rusty but solid seat bottom
roofinwilly
Looking to buy one seat bottom for my bugeye from an early midget or sprite. Must be rusty but solid to match the original. Will coat old and new with POR-15 prior to new covers. Contact on or off line with any leads. Thanks
tony barnhill
Great Pumpkin - R.I.P
If you've not found one by the Fall, I have a pair!
R
roofinwilly
Cause the other one is
too much
J TR2/3/3A Rusty pushrods Triumph 1
L TR2/3/3A Who's using what to treat rusty stuff TR3 Triumph 21
J TR2/3/3A Replace rusty sills? Triumph 10
J TR5/TR250 TR250 Rusty Plenum Triumph 2
NutmegCT Exterior paint - rusty spot Restoration & Tools 3
G Old rusty gril/ headlight bucketsl wanted MG 3
Lynn Kirkpatrick Loosen a rusty brake fitting nut Restoration & Tools 5
PatGalvin Rusty Boot Lid Follies Triumph 24
bugedd Rusty Bugeye in a yard Spridgets 0
I Tips on removing rusty bolts or screws? Spridgets 16
T ever see a rusty thrust washer? Triumph 10
B Restore a rusty uni body car vs a full frame car? Restoration & Tools 4
jlaird Rusty old Bugeye grill Spridgets 10
HealeyPilot Rusty brake rotors Austin Healey 6
R BJ8 rusty seat pan Austin Healey 5
NutmegCT TR2/3/3A TR3A rusty floor, part one Triumph 4
vping Freeing up a rusty jack - Any tips? MG 20
1979Roadster RUSTY FUEL PUMP MG 6
G Spitfire Rusty Bumpers on My Spit Triumph 10
KLUTZ Rear Rubber Rusty Bumper MG 11
jcatnite Rusty's Bad Habit Spridgets 17
Howard_The_Duck Rotten and Rusty Front Cowl - Suggestions? MG 1
kindofblue ID this Rusty One Triumph 5
Nunyas grr! rusty old heater pipes... MG 5
TigerEddie Elise Mk 1 recalls for rusty footwells? Lotus 0
78Z Removing Rusty spindles in junkyard Restoration & Tools 9
T Rock Tumbling Rusty Bits and Pieces Spridgets 5
S Rusty coolant Austin Healey 0
S Rusty coolant Restoration & Tools 6
V For Sale Hard Top and Solid Walnut Dash for Sale Triumph Classifieds 2
KVH General Tech Rear Brakes and Solid Axle Triumph 2
T Wanted Looking for a solid [but doesn't have to be perfect] 100-6 Austin Healey Classifieds 17
C AUF214 solid state conversion question British Motor Corp 0
R Solid state SU Fuel Pump Austin Healey 2
D TR4/4A Seals on TR4 Solid Rear Axle Triumph 5
KVH TR4/4A Removing Rear Differential Seal--Solid Axle Triumph 1
T TR4/4A Differential clatter-solid axle Triumph 4
Popeye TR4/4A TR4A solid axle rear leaf spring question Triumph 14
N Spitfire Question on solid steering rack mounts! Triumph 3
BobbyD New OD Controller & Solid State Rheostat Triumph 0
richie TR4/4A Wheel fitment on TR4a solid axle vs IRS Triumph 6
T TR4/4A Refreshing solid axle TR4a rear bushings Triumph 4
T Tvr 2500m For Sale, Nice Original Solid Example. TVR 1
Stinger TR4/4A TR4A Wood Dash Plywood or Solid Wood Triumph 13
coj Solid state turn and brake box Austin Healey 7
V Solid state fuel pump question Spridgets 2
T TR4/4A Which TR4a is better - IRS or solid axle? Triumph 30
hymodyne rubber, poly vs solid steering rack bushings Triumph 12
PAUL161 Solid Throttle Disk for HIFs MG 7
Banjo TR4/4A TR4A solid rear axle, axle. free Triumph 8
