Wanted TR-3 Crank Handle
karls59tr
Bronze
Hello Marty I have a TR3 crank handle from a 1959 TR3A. Not sure if there was a difference from year to year? I would like $140US plus shipping. I can send a pic if you are interested?
Karl
M
Marty V
Karl, Thank you for your response. At this time , as luck would have it , I have been offered another for slightly less. Again, thank you for your quick response.
kjman55
Out of interest , 30 odd years ago I bought some Vanguards and discovered that Phase 2 and phase 3 Vanguard crank handles are almost identical (about a 1/2" difference in the handle but identical from the crank pulley to the grille fitting ( whatever it's called)) and they do the job just as well Unfortunately they are probably even more scarce than TR ones these days.....
nichola TR6 Door handle and window crank installation Triumph 0
Twit early TR4 Crank Handle wanted Triumph Classifieds 0
D TR2/3/3A Crank handle support Triumph 11
K For Sale TR3 crank handle Triumph Classifieds 0
ckeithjordan Wanted WTB: TR3 Crank Handle Guide Stays Triumph Classifieds 1
K TR4/4A TR4A window/door crank handle removal? Triumph 11
L Door handle and window crank escutcheons Triumph 7
memphis remove door handle and window crank Austin Healey 18
1 Window crank handle broke MG 12
C TR2/3/3A crank handle for tr-3 Triumph 2
B TR6 71 block & crank Triumph 1
J Wanted WTB Bell Crank Pivot Triumph Classifieds 2
K TR2/3/3A What is the best way to prevent the crank from turning ........ Triumph 27
Michael Oritt Rear Crank Seal Kit Austin Healey 7
M Wanted Dampener Tr4a crank pulley Triumph Classifieds 9
T MG Midget 1500 crank shaft pulley Spridgets 0
S TR2/3/3A Tightening the crank pulley dog bolt on a tr3 Triumph 7
D TR2/3/3A TR3 throttle linkage bell crank. Triumph 29
R Wanted 3 main crank MG Classifieds 1
P TR6 Tight window crank Triumph 9
71TR6 Triumph TR4 Coventry Radiator with crank hole- recently refurbished Triumph Classifieds 0
D TR2/3/3A TR3A Crank Dog Triumph 2
K TR2/3/3A The timing mark on the crank pulley.... Triumph 5
K For Sale Starter Hand Crank Triumph Classifieds 0
jtaylor3 1275 EN40 Crank Spridgets 5
J TR2/3/3A Flywheel-Crank Dowel Alignment Triumph 6
R TR2/3/3A Extension Crank Bolt Attachment Triumph 12
M Wanted TR3 Hand Crank Guide Triumph Classifieds 3
Alfred E. Neuman TR4/4A TR4 fan extension and crank bolt length Triumph 9
Got_All_4 TR2/3/3A Hand crank misalignment Triumph 9
R TR2/3/3A Temperature Gauge for 1954 TR-2 & Hand Crank Triumph 17
Got_All_4 TR2/3/3A TR3 engine hand crank Triumph 14
D BT7 tri-carb installing my crank Austin Healey 4
R General Tech Crank bearing cap broke...Torque?? Triumph 37
Rut Crank/flywheel dowels Spridgets 3
R TR2/3/3A One more crank pulley question Triumph 7
R TR2/3/3A Crank pulley question Triumph 4
GTP1960 TR2/3/3A Timing cover/crank hub oil seal Question Triumph 4
Boggsy64 MGB Crank doesnt turn freely - new main brgs MG 21
jfarris TR2/3/3A TR3 tining without marks on crank pully Triumph 6
T Replacing the crank pulley/damper Austin Healey 4
T TR4/4A How to determine if the crank is good before pulling the engine out Triumph 8
R Crank damper alignment Austin Healey 6
R timing gear crank shims Austin Healey 11
R Dennis Welch Rear Crank seal conversion - Gap in back plate Austin Healey 19
R Engine crank shaft nuts Austin Healey 1
B Remove Crank Nut Austin Healey 55
M_Pied_Lourd TR2/3/3A Crank Oil Slinger Orientation Triumph 2
S TR4/4A Water pump and crank nose questions Triumph 7
GTP1960 TR2/3/3A Removing the fan extension from the Crank hub Triumph 13
