TR2/3/3A crank handle for tr-3
captainde
Member
I have a 1957 Tr-3 with a tr-4 engine, also it has a tr-4 fan pedestal which is longer than the tr-3 one. I got a shorter tr-3 pedestal and crank bolt today, I have a tr-3A hand crank. I would like to know if it is just the distance of the fat part of the handle that separates the two handles. It looks like the fat part can be moved as it appears to be pressed on to the handle.
Thanks,
captainde
Geo Hahn
Here's some pics of 2 handles which might offer a clue:
But I would think moving the 'fat bit' would be very difficult.
They come up often on eBay... were it me, I would sell the crank you have and buy the crank you need.
nichola TR6 Door handle and window crank installation Triumph 0
Twit early TR4 Crank Handle wanted Triumph Classifieds 0
D TR2/3/3A Crank handle support Triumph 11
K For Sale TR3 crank handle Triumph Classifieds 0
M Wanted TR-3 Crank Handle Triumph Classifieds 3
ckeithjordan Wanted WTB: TR3 Crank Handle Guide Stays Triumph Classifieds 1
K TR4/4A TR4A window/door crank handle removal? Triumph 11
L Door handle and window crank escutcheons Triumph 7
memphis remove door handle and window crank Austin Healey 18
1 Window crank handle broke MG 12
B TR6 71 block & crank Triumph 1
J Wanted WTB Bell Crank Pivot Triumph Classifieds 2
K TR2/3/3A What is the best way to prevent the crank from turning ........ Triumph 27
Michael Oritt Rear Crank Seal Kit Austin Healey 7
M Wanted Dampener Tr4a crank pulley Triumph Classifieds 9
T MG Midget 1500 crank shaft pulley Spridgets 0
S TR2/3/3A Tightening the crank pulley dog bolt on a tr3 Triumph 7
D TR2/3/3A TR3 throttle linkage bell crank. Triumph 30
R Wanted 3 main crank MG Classifieds 1
P TR6 Tight window crank Triumph 9
71TR6 Triumph TR4 Coventry Radiator with crank hole- recently refurbished Triumph Classifieds 0
D TR2/3/3A TR3A Crank Dog Triumph 2
K TR2/3/3A The timing mark on the crank pulley.... Triumph 5
K For Sale Starter Hand Crank Triumph Classifieds 0
jtaylor3 1275 EN40 Crank Spridgets 5
J TR2/3/3A Flywheel-Crank Dowel Alignment Triumph 6
R TR2/3/3A Extension Crank Bolt Attachment Triumph 12
M Wanted TR3 Hand Crank Guide Triumph Classifieds 3
Alfred E. Neuman TR4/4A TR4 fan extension and crank bolt length Triumph 9
Got_All_4 TR2/3/3A Hand crank misalignment Triumph 9
R TR2/3/3A Temperature Gauge for 1954 TR-2 & Hand Crank Triumph 17
Got_All_4 TR2/3/3A TR3 engine hand crank Triumph 14
D BT7 tri-carb installing my crank Austin Healey 4
R General Tech Crank bearing cap broke...Torque?? Triumph 37
Rut Crank/flywheel dowels Spridgets 3
R TR2/3/3A One more crank pulley question Triumph 7
R TR2/3/3A Crank pulley question Triumph 4
GTP1960 TR2/3/3A Timing cover/crank hub oil seal Question Triumph 4
Boggsy64 MGB Crank doesnt turn freely - new main brgs MG 21
jfarris TR2/3/3A TR3 tining without marks on crank pully Triumph 6
T Replacing the crank pulley/damper Austin Healey 4
T TR4/4A How to determine if the crank is good before pulling the engine out Triumph 8
R Crank damper alignment Austin Healey 6
R timing gear crank shims Austin Healey 11
R Dennis Welch Rear Crank seal conversion - Gap in back plate Austin Healey 19
R Engine crank shaft nuts Austin Healey 1
B Remove Crank Nut Austin Healey 55
M_Pied_Lourd TR2/3/3A Crank Oil Slinger Orientation Triumph 2
S TR4/4A Water pump and crank nose questions Triumph 7
GTP1960 TR2/3/3A Removing the fan extension from the Crank hub Triumph 13
