TR4/4A Hydralic bleed
Winston
I've replaced both the Master and Slave cylinder on myTR4, line bent by hand to conform. No leaks, no kinks. I'm having to pump the clutch pedal to get pressure to engage clutch. No shudder, just spin on downshift. reservoir full. Clutch replaced 7 or so years ago. Was all good last season. Opinions appreciated.
Geo Hahn
You might look at how much movement you get on the clutch operating arm (the thing that the slave moves) -- I think that should be around 1/2 to 5/8" of movement.
That might give you a clue as to whether the issue is hydraulics or something internal.
If hydraulics at fault - try again to bleed.
If internal -- one suspect that comes to mind is a broken clutch fork pin.
Sarastro
Assuming there is no visible leakage, I see two possibilities:
1. The clutch needs bleeding.
2. The master cylinder needs to be rebuilt. The valve seal is allowing leakage back into the reservoir.
The good news is that both are cheap options.
A TR6 Need clutch hydralic line ideas [TR6] Triumph 24
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
K TR2/3/3A Another brake bleed question....... Triumph 17
WHT Remote Clutch Slave Cylinder Bleed Extension Austin Healey 11
bugedd Bench bleed tips Spridgets 14
G Brake/clutch resevoid replaced do I have to bleed the system Austin Healey 9
Jim_Gruber Did my clutch just bleed itself? Spridgets 11
K TR4/4A Hey CJD...gravity bleed clutch MC and slave? Triumph 6
T TR2/3/3A Bench Bleed Girling Master Cylinder Triumph 2
princetn1 MGB Clutch Bleed MG 3
M General MG Midget clutch bleed - engine out MG 3
trotti Access to the clutch slave cylinder bleed screw Austin Healey 41
AngliaGT 1275 - Just HOW Do I Bleed the Slave Cylinder? Spridgets 4
T TR2/3/3A Only women bleed Triumph 8
K TR2/3/3A Clutch bleed using"gravity bleed" method? Triumph 4
M Bn-2 Windshield Seal Paint Bleed Austin Healey 8
jlaird Brake bleed niples Spridgets 34
K TR2/3/3A TR3A with TR6 trans Clutch Bleed Issue Resolved. Triumph 6
K TR2/3/3A TR3A Clutch Slave Bleed Issue? Triumph 8
D BN2 master cylinder bleed Austin Healey 2
B Bleed Screws Spridgets 2
bugedd Brake bleed question Spridgets 9
bugedd Brake bleed screws Spridgets 6
nevets How to clean a E Z Bleed ? Restoration & Tools 11
K TR2/3/3A TR3 Clutch master and slave bleed issues? Triumph 5
John_Mc Bench bleed slave cylinder? Triumph 4
M Rocker Arm without Oil Bleed Hole Austin Healey 4
eschneider xj6 purge valve / air bleed valve Jaguar 4
R T-Series Still No Luck With Clutch Bleed MG 15
Trevor Jessie Eezi-Bleed Tech tip Spridgets 1
Z TR6 Can't seem to bleed TR6 brakes Triumph 10
jjbunn Missing Bleed Nipple? MG 6
A Brake bleed Austin Healey 3
glemon Help Cant Bleed Brakes Triumph 15
1 So, I need to bleed my brakes on 60 BE.... Spridgets 3
T Any tips on how to bleed brakes?? Triumph 16
D clutch bleed ? Spridgets 2
steved033 Clutch stuck, a bleed doesn't help. Austin Healey 20
2wrench Speed bleed tool Triumph 15
SCguy bleed clutch? Triumph 3
R T-Series MGB Clutch Bleed Solution MG 5
RedTR3 TR2/3/3A TR3 Clutch slave bleed screw size Triumph 4
jerrybny Master Cylinder Bleed Kit Triumph 8
jerrybny master cylinder bleed kit Restoration & Tools 2
MrPandy Bleed the oil pressure gauge? Triumph 5
Woodie how do you bleed a clutch? Spridgets 12
I Brakes won't bleed Triumph 14
A BJ8 Blake Bleed Mystery - Low Fluid Flow Austin Healey 3
S Brake Bleed after Servo Installation Austin Healey 4
G Teflon tape on bleed screws Austin Healey 13
