Spitfire Differential clicking
succubusdad
Hello all, have a spitfire 1500. Let me first apologize for my unexperienced rambling. I have searched for my specific issue but can only find single "clunk" posts. I replaced my leaf spring and shocks as I had a sag. This appears to have opened up a new can of worms that hadn't noticed previously. The car drives and shifts fine but I notice now that when I let off the gas or in between shifts there is a "snaping" or "clunking" noise that is coming from rear that matches my speed. "Click click click click" Tires off and as I rotate both hubs back and forth there seems to be at least 1/4" of slack from the each of the shafts. I have checked all the fittings from the hubs up to the differential but the slack seems to be coming from inside the differential itself. First, I am almost certain this amount of slack is not normal. Second, could the increased stance from the new leaf spring cause the union of the differential gears to be misaligned, tensed or untensed? Third, I think I'm probably in trouble right?
bobhustead
The slack you describe is actually quite small. There are half a dozen bearings and cups, six gears, 4 surfaces supporting spider/axle gears and two splined axle connections to the axle gears in the diff. All these items wear and all of them contribute to slack action in the system.
The noise is another matter and needs to be tracked down. You may need to do a teardown to remove the third member to do so.
Bob
S
succubusdad
Bob
Thanks Bob, I do appreciate the response. I'll keep looking.
CJD
+1 on the slack. 1/4" measured at the outside of the hub is decent. When a differential goes bad it either whines or rumbles. A ticking sounds like maybe a brake line, cable, or shock may now be rubbing against a wheel. It could even be the rotor against the splash shield, if that got bent slightly.
sp53
If I remember correctly, there are 4 U joints on the rear of the Spitfire. I had a 71 and it had independent suspension, I think. This was in 1973 long time ago. Anyways, I would look at those first. Grab them with both hands and see if they click or move. Perhaps lube them and see if anything temporally changes.
steve
S TR2/3/3A when rebuilding a differential Triumph 9
B TR2/3/3A Possible differential problem Triumph 3
S TR2/3/3A Placing the differential on the frame Triumph 4
CARSINC For Sale Sprite Differential Spridgets Classified 0
S TR2/3/3A old 4 bolt axle differential. Triumph 11
T Rear/Differential "Clunk" Austin Healey 2
W TR2/3/3A Differential cover torque Triumph 4
G Spitfire Spitfire 1500 differential whining Triumph 6
B Midget Differential Capacity Spridgets 5
R Changing BJ7 Differential Ratio Austin Healey 10
R For Sale TR6 REAR DIFFERENTIAL Triumph Classifieds 3
A TR6 Installing differential and transmission Triumph 10
Sarastro TR4/4A Differential setup question Triumph 12
Ripper01 Sold- TR6 Differential drive Triumph Classifieds 1
Ripper01 For Sale Sold-TR6 Differential Triumph Classifieds 0
Michael Oritt Wanted 4.22:1 spridget differential Spridgets Classified 1
J TR6 TR6 Differential Rebuild question Triumph 6
J TR6 Differential / Rear Axle Triumph 1
71TR6 TR2/3/3A Locker Differential- I have one but what is it? Triumph 9
Got_All_4 TR6 Differential ID year & output shaft removal Triumph 11
Got_All_4 TR6 Differential side hub measurement Triumph 1
edkap2002 TR6 differential mounts, rear springs and shocks Triumph 1
glemon General Tech Differential flange removal Triumph 11
DrEntropy Wanted Later ['67~'68] differential. MG Classifieds 0
J Flaking Paint Inside Differential Austin Healey 6
P TR2/3/3A Another Differential Question Triumph 22
P TR2/3/3A Differential question Triumph 6
DrEntropy MGB Differential with too much lash MG 5
J For Sale Triumph TR3 rear differential and rear brake assembly - Northern Illinois Triumph Classifieds 1
L Wanted Tr6 differential Triumph Classifieds 9
Lin Rear differential drain plug leak Austin Healey 16
P MGB Noisy Rear Axle / Differential MG 1
S TR2/3/3A Differential Gasket & Oil Leak Triumph 9
N Spitfire Changing Differential oil Triumph 14
R TR2/3/3A Sluge in Differential Triumph 21
J TR2/3/3A Differential Side Gear Backlash Triumph 3
J TR2/3/3A Differential Rebuild - Gear Markings Triumph 18
D Clutch-Type Differential Austin Healey 5
K TR2/3/3A Correct oil level for differential? Triumph 5
W Differential oil for 100/4 1954 Austin Healey 14
S For Sale Triumph tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
T Differential Pinion Bearings Austin Healey 0
H Third Member - Differential - Carrier Housing - Center Section - Gear Set Cleaning Spridgets 4
S For Sale Tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
oldbagpipe For Sale TR4 Detroit Locker Differential $1,000 Triumph Classifieds 3
