Loosen a rusty brake fitting nut
Lynn Kirkpatrick
Does anyone have a sure way to loosen a rusty brake line nut on a brake hose?
I've sprayed/soaked it overnight with weasel whiz and now have PB Blaster on it. I'm using fitting wrenches, not just open end, but I can feel the wrench starting to slip. I could try vise grips, but I hate to chew up the nut if there is a better way.
I can let it soak longer. I wondered about applying a little heat, but brake fluid boils at about 300 deg. F,so I'm not sure that will help much, after flushing the penetrants off.
Any suggestions? Thanks
trrdster2000
Lynn, Sorry to hear you are having such trouble, but I think it has been tightened so much that the connection on the bubble has flared and you will destroy the threads on the way out, even if you get it come loose. I hope it's just a rear wheel and not the front. The brake wrench should capture the nut, and vise grips will just crunch the fitting, sounds like a replacement.
Good Luck, Wayne
JPSmit
I have had good luck with heat - I heat it up, throw water on it to "jolt" it, heat it up again an touch a candle to the thread - wax wicks into the threads and then try it.
JPSmit
Or perhaps disconnect at the other end since you will have to rebleed regardless.
Banjo
Even with the bleeder open it can blow a hose. I used to do a lot of Chrysler minivan front hoses. always needed to heat the nut to get it out of the block on the end of the hose. I knew it was hot enough when the hose blew off the block. (POW!!)
Are you replacing the line or the hose? If it's the hose, who cares if it blows? Just make sure you're wearing eye protection. or beat it to the punch and clip it off before you heat it up.
If you're replacing the line, clip the line just above the nut, and put a socket or the closed end of the wrench over the nut.
another trick I've had to use before is to take the hose end loose from its bracket and spin it off the end of the line. that's only if the nut is seized to the line really bad and the line looks iffy. Of course, then you should be replacing the line too.
If you just heat it up mildly with a hand held mapp gas/ propane torch, and stay on the nut instead of the end of the hose, you're not likely to blow the hose
R TR2/3/3A Loosen engine Triumph 27
NutmegCT Loosen those nuts! Restoration & Tools 5
R fulcrum pin loosen Austin Healey 9
Andrew Mace When bolts loosen up... Triumph 13
bugedd How to loosen crank bolt Spridgets 49
J TR2/3/3A Rusty pushrods Triumph 1
L TR2/3/3A Who's using what to treat rusty stuff TR3 Triumph 21
J TR2/3/3A Replace rusty sills? Triumph 10
J TR5/TR250 TR250 Rusty Plenum Triumph 2
NutmegCT Exterior paint - rusty spot Restoration & Tools 3
G Old rusty gril/ headlight bucketsl wanted MG 3
PatGalvin Rusty Boot Lid Follies Triumph 24
bugedd Rusty Bugeye in a yard Spridgets 0
I Tips on removing rusty bolts or screws? Spridgets 16
T ever see a rusty thrust washer? Triumph 10
B Restore a rusty uni body car vs a full frame car? Restoration & Tools 4
jlaird Rusty old Bugeye grill Spridgets 10
HealeyPilot Rusty brake rotors Austin Healey 6
R BJ8 rusty seat pan Austin Healey 5
NutmegCT TR2/3/3A TR3A rusty floor, part one Triumph 4
vping Freeing up a rusty jack - Any tips? MG 20
1979Roadster RUSTY FUEL PUMP MG 6
G Spitfire Rusty Bumpers on My Spit Triumph 10
KLUTZ Rear Rubber Rusty Bumper MG 11
jcatnite Rusty's Bad Habit Spridgets 17
Howard_The_Duck Rotten and Rusty Front Cowl - Suggestions? MG 1
kindofblue ID this Rusty One Triumph 5
Nunyas grr! rusty old heater pipes... MG 5
TigerEddie Elise Mk 1 recalls for rusty footwells? Lotus 0
78Z Removing Rusty spindles in junkyard Restoration & Tools 9
T Rock Tumbling Rusty Bits and Pieces Spridgets 5
R rusty but solid seat bottom Spridgets 4
S Rusty coolant Austin Healey 0
S Rusty coolant Restoration & Tools 6
6 Brake Fluid Spridgets 4
F Excessive Brake Pedal Travel Austin Healey 3
F Disc Brake Shimming Austin Healey 8
PDIGIO_6x3 TR6 BRAKE TUBING KITS Triumph 6
L Red Rubber Brake Grease Austin Healey 2
Martinld123 Emergency Brake Doesn't Release Austin Healey 9
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
M Brake Servo Austin Healey 2
J MGB BRAKE VALVE ? MG 11
G Brake Light Switch Failure Austin Healey 24
