TR2/3/3A Differential Side Gear Backlash
Joel M
I need some advice on setting the differential side gear backlash. With the original thrust washers the backlash measures around 10-12 mils. The service manual does not list a spec, but this seems a bit high to me. So I ordered replacement planet gear thrust washers with minimum thickness available of 0.056" (the originals measured 0.042" thick). With the new washers, backlash is essentially zero and the resistance when turning the gears is about the same. I'm not that confident, but thinking this is probably okay and will wear in quickly. Any thoughts?
Joel
bobhustead
I would never have thought to be worried with this. Unless you have zero traction on one wheel and spin the other for a long time, these gears don't do very much work. If you are just putting back used gears, I would stay with whatever was there.
Bob
Herk
The later service manuals for IRS cars list a spec for the pinion gear lash. It's the same differential. Don't recall the exact number, but it's close to zero with fresh washers. Since you have the carrier out of the housing, resetting ring and pinion lash and pinion bearing preload would be time well spent.
Got_All_4 TR6 Differential side hub measurement Triumph 1
S TR2/3/3A when rebuilding a differential Triumph 9
B TR2/3/3A Possible differential problem Triumph 3
S TR2/3/3A Placing the differential on the frame Triumph 4
S Spitfire Differential clicking Triumph 6
CARSINC For Sale Sprite Differential Spridgets Classified 0
S TR2/3/3A old 4 bolt axle differential. Triumph 11
T Rear/Differential "Clunk" Austin Healey 2
W TR2/3/3A Differential cover torque Triumph 4
G Spitfire Spitfire 1500 differential whining Triumph 6
B Midget Differential Capacity Spridgets 5
R Changing BJ7 Differential Ratio Austin Healey 10
R For Sale TR6 REAR DIFFERENTIAL Triumph Classifieds 3
A TR6 Installing differential and transmission Triumph 10
Sarastro TR4/4A Differential setup question Triumph 12
Ripper01 Sold- TR6 Differential drive Triumph Classifieds 1
Ripper01 For Sale Sold-TR6 Differential Triumph Classifieds 0
Michael Oritt Wanted 4.22:1 spridget differential Spridgets Classified 1
J TR6 TR6 Differential Rebuild question Triumph 6
J TR6 Differential / Rear Axle Triumph 1
71TR6 TR2/3/3A Locker Differential- I have one but what is it? Triumph 9
Got_All_4 TR6 Differential ID year & output shaft removal Triumph 11
edkap2002 TR6 differential mounts, rear springs and shocks Triumph 1
glemon General Tech Differential flange removal Triumph 11
DrEntropy Wanted Later ['67~'68] differential. MG Classifieds 0
J Flaking Paint Inside Differential Austin Healey 6
P TR2/3/3A Another Differential Question Triumph 22
P TR2/3/3A Differential question Triumph 6
DrEntropy MGB Differential with too much lash MG 5
J For Sale Triumph TR3 rear differential and rear brake assembly - Northern Illinois Triumph Classifieds 1
L Wanted Tr6 differential Triumph Classifieds 9
Lin Rear differential drain plug leak Austin Healey 16
P MGB Noisy Rear Axle / Differential MG 1
S TR2/3/3A Differential Gasket & Oil Leak Triumph 9
N Spitfire Changing Differential oil Triumph 14
R TR2/3/3A Sluge in Differential Triumph 21
J TR2/3/3A Differential Rebuild - Gear Markings Triumph 18
D Clutch-Type Differential Austin Healey 5
K TR2/3/3A Correct oil level for differential? Triumph 5
W Differential oil for 100/4 1954 Austin Healey 14
S For Sale Triumph tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
T Differential Pinion Bearings Austin Healey 0
H Third Member - Differential - Carrier Housing - Center Section - Gear Set Cleaning Spridgets 4
S For Sale Tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
oldbagpipe For Sale TR4 Detroit Locker Differential $1,000 Triumph Classifieds 3
