumph Classifieds 1
Ripper01 For Sale Sold-TR6 Differential Triumph Classifieds 0
Michael Oritt Wanted 4.22:1 spridget differential Spridgets Classified 1
J TR6 TR6 Differential Rebuild question Triumph 6
J TR6 Differential / Rear Axle Triumph 1
71TR6 TR2/3/3A Locker Differential- I have one but what is it? Triumph 9
Got_All_4 TR6 Differential side hub measurement Triumph 1
edkap2002 TR6 differential mounts, rear springs and shocks Triumph 1
glemon General Tech Differential flange removal Triumph 11
DrEntropy Wanted Later ['67~'68] differential. MG Classifieds 0
J Flaking Paint Inside Differential Austin Healey 6
P TR2/3/3A Another Differential Question Triumph 22
P TR2/3/3A Differential question Triumph 6
DrEntropy MGB Differential with too much lash MG 5
J For Sale Triumph TR3 rear differential and rear brake assembly - Northern Illinois Triumph Classifieds 1
L Wanted Tr6 differential Triumph Classifieds 9
Lin Rear differential drain plug leak Austin Healey 16
P MGB Noisy Rear Axle / Differential MG 1
S TR2/3/3A Differential Gasket & Oil Leak Triumph 9
N Spitfire Changing Differential oil Triumph 14
R TR2/3/3A Sluge in Differential Triumph 21
J TR2/3/3A Differential Side Gear Backlash Triumph 3
J TR2/3/3A Differential Rebuild - Gear Markings Triumph 18
D Clutch-Type Differential Austin Healey 5
K TR2/3/3A Correct oil level for differential? Triumph 5
W Differential oil for 100/4 1954 Austin Healey 14
S For Sale Triumph tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
T Differential Pinion Bearings Austin Healey 0
H Third Member - Differential - Carrier Housing - Center Section - Gear Set Cleaning Spridgets 4
S For Sale Tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
oldbagpipe For Sale TR4 Detroit Locker Differential $1,000 Triumph Classifieds 3
