How to loosen crank bolt
bugedd
Okay, I am frustrated. Between my child verbally abusing me and the car, I am about ready to start drinking. And its only 11am. So what is the trick to getting the crank bolt loose? I tried putting it in gear, blocking the wheels, and nothing. It pushes the blocks out of the way. I put the breaker bar against the inner fender and cranked the motor and it wouldn't break loose. The steering rack is in the way, so I can't get the impact on it. Solutions?
tomshobby
Maybe not a good idea to use the gears in the drive line for a break against that kind of force. The gear teeth are not designed for it. I once did that with a large farm tractor I owned instead of getting out the impact and ended up replacing a rather expensive gear. AND still had to get out the impact.
Can you leave the transmission mount on and raise the engine enough to get at it.
mightymidget
I had no luck at home, took to a machine shop to remove cause I wasn't sure which way was lousie. Fortunately mine was out of the car
bugedd
bugedd
Ya, I can get a socket on it with it jacked up, just can't get it to break loose.
lesingepsycho
It IS lefty-loosey which is why you need to be sure to use a new locktab washer (the one I'm sure you have undone all the tabs on, right?), otherwise it can (and therefore probably will) relieve itself of its duty. How do you suppose I know that one. :smirk: :wink:
Unfortunately for you, I've never had any problems getting mine off so I don't have any clever tricks to pass along. So instead I'll just wish you good luck!
JACK
Deleted member 8987
Trick for most cars we have used in shops for decades.
Long breaker bar.
Inserted into appropriate socket.
Place socket onto bolt.
Rotate engine (by hand) in normal rotation direction (clockwise from the front) until the breaker bar is firmly against the underside of the frame rail.
Stand back,
Tap starter.
Trust me.
bugedd
bugedd
I tried taping the starter, I'll give it another try. Problem lies with engine turning over, even in gear. I wish I had an impact, that would make life easier.
JPSmit
Or a friend with an impact driver.
Is there anyone around who loans/rents them? Or a local car club you could ask? even a high school?
equiprx
Chico is probably too far away from Pacifica but you could use mine.
bugedd
bugedd
Okay, I just tried an electric GM impact wrench, and no luck. I also again tried the bump start with the breaker bar against the inner fender, and no luck either. The washer is bent out of the way. So its just really frozen in there. What I need to figure out is how to hold the motor still and keep it from turning while I break it loose. Any thoughts on how to jam up the motor? Something I can wedge somewhere?
ChrisS
My first choice would be an air impact of course but barring that you can fill a cylinder with 1/4" rope through the spark plug hole while it is on the compression stoke (both valves closed), leaving a tail outside the engine to recover the rope later. Turn the engine over by hand until it locks up and then use a breaker bar to loosen and remove the dampener bolt. To be consistent with every British car manual I've read, assemble in reverse order.
Deleted member 8987
so, tell me, this "Problem lies with engine turning over, even in gear. I wish I had an impact, that would make life easier."
WHY won't it turn over, and why are you trying to remove the damper bolt?
Is the engine toast?
If so, pull it out......going to be easier to get that bolt off when it's out.
Are you doing any more work on it?
Like, pulling the oil sump?
If so, a piece of pipe jammed between the crank counterweight and the side of the block, and a big chunk of pipe as a cheater bar on the breaker bar.
Is the starter bad?
Pull the starter, have someone hold a prybar in the ring gear teeth and then break it loose. I've had to do that on Hondas, never damaged a ring gear yet.
Heat?
nomad
My vote is with TOC. Pull the starter and use a large screwdriver or pry bar that fits the teeth on the flywheel. Always worked for me. If that won't do it use same procedure only with box open wrench on the nut then whack it with a large hammer. [Commonly known as a BFH!]
Kurt.
tomshobby
Kurt.
I agree with the pry bar on the flywheel. Much better than using the drive line gears.
bugedd
bugedd
The timing cover is cracked, that's why I am pulling this apart.
nomad
Tom: That "Swench" looks like one heck of a tool. Any idea what it costs???
Kurt.
R TR2/3/3A Loosen engine Triumph 27
NutmegCT Loosen those nuts! Restoration & Tools 5
R fulcrum pin loosen Austin Healey 9
Lynn Kirkpatrick Loosen a rusty brake fitting nut Restoration & Tools 5
Andrew Mace When bolts loosen up... Triumph 13
B TR6 71 block & crank Triumph 1
J Wanted WTB Bell Crank Pivot Triumph Classifieds 2
K TR2/3/3A What is the best way to prevent the crank from turning ........ Triumph 27
Michael Oritt Rear Crank Seal Kit Austin Healey 7
M Wanted Dampener Tr4a crank pulley Triumph Classifieds 9
T MG Midget 1500 crank shaft pulley Spridgets 0
S TR2/3/3A Tightening the crank pulley dog bolt on a tr3 Triumph 7
nichola TR6 Door handle and window crank installation Triumph 0
D TR2/3/3A TR3 throttle linkage bell crank. Triumph 29
R Wanted 3 main crank MG Classifieds 1
Twit early TR4 Crank Handle wanted Triumph Classifieds 0
P TR6 Tight window crank Triumph 9
71TR6 Triumph TR4 Coventry Radiator with crank hole- recently refurbished Triumph Classifieds 0
D TR2/3/3A TR3A Crank Dog Triumph 2
K TR2/3/3A The timing mark on the crank pulley.... Triumph 5
K For Sale Starter Hand Crank Triumph Classifieds 0
jtaylor3 1275 EN40 Crank Spridgets 5
J TR2/3/3A Flywheel-Crank Dowel Alignment Triumph 6
R TR2/3/3A Extension Crank Bolt Attachment Triumph 12
M Wanted TR3 Hand Crank Guide Triumph Classifieds 3
Alfred E. Neuman TR4/4A TR4 fan extension and crank bolt length Triumph 9
D TR2/3/3A Crank handle support Triumph 11
Got_All_4 TR2/3/3A Hand crank misalignment Triumph 9
K For Sale TR3 crank handle Triumph Classifieds 0
M Wanted TR-3 Crank Handle Triumph Classifieds 3
R TR2/3/3A Temperature Gauge for 1954 TR-2 & Hand Crank Triumph 17
Got_All_4 TR2/3/3A TR3 engine hand crank Triumph 14
ckeithjordan Wanted WTB: TR3 Crank Handle Guide Stays Triumph Classifieds 1
D BT7 tri-carb installing my crank Austin Healey 4
R General Tech Crank bearing cap broke...Torque?? Triumph 37
Rut Crank/flywheel dowels Spridgets 3
R TR2/3/3A One more crank pulley question Triumph 7
R TR2/3/3A Crank pulley question Triumph 4
GTP1960 TR2/3/3A Timing cover/crank hub oil seal Question Triumph 4
Boggsy64 MGB Crank doesnt turn freely - new main brgs MG 21
jfarris TR2/3/3A TR3 tining without marks on crank pully Triumph 6
T Replacing the crank pulley/damper Austin Healey 4
T TR4/4A How to determine if the crank is good before pulling the engine out Triumph 8
R Crank damper alignment Austin Healey 6
R timing gear crank shims Austin Healey 11
R Dennis Welch Rear Crank seal conversion - Gap in back plate Austin Healey 19
R Engine crank shaft nuts Austin Healey 1
B Remove Crank Nut Austin Healey 55
M_Pied_Lourd TR2/3/3A Crank Oil Slinger Orientation Triumph 2
S TR4/4A Water pump and crank nose questions Triumph 7
